Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
When we changed the filters in our ge smart water reverse osmosis system GXRM10G, we lost pressure and the water dribbles out and no longer flows. We only get a glass a day. What do we need to do
    President:
  • 3,433 Answers
Did you unwrap them? Remove clear plastic?
Posted on Nov 18, 2009
Water filter drain running all the time
Is this a new system? The should be a small restriction in the drain line. The size of the restriction is matched to the gallon per minutes of the R.O. system. Yours could be missing or not the right size, ie not enough restriction.
Jul 02, 2012 | General Electric GE SmartWater Household...
I have a GE smartwater reverse osmosis system model number GXRM10GBL02. Water leaks daily from the small hole on the faucet on my counter top. Any idea why water comes out that small hole? Otherwise the...
That is the drain for the reverse osmosis system. You have what is referred to as an AIR GAP faucet. The waste water is pushed up there before it goes to drain just as the drain for a dishwasher does. If water is coming out of the faucet the drain is most likely plugged or the line is kinked causing water to back up and overflow. Check the drain line for kinks and clean out the drain where it attaches to the stand pipe.
RJ
Oct 22, 2010 | General Electric GE SmartWater Household...
I am on a well system (submersible pump) and low pressure issues happened this week. Checked the pressure on Smart Water system and it was 45psi. I replaced the paper filter with a carbon filter cleaned...
This could be caused by several different issues. A faulty switch on the well, bad well tank, bad check valve. If you have a water softener, bypass it to see if pressure loss is through it. That carbon filter will cause even more pressure loss. Turn a cold water faucet on, let the well cycle several times and observe the cut-in and cut-out pressure. Typical well pressure pressure will be 40-60psi.
RJ
Jun 26, 2010 | General Electric GE SmartWater Household...
Low water pressure is diminished after replaced 2 filters in a month. plumber tested to see if water is fully flowing.
Does this mean that you are now having the right pressure? Since the filters are changed, water should
now flow. Is it all systems go?, that is assuming that
your pipelines are not clogged.
Nov 05, 2009 | General Electric GE SmartWater Household...
The water is not clear any more we have white residue in the kettle. We did change the filter and emptied the tank 3 times before insulting the new filters.
I don't believe that any filtration system is capable of removing dissolved calcium from water and that is what causes the white deposits. Water softeners will, but I don't like the idea of dissolved salts in our tap water.
Oct 24, 2009 | General Electric GE SmartWater Household...
Slow water flow from GE SmartWater under sink water filter.
I solved the problem! The system's manifold (the plastic base you put the filter in) has small black conical shape button. When you tight the filter in, one of the two small triangle-shaped cams (located close to the filter's central hole) pushes the manifold's button, and this opens the water flow. The problem is that the cams are too low and do not push the button all the way in. Take a pliers and squeeze (not too much!) the cams, so they will raise a little: it will be enough to push the button to open the flow completely.
Mar 11, 2009 | General Electric GE SmartWater Household...
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
623 people viewed this question
Top General Electric Water Heaters Experts
Paul Carew
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
