Question about Microsoft Xbox 360 Console
My xbox is showing one red light ,what thats mean
My xbox 360 is showing one red light at the bottom
    Genius:
  • 1,234 Answers
Hello Mr .
1) Remove your hard drive and/or memory units.
2) Run "Initial Setup" under the system blade.
3) Decline inserting HDD or memory unit when prompted.
4) Sync your controller and pop in a game.
Fix-shadow
Posted on Aug 27, 2010
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
I started my xbox360 and my controller won't connect and then a red light came on in the right bottom of the circle .what do i do ? Or what is going on?
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Dec 26, 2010 | Microsoft Xbox 360 Console
Xbox 360 one red light bottom right
Nov 05, 2010 | Microsoft Xbox 360 Console
What's the difference between a xbox 360 over heating and the rrod
There are 4 different kinds of RROD on a xbox 360. When the ring of light shows 1 red light, it means there is a minor hardware issue. If it shows 2 red lights, it means it over heated. If it shows 3, it has a major hardware failure and 4 red lights means that you dont have your A/V cables plugged in. Hope this helps.
Aug 04, 2010 | Microsoft Xbox 360 Console
My xbox has E74 what do i do about getting it fixed, however it only shows one red ring in the bottom right of the circle when it is turned on, not three
The Error 74 means that your 360 is experiencing hardware failure. Only one red light should show up. You should send you 360 to Microsoft for a repair. If you are not under warranty you could fix it yourself, by doing the X clamp repair. But by opening your 360 it will void your warranty so be careful.
Hope this helps
May 07, 2010 | Microsoft Xbox Console
My xbox has one red light and the code E94 shows
this means that your scaler chip on your 360 is damaged, or you over heated it. try doing the towel trick, which is wrapping a towel around your xbox and over heating it, thus melting the scaler chip down to your motherboard, or turn it in for repair if you don't want to do that. i recommend personal repair.
Dec 14, 2009 | Microsoft Xbox 360 Console
Wont load,blinking red light on the power button
if it is the top left, bottom left and bottom right lights blinking red, this means that there is a hardware failure in your xbox 360 and there is no current way to fix this. i recommend that you send it in to xbox to see if they can do anything, and if not, they will possibly send you a new xbox 360.
Sep 27, 2009 | Microsoft Xbox 360 Console
E-68
Hello Ya Boy P,
According to Xbox Support, one red light means you have a system error and suggest that you contact Microsoft Customer Support for further assistance. Here is a link that should help you out.
http://support.microsoft.com/kb/907536
The hard drive do come with the Xbox 360 depending on with version you purchase. If you purchased the premium version or the elite version, the hard drive will come with the Xbox 360. Otherwise you can purchase a hard drive for the Xbox 360. I hope this information helps.
Sincerely,
Agent Xiong
May 21, 2008 | Microsoft Xbox 360 Console
X box 360
red lights means there is an error usally can be fixed make sure all cables are CORRECTLY plug in. Second make sure it is a proper xbox or xbox 360 game.
Nov 02, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
57 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
