Question about Apple iPod nano
Problem with the volume I have to turn the volume to the max to hear music
  • 11,896 Answers
Check headphone jack is tight, try turning the jack to see if there is a better connection or try different headphones.
Posted on Nov 17, 2009
My NAD C350 plays very faintly. when I turn the volume dial to the max position, I can bearly hear the music. I can hear properly from earphones output. Thanks
Take care. First put the volume down complete. Then unplug the head phone and than try to raise the volume. Could be the headphone connector does not switch through correct. Could be the connections between the pre and power amp are not in place or not proper pushed in?
Always take care when working with amplifiers. When switching them on with volume to max, you easy can kill your speakers. Also when disconnecting the headphones on full power kan damage the loudspeakers.
Aug 29, 2013 | NAD Audio Players & Recorders
No volume from turntable, even with volume turned to max, are ther internal fuses ?
You don't state which model the turntable is. Without this we are working blind. If the turntable has a built in amp then that will have failed. A blown fuse would shut down everything. If it has no built in amp and you have it connected to a separate amp, then you have either connected it to the wrong socket - it needs a phono socket - or if the amp doesn't have one you need a magnetic cartridge preamp.
Apr 12, 2013 | Audio Players & Recorders
When I connect me ipad to the Philips mx5500D the sound is low
maybe your ipad's volume is low - volume settings for ipads are different when both plugged / unplugged
Oct 27, 2012 | Philips MX5500D System
Low volume on incoming calls
remove battery from phone and reinstall after 10 mins... this seems to fix alot of things also go to sound setting a make sure the volume is turned up all the way
Jul 09, 2012 | Apple iPhone 3G
I need to unlock my volume control
Press menu button, select settings, select playback, select volume limit, turn volume to max and press select button. This should let you play music at max volume
Nov 01, 2009 | Apple iPod classic MP3 Player
Ipod shuffle second generation, volume has dropped to where the volume has to be at max just to hear it. Factory volume settings were never changed, it just kept getting quieter every time i used it. Do i...
Your battery might be going out. If you are sure that your battery is OK, then go to iTunes and make sure that you can see your iTunes library.
  1. Go to the menu bar and click on Edit. Then click on Select all. All of your music will be selected and turn blue.
  2. Right Click anywhere in the music library.
  3. You will get a message that asks if you want to edit all of your music library. You will click 'Yes'.
  4. A new window will open. There will be 4 tabs. Pick the one that says Options. There you will see a slider to adjust the volume in all of your music. The slider will be set in the middle. You can slide it to the right to about 80-90.
  5. Close your window. iTunes will begin changing the volume on all of your music.
  6. When it is finished, plug in your iPod and see how much different it sounds. Turn down the volumn on your iPod until you can readjust it.
Hope that helps.
Dec 08, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Using my ipod in my car
try the volume setting on your ipod. it may have to be adjusted. go to settings, volume and see where you are on the slider and adjust to the volume you want. ipods come factory set at a predetermined volume level.
Nov 20, 2007 | Apple iPod nano
Apple iPod nano Logo
46 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
