Question about Acer Aspire 5100 Notebook
When I am typing my cursor will jump to another place on the screen and start typing there how do I fix this problem?
  • 400 Answers
Sir,
This is your Laptop's touchpad problem which might have got damaged sensor. This can be repaired but it would not work as smooth as new so I would suggest you to claim it warranty if not out dated or if so then do not get local repair but to contact the dealer of product.
Posted on Nov 17, 2009
Gateway HDMI laptop T series charger output 19 vgets v.hotbut works . burser pointer starts jumping frm place to place on screen dificult to control ?
run it in battery to see if fixes cursor problem
also try a different mouse see if that makes the cursor move correctly
this way you see if its the mouse or power supply
might also a touch pad problem anything that controls the cursor
May 07, 2015 | Gateway Computers & Internet
The cursor jumps from place to place as I type
This is a known issue in microsoft word. There is no fix as of yet but most people are moving their cursor to the bottom right of the screen after they have clicked where they wish to be typing. hope this helps
Dec 02, 2013 | Computers & Internet
My cursor in windows 7 keeps jumping all over the place when I type or try to click on an icon how can I fix it?
Swap out the mouse.
If there is a ball underneath, remove it and clean the X and Y rollers.
Oct 16, 2012 | HP Computers & Internet
My cursor jumps all over the place when I am typing. As I am in mid sentence I find that my cursor has jumped to another part of the screen then what should I do in this situation
Open the configuration panel (Classic view). Click on the mouse icon. Open the Cursor Options tab. Put a mark in the CheckboxHide Cursor during typing. You can also chek the box Show mouse cursor when I press thye CTRL key. You can also reduce the speed of the movement of the cursor. All these options are on the same TAB.
Jul 13, 2011 | Tablets & eReaders
My cursor jumps back when I type. I am not hitting the touch pad...help
You're probably having a jumping cursor where the cursor jumps from one place to another while typing an email or something. To fix this Go to control panel - hardware - mouse then look for the check box that you can tick on that says "Tap off while typing" and this should fix the problem.
Should you have any other questions just please leave a message.
Cheers~
Jun 25, 2010 | Dell Computers & Internet
Jumping cursor of a
Hi! I think youre probably having a jumping cursor where the cursor jumps from one place to another while typing an email or something. You may got to control panel - hardware - mouse then look for the check box that you can tick on that says "Tap off while typing" and this should fix the problem. Thanks for visiting FixYa.com!
Jun 04, 2010 | Dell Inspiron 1525 Notebook
My cursor jumps all over the place when I am typing. As I am in mid sentence I find that my cursor has jumped to another part of the screen and has started typing.
Your driver need to be update first,Reset everything default on Mouse settings, Then if NOT you need to see connector for Mouse internally.
Goodluck
JMC
Aug 08, 2009 | Fujitsu Siemens LIFEBOOK T4010...
Cursor jumps around
Does the cursor jump around when your hands are nowhere near the touchpad? The touchpads are heat and pressure sensitive. I personally have very warm (and sometimes sweaty) hands. I have this problem often when working on laptops. If I hover my hands over the pad, it causes the mouse to move. I've had to take a business card, put tape on one side of it, and use it as a flip-cover for the touchpad on most of my laptops. If the cursor moves around when you're nowhere near the laptop, then you may want to try disabling the pointing stick (if it has one). I've had several clients with laptops where the pointing stick mouse control go crazy and move and click on things.
May 13, 2009 | Dell Inspiron 1420 Laptop
Cursor jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
  1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
  2. Adjust the sensitivity of the touch pad:.
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
  3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
Aug 14, 2008 | Computers & Internet
Cursor jumps around
Try this software:
http://code.google.com/p/touchfreeze/downloads/list
Touch Freeze will disable the touchpad when you start typing. I have not used it, but give it a try.
Also, your touchpad could be wearing out or a driver reinstall could be in order. My wifes Toshiba had a bad touchpad and the cursor would jump all over the place. I disabled it and she now uses an external mouse. No problems anymore.
May 15, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5100 Notebook Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
