Question about LG RUMOR Cellular Phone
Water damage It got some water on it and freaked out. I have it got some water on it and freaked out. I have the actual phone sitting in a a 37 degree celcius incubator and the battery appears to be ok. After about an hour of incubating, i tried to turn it on and it just says LG Rumor on the screen. Good or bad for me?
  • 11,896 Answers
Good sign, means circuit board is not fried, but the software will have to be updated. You may get lucky enough to find a software update on the manufacture's website.
Posted on Nov 17, 2009
How do you change the temperature from 100 degrees Celsius to 37 degrees
Uhh. Water boils at 100 C and 37 C is normal body temperature. Not sure this is for a refrigerator. Please provide the manufacturer, model number and appliance type you need help with.
Feb 05, 2015 | Refrigerators
Recommend temp settings for Gallery
Hey friend, thanks for your post!
The recommend setting for your refrigerator is 0 degrees for your freezer and 37 degrees for your refrigerator. If your refrigerator has a water tank that holds the water prior to dispensing it then you would turn down your settings. I hope this is helpful. -Matt
Sep 22, 2014 | Frigidaire Refrigerators
Pool heater throws code h5? smoked
HS
Water Temperature Sensing Error
A) Inlet water temperature sensor is reporting a temperature in excess of 104 degrees.
Normal operation resumes 2 minutes after inlet water temperature sensor reports temperatures of 104 degrees or less. This error functions in both normal and remote thermostat modes.
or
B) Inlet water temperature sensor is reporting a temperature change at a rate faster than 6 degrees in 60 seconds, indicating a potentially damaging low water flow conditon. Normal operation resumes when temperatures stabilize. If this condition is detected 3 times, the heater will lock-out until the electrical power is cycled off and back on.
Jun 10, 2014 | Hayward H Series Pool & Spa Heater...
Water line frozen
water tank in bottom of fridge needs to be thawed out and temps adjusted so freezer is at 4 degrees above zero and fridge should be at 37 degrees
Jan 12, 2014 | Whirlpool GS6NBEXR Side by Side...
Overheats sitting
The radiator fan should come on at 220 degrees. You could bypass the fan relay to power the fan while you are driving until you can get the actual problem fixed.
Jun 03, 2013 | Honda Cars & Trucks
How can you fix a blackberry pearl with water damage?
remove the back cover and the battery and everything what you can remove,and dry it in the natural air,not with anything for drying,for example dry it in the sun.do not try to switch on a wet phone!only when it is dry!
Mar 20, 2011 | Cell Phones
Water filter froze solid
Your refrigerator compartment temprature is below 32 degrees and freezing your water in the filter. Adjust the thermostat setting to a higher temprature setting using a thermometer in the referigerator as a refrence. 34-37 degrees is a good temprature range to keep food fresh.
Jul 31, 2009 | Refrigerators
Water damage LG Shine
This may sound crazy, but it has worked for every phone me or my friends have had water damage to.
Take the phone apart as far as you can go (like take off the silver plate backing and take out the battery, and simcard) and place it on a dry rag and put it in the oven. Then heat the oven to its lowest setting. My oven can go as low as 175 degrees, so what I did was to open the top a little bit to let the heat out. Believe it or not, this heat shouldn't ruin the phone, but only dry up the water that is blocking the circuits. Be very careful though. The ideal temperature is about 125 degrees.
Considering water boils at 212 degrees, it SHOULD take more heat than than to actually damage your phone. Leave it in the oven, turned off, for 24 hours or longer. Give it some time... be patient. Then try turning it back on. It has worked for me and my friends, as of now we are 5/5.
Good luck.
Nov 24, 2008 | LG Shine KE970 Cellular Phone
Cell phone dropped in water - red dot showing - options?
you don't need to actually drop your phone in water for there to be water damage.
simple things like having your phone in the rain, in the bathroom while you shower, around a hot tub, or possibly even if it's really humid outside can set this water damage sensor off.
it just gives phone companies more ways to void your warranty.
hope this helped.
Sep 08, 2008 | Cell Phones
LG RUMOR Cellular Phone Logo
185 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
