Question about SVA-USA EV-1703 17 in. LCD Television
The power went out and having trouble getting tvto power up after power came back any hints thanks
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
Trying to install replacement side passenger window in Holden Berlina 2002 VX II - not having much luck - any hints/tricks?
what exactly are you having trouble with? the fitting of the glass? removal of the trim to gain access?
Sep 13, 2016 | Holden Cars & Trucks
30" apple cinema display suddenly went blank.
It's probably the backlight. If you look very closely, perhaps using a flashlight, you might be able to see that it is still working but just not being lit up from the back. In that case it may be worth fixing, but if not, then it's probably past its useful life.
One other thing you might try is a different power supply.
Feb 14, 2014 | Apple Cinema HD 30" LCD Monitor
Overcooked green beens the alarm went off and then the power went off on the microwave for a minute then I reset the microwave and it started to work and then it lost its power and won't come back on
Most probably magnetron Unplug machine for one hr Open machine check the magnetron (hint check the resistance of the two terminals) using ohm meter If not Then call somebody I can help if you response me back with some more details Thanks Please rate my work
Sep 06, 2011 | Samsung Microwave Ovens
To program venturer tv to dishnetwork receiver
Hi my nameis Mike Houston of DISH Network and I see you want to program the Venturer TVto our DISH Network receiver. We currently do not have the three digit code(s)for the Venturer TV, what we do have to setup the remote is called a Power Scanand it will find the code to setup the remote to the TV. I will send you the linkto help with the setup; http://www.dishnetwork.com/SupportSection/power-scan-instructions.
Jul 28, 2011 | dishnetwork.com
I have a presario 5000v and the power supply went out so I disconnect and removed the power supply and got another and I am having a hard time hooking the wiring back up I need help
What exactly are you having trouble with? I have a 5000 series Presario. Did you get an exact replacement power supply? Check the plugs to make sure.
There should be a mother board connector that will only go on one way (if yours is split, they will still only attach one way), the Molex and mini Molex are for the drives.
Post a comment if you still have trouble and I will pop my 5000 open and check for you.
Thanks for your interest in FixYa.com
Please vote
thanks
Dec 20, 2009 | Compaq Presario 5000 PC Desktop
My TH-42PX6U TV went completly dead
Ok, I hope to save you a lot of money. I finally figured it out. There are a lot of hints on the web. Once you get it fixed you will regocnize them. So here is what I did. Had to order the 2 fuses for the main power board from panasonic. The fuse number is K5D802BNA005. You only need two. Once I changed the 2 fuses I go the tv to power up but the red light blinked 10 times. This indicated there is a power problem.
There is a high probability the P board is bad. You can check this by checking th voltage on the number one pin on the p10 connector. TO do this you have to measure the voltage as you power the TV up. you should get 14 volts. if not the board is bad. I bought one on Ebay for $120. Put it in and it works. good luck.
Feb 25, 2009 | Panasonic TH-42PX60U Television
EPSON V700 Photo Scanner
Unplug the power supply from the power port on the scanner then plug it back in after a few seconds and power-up if it isn't already on. This happens to me a lot and this works every time. Frustrating though.
Jan 14, 2008 | Epson Perfection V700 PHOTO Flatbed...
SVA-USA EV-1703 17 in. LCD Television Logo
51 people viewed this question
Top SVA-USA Televison & Video Experts
Michael Galve
Michael Galve
Adorjani Laszlo
Are you a SVA-USA Televison and Video Expert? Answer questions, earn points and help others
