Question about Thermador DWU244 Dishwasher
I purchased a thermos gas grill without the manual. It did not come with a gas tank or instructions on how to use. Can I see a manual for this model 461630007. Thanks.
  • 11,896 Answers
What is the make? Is it Thermador? If so, you can get the manual here;
http://www.thermador.com/SupportCenter/DocumentDisplay.aspx
Posted on Nov 17, 2009
Grill does not get hot. I have a fresh bottle of propane. Hose is not kinked. Grill is maybe 6 - 10 years old.
hi,
When a new or newly filled propane tank is attached to your gas grill, the OPD is usually at its maximum limit position above a tank filled to capacity. Propane may come through the valve too strongly due to the additional pressure of being full and the OPD displacement. The propane tank goes into check and limits gas flow when too much pressure hits the valve. Some grill manufacturers provide instructions for this in the users manuals but most people do not read the manual. Many grillers believe replacement parts are needed and burners, ignitors and regulators get replaced without reason. Depending on how efficient the grill is operating, some grills attached to a tank in check will not ignite and others will light but cannot reach cooking temperatures because the tank has limited the amount of propane released. Sometimes the food will be unable to exceed 200 degrees in temperature because the propane tank is in check.
Gas grill replacement parts are available and are sometimes necessary, low or no gas flow indicates a different typr of repair. Most grillers accept instructions and the problem is corrected in minutes -- but believe it or not I have had a few insist on purchasing replacement parts.
How do I fix grill?
To reset the check valve and get back to cooking on your gas barbecue grill, first
turn everything off. Turn off the grill, the rotisserie, the side burner and the LP gas cylinder tank. Once everything is turned off disconnect the propane tank from the gas grill regulator by unscrewing it or pulling the quick-release on older or retro-fitted propane cylinders. Now turn the grill on. I know, it is dis-connected from the gas tank but we want to ensure that the pressure in the gas lines or any gas in the burners is released. Leave all grill burners in the on position for 3 - 5 minutes before turning them off. Make sure. Most gas grill valves must be pushed in to turn them and if turning is attempted without pushing the knob, they will not turn to the "on" position. With the grill, et al turned off reconnect the propane tank and slowly turn the hand wheel to the open position.
Slowly. The trick here is to turn the hand wheel slowly. Propane in a new or very full tank will be under more pressure, especially with the OPD floating in position. The extra pressure will come through the tank valve stronger. Turn the gas tank slowly allowing small increments of propane to enter the grill.
Once this is complete, you should be able to turn the grill on high and ignite your gas grill burner. Your cooking heat should be back to normal and cooking times decreased. If the problem persists, try this process again to make sure you followed every step. The check valve exists to save your life if there is a leak in any of the gas fittings. Constant check valve issues could imply a gas leak and a visit from your local gas grill service technician may be necessary.
To find a leak, turn the grill valves to the off position and the gas tank valve to the full on position. This should pressurize the gas line. Spray soapy water on all the fittings and look for bubbles just like checking for the leak in a flat tire.
Do not attempt to correct a gas leak on your own. While a check valve error when your gas grill will not get hot or will not ignite is a user education error and an issue corrected by learning about your propane tank, a gas leak should be corrected by a licensed gas service technician. When you are grilling, turn the propane tank on first and then turn on your grill. When you are done cooking, turn the gas tank off first and then turn off the grill valves. The process releases the pressure in the gas grill hose and manifold which allows the gas tank to release pressure by filling these lines. Read the safety features of your gas grill, clean it when necessary and replace used and failing parts. Aside from that be safe, eat well and have fun.
thanks.
Jun 15, 2010 | Weber Genesis Silver B Grill
I am not getting gas to the grill burners
Check out the reg could not be passing gas
Jul 05, 2017 | Thermos Stainless Steel Gas Grill
This is for the Thermos Millenium 4000: I need
Ive replaced the gas tank and make sure valve is on tight but the flame is still weak!?
Feb 01, 2010 | Thermos Quick Set Gas Grill 4000
Converting Thermos Stainless Grill to natural gas
You have to install a conversion kit for it to work the way you want. The reason is because the orifice in either the valves or the main "jet" that feeds the burner tube has to be changed. Natural gas is really not as efficient as lp gas (propane) because it takes more natural gas to create the same btu output as propane.
In short, your grill will not work if you do not do the conversion. I am including a link that lists the conversion kit for your grill, you can order it there and you can download the assembly manual as well.
Here is the link: http://www.charbroil.com/Consumer/product_detail_e.aspx?ProductID=1723&CategoryID=25
Nov 20, 2009 | Thermos Stainless Steel Gas Grill
Thermos Fire&Ice Grill2Go user's manual
Grill2Go manual http://www.appliancefactoryparts.com/content/pdfs/8623.pdf
Jan 23, 2008 | Thermos Grill2Go Fire+Ice
Thermador DWU244 Dishwasher Logo
65 people viewed this question
Top Thermador Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
DROPNDEAL
DROPNDEAL
Are you a Thermador Dishwasher Expert? Answer questions, earn points and help others
