Question about Sony Xplod XM-554ZR Car Audio Amplifier
I have a 2007 chevy silverado classic an i dont
I have a 2007 chevy silverado classic an i dont know which wire i need to hook up the remote wire on my amp
  • Israel Adame
    Israel Adame May 11, 2010
    factiry or aftermarket stereo?
  • 506 Answers
Buy the aftermarket harness for it. Within the harness there should be a wire that says power ant or remote. Splice a wire to that and run it back to your remote turn on.
Posted on Dec 15, 2009
Need the wiring diagram for a 2007 chevy silverado classic truck wiring for the signal lights
Go on line to a company called HELM .So its Helm .com
They print the factory manuals for most of the big boys .with a Chevy you might need 2 but their 50 bucks a pop and you will be able to look up and thing about your vehicle and never to ask anyone again .
Sep 09, 2016 | 2007 Chevrolet Silverado Classic SS New...
Chevy silverado where is the horn relay
It depends if it is a classic or new style Silverado. Both were made in 2007. If it is a classic Silveradothere is a replaceable relay in the under hood fuse block. If it is a new style Silverado the horn relay is part of the printed circuit board that is only available with UBEC (under hood bussed electrical center).
Jan 06, 2015 | Cars & Trucks
My car stereo in my 2007 Chevy silverado says locked on the screen and I can't get it to do anything.
I am not sure if this will help but try locking the doors without the remote and then use the door key to unlock the door and start the truck this is just an idea but it worked on my daughters car
Sep 19, 2011 | 2007 Chevrolet Silverado Classic SS New...
2007 Chevy silverado (classic). Once hooked up to trailer, the brake lights do not work only turn signals on trailer.
firat of all check and make sure you have a real good ground or otherwise you will lose current to another wire and this can short out and cause the lights to malfunction.
White: Ground
Brown: Running
Yellow: LT and Stop
Green: RT and Stop
This is the wiring code for the 4 wire trailers and
Wire a round seven-pin hitch, typically sold without a wiring harness, to the vehicle observing the following color codes: Run a white 10-gauge wire between ground and terminal one, run the blue 12-gauge wire between the electric brake controller and terminal two, the brown 14-gauge wire between the taillights and terminal three, the black 10-gauge wire between the permanently live 12-volt supply and terminal four, the yellow 14-gauge wire between the left turn/brake light and terminal five, the green 14-gauge wire between the right turn/brake light and terminal six and the purple 14-gauge wire between the backup light and terminal seven (in the center).
Feb 18, 2011 | 2007 Chevrolet Silverado Classic SS New...
How do I remove the driver's door panel on a chevy 2007 nbs?
open door pull ruber boot back on door side unplug wire connections snap lock release on con pull pins pull door
Jun 18, 2010 | 2007 Chevrolet Silverado Classic SS New...
Brake control hook up
off of your factory harness you will have a small brown wire and a small blue wire among the 5. Do not use the small brown wire, use the blue.
Mar 15, 2009 | 2007 Chevrolet Silverado 1500 2WD
2007 chevy silverado hook up with tekonsha 4 wire brake control, chevy has 5 wires any suggestions
the fifth wire is most likely an auxiliary power wire, for if you wanted lights inside a trailer. (PLEASE RATE MY ANSWER!)
2007 Chevy Silverado Center brake light works but back ones dont
There is a probable bad wiring connection in problem one and three.
#2 Possible water leak causing bulb break. Try wd40 in socket. you need a wiring diagam and cheap voltmeter if you want do it yourself.
Dec 24, 2008 | 2007 Chevrolet Silverado Classic SS New...
Sony Xplod XM-554ZR Car Audio Amplifier Logo
187 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
