Question about Refrigerators
Magic Chef Top Freezer. Drain water from freezer not flowing thru drain tube into pan. How do I get to the drain tube.
    President:
  • 2,702 Answers
The best way to clear the tube is push a lenth of curten wire up the tube from the pan end,,, or blow through it with comprest air
Posted on Nov 17, 2009
Model No.ERF415M 13CT. I have ice forming underneath the bottom freezer draw, when I open the door it melts and runs out as water under the appliance.
drain is plugged up were it is normally drain to defrost the freezer completely find a place to store food in freezer for a few ours leave door of freezer open pull out all shelfs and lay a few tools down at bottom of freezer were you seen the ice build up after you have done that pull ref away from wall take back of bottom look fro drain pan with a turkey baster send water thru back of freezer inside if water still flows back out into freezer drain tube is still clogged use warm water when doing this if you see drain pan full of water use a shop vac that can deal with water suck out water send water again water should go strait to drain pan if still flows out may have to remove drain tube
Aug 23, 2011 | Daewoo Freezers
Magic chef model number CSB2323AR seems to be a defrost problem. Water accumulates at bottom of freezer then ices up. Is there a drain pan on this model?
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the lower right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Aug 07, 2011 | Magic Chef Refrigerators
Magic chef frost free refrigerator leaking water down the rear appears to be coming from the freezer compartment water puddles under veg. bin and then out onto the floor do not see a drain hole in...
Generally you have to remove the back panel of the freezer. There you will find the freezer coil and fan. the defrost water drips off the coil during defrost and gravity flows down thru the drain. Hole should be in center of unit. Those drains plug up. clear drain.and make sure panels go back on correctly
Jun 25, 2011 | Refrigerators
I have a magic chef refrigerator model # mcbr415sf. The top freezer part does not get cold enough to keep ice cream cold, but when you turn the temp up -- there is only one temp control and that controls...
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level
You can fix this by yourself and do take care in solving the problem......
May 12, 2011 | Refrigerators
I have a 6-7 year old Magic chef top freezer, refrig which is collecting water each day at the inside bottom of the box, refrigerator section. I notice that a slight drip of water comes thru the middle...
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Magic Chef CTB1821AR Top Freezer...
We have a Magic Chef CTB177GR refrigerator (no ice maker hooked up) that leaks...from where I don't know. I took off the lower back cover, it is dusty but no water present there. I pulled out the crispers...
Good day.
Water can only come from one place, where the frost is melted off the coil in the freezer during it's normal defrost cycles that occur daily.
Two styles. One style allows this condensed water to run down the back wall of the inside of the refrigerator, under the crispers and thru a hole in the bottom of the cabinet into a drain pan positioned
under the hole.
Possible missing pan, not positioned properly, or crack in the drain pan itself.
The other style drains the water to a hose mounted on the back of the machine, down and then into the pan.
Possible hose blocked, not connected properly, or the other items as described in first style.
It's a look-see type of repair.
Nov 17, 2009 | Magic Chef CTB1722 Top Freezer...
10 year old frige leaking water from the freezer onto the floor
drain tube is plugged the fridge goes into defrost about every 8 hours use a hair dryer to melt the ice and check the drain tube goes to the pan by the compressor
Jun 30, 2009 | Refrigerators
Magic Chef Side bye Side freezer started leaking
the drain line may be the problem. check to see if theres water in the bottom of the drain pan in the freezer compartment.
Mar 30, 2009 | Refrigerators
Magic chef fridge #ctb1722grq
Behind the panel in the freezer there is a drain hole that is underneath the evaporator.  It is frozen over.  Take the back panel off and get all of the ice out and run hot water down the drain until it is clear.  When the unit goes into defrost some of that ice melts and drips down thru the vent into the fridge section.
Oct 20, 2007 | Frigidaire FRT17G4B Top Freezer...
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
