Question about Kirby Ultimate G Bagged Upright Vacuum
The belt broke and there was a bit of a burning smell - I attached the carpet cleaner attachment with integral belt but there's no electric power
  • 701 Answers
Here is the belt you need:
Kirby Ultimate G Belt
Posted on Nov 17, 2009
My vacuum cleaner is very hard to push. It feels very heavy and drags on the carpet
Did your vacuum have a bit of a burning smell prior to this happening? I'd guess that the belt for the agitator brush failed (either broke or stretched) and the brush is no longer spinning. If you find the belt is the culprit, it probably failed due to hair and/or dust binding up the agitator, so be sure to clean the brush and bushings prior to replacing the belt, otherwise the new belt may fail prematurely as well.
Sep 21, 2017 | Vacuums
Tip
How To Attach The Carpet Shampooer Cleaning Attachment Kirby Generation 3 (G3).
This is an excellent, easy to follow video presentation of attaching the carpet cleaner to your Kirby Generation 3 Upright Vacuum Cleaner. Please note that the model being used in the video is a newer model named the Sentria, but the process of attaching the carpet extractor attachment is identical on the Kirby Sentria and the Kirby Generation 3. The only major difference is that the Generation 3 does not have the lever that extends out to turn the belt to off. On the Generation 3 this is dont by turning the entire white square with the Kirby logo on it in the front of the vacuum cleaner.
Please feel free to ask for a repair clarification if you have a question on how to attach the carpet shampooer. I'm always, more then happy to answer any follow up questions there may be.
Instructional Video On How To Attachment Carpet Shampooer To Kirby Generation 3 Vacuum Cleaner:
http://kirbywhq.powweb.com/videos/Carpet_Shampoo.mov
I hope that this helped you change your Kirby into a carpet shampooer. I you found this video helpful, please rate this Tip as helpful by clicking the Thumbs Up Icon. I really do appreciate it, thank you.
Chris J.
on Mar 21, 2010 | Kirby Generation 3 Bagged Upright Vacuum
When using, smells like vacuum is burning. This is without the powerless attached. What do I need to do?
It is most likely the belt. The belts stretch out over time and start slipping. When they slip they burn. Also check to make sure nothing is keeping the roller brush from spinning.
Mar 05, 2016 | Rainbow Vac Cleaner E, E2 Series Electric...
I have a steam vac spinscrub carpet cleaner works good but it just started smelling like it was burning and started to smoke
Anytime someone says they smell something burning on any type of vacuum cleaner of carpet cleaner etc. All I can think of is the belt is rubbing on plastic which would cause the sense of something burning because you possibly are smelling the belt........
Mar 12, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Hoover carpet cleaning started to smell like it's burning and black chunks of rubber came out
Nan, there's obviously a belt that's shot and needs to be replaced. If it started to smell, then it was probably bound up at some point in it's travel path, that stops it from running and the motor shaft burns it's way through the belt, making the smell.
Nov 03, 2013 | Hoover SteamVac Carpet/Upholstery Deep...
I have a Lux Floor Pro Heavy Duty carpet cleaner. Whis attachments (scrubbers) do I attach to the bottom to wash a non-plush carpet. I have three attachments that have hard bristles and three that have...
NEVER USE THE HARD BRUSHES ON CARPET ! You can burn up your motor, break the drive belt,or strip the drive gears The black bristle brushes are for all carpet types.
The hard bristle brushes are made for hardwood and other smooth surfaces.
Oct 24, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Hoover F6025900 Steam Vac Widepath LS, I own this steam vac and I found bits of rubber under the machine when I turned it on, smelled like burned rubber from a belt? Can you please tell me if there is a...
Well there is no belt, and not sure what the rubber would be from, everything is plastic or metal. Unless it is really an electrical smell, which means the motor is going bad.
Jun 22, 2008 | Hoover Vacuums
Smell from the motorof the vacuum cleaner
ALL VACUUMS SMELL TO SOME EXTENT. YOU DON'T MENTION IF THIS IS A NEW PROBLEM OR NOT.
WHAT I DO IS VACUUM UP A LITTLE BIT OF TIDE (ANY POWDER WILL DO) WHEN I CHANGE THE BAG.
USE THE HOSE WHEN DOING THIS. THOSE FINE POWDERS THEY SELL TO "FRESHEN" YOUR CARPET ARE GRITTY AND NOT GOOD FOR YOUR ELECTRIC ATTACHMENTS AND MAY ALSO CLOG THE BAGS AIR FLOW.
Apr 25, 2008 | Vacuums
Smell/suction
The brushroll may spin when looking at it but stops when pressure of the floor is applied. The belts stretch, so they look fine but are not. The smell - if it's a rubber smell - would also be the belt. Some, or most, brushrolls can get hair in the ends that could also cause a smell and belt problem.
Dec 17, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Burning smell/lost suction
Is the brush roll turning while on the carpet. If the belt is old, then it has stretched and will slip causing a rubber smell. But if it is an electrical smell, then your motor is failing and will need to be replaced.
Dec 15, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Kirby Ultimate G Bagged Upright Vacuum Logo
85 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
