Question about Garden
My grow light was purchased used now it doesn't work
My grow light was purchased used a couple of weeks ago.I purchased a new 250 watt bulb so that is new. However, I finally go to use the grow light for the first time and it stops working less than 10 hrs later. The on switch on the side still lights up so it is getting electricity but the bulb does not light up anymore. Is there anyway to test what exactly went wrong with it and repair it on my own?
I assume the bulb goes back on when it cools down-if so i make the assumption that it has over heated ventilate bulb area more
Posted on Nov 18, 2009
Suggestion for Headlight Replacement
h4 head lights are normally 55/65 watts
head light brilliance is controlled by the condition of the reflector , the head light glass and head light alignment /aim
with the fitment of relays you can get up to 65 /85 watt bulbs but if the reflector is plastic then it will melt with bigger bulbs
May 26, 2017 | 1996 Lincoln Mark VIII
I bought two HB-4190 Hampton Bay Lights a couple of years ago. All has worked well until the past couple of months. THe light bulbs now burn out withing weeks. The bulb in one of the units keeps...
if lights are haligen lights, you may be adding to the problem, never touch them after you have removed the lamps, do not use your hands to install them, oils from hands cause them to burn out quicker, use a cloth to install them do not touch lights
Aug 16, 2011 | Home
400 watt grow light
ballast is weak ,or the bulb. i would never by the combo lights /use a hi pressure sodium for both vegative state and flowering.you dont necessarily need a MH..
Jan 03, 2010 | Garden
Picture cycles off and on
I replaced a burned out xl-2000u bulb with an after-market Philips bulb on my Sony KF60XBR800. After a fews weeks, I started experiencing intermittent black-outs with the "stand by" red light appearing. After a couple weeks it became intolerable. I then purchased an OEM Sony lamp and the problem has been gone for months. I read somewhere that the Sony circuitry monitors either resistance or watts and shuts the thing down for board protection. It was said that it is so sensitive it can can use only the Sony bulb. I'm a believer. If the bulb is going bad, i wouldn't doubt the protection circuit can kick in.
,,,,Pat
Nov 21, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Landscape ligthing Transformer
Yes ican. They are made to be split into two 300 watt circuits. So it's ideal to place it at a location in the middle of you lights . Basically to go each direction from the transformer. Now you need to find out what wattage bulbs are in each light.(different fixtures can have different watt bulbs.) Lets say you have 8 lights going one direction and 8 going the other way and each light has a 20 watt bulb. That adds up to 160 watts on each side. So you are well below the 300 watt rating per side. By the way I wouldn't go anymore than 250 watts on a 300 watt circuit. Next you look on the bottom of the transformer and you will see the screws where you hook up the wire. You will need to strip the end of the wires about a half inch. Hook one set under the A & B for one side then do the same for the otherside. Plug in the transformer and set the timer to whatever tme of day and night you prefer. Hope this helps. If you have more questions just ask. Thaks and remember to rate me.
Oct 21, 2008 | Garden
Growing lights Types
There are three major types of lighting systems available right now: incandescent, fluorescent, and high intensity discharge. Incandescent lights are horribly inefficient (especially the screw-in "grow bulb" type) and really not an acceptable option for plant growth. Although they are inexpensive to purchase, their cost of operation makes them the costliest source of light.
Aug 27, 2008 | Jump Start 4' Fluorescent Plant Grow Light...
Hid light output?
MH lamps are available in 175,200, 400 and 1000 watt sizes. HPS lamps come in 50, 75, 150, 400 and 1000 watt sizes. San Agro comes in 430w only, but it works with a 400w HPS ballast. Each lamp requires its own ballast, which comes with the fixtures that are designed to use these lamps, and are also available separately.
Aug 27, 2008 | Hydrofarm Agrosun Dayspot 60w Grow Light...
KodaK EKTAGRAPHIC MODEL E2 SLIDE PROJECTOR
You can use an ENH lamp which is 250 watts. it costs more (shop around- margins are high on lamps) but lasts an average of 175 hours vs the 300 watt ELH lamp at 35 hours.
You can also get ELH and ENH lamps from Wiko and Fuji in a "-5" version, ie ELH-5. It's built for 125 volts rather than the typical actual house voltage of 110-120 v. This allows them to burn much longer. There is a marginal lowering of light output in these forms.
Nov 25, 2007 | Office Equipment & Supplies
Sound, but no picture. Standby light blinking 5 times
A few weeks ago my set started flashing to a black screen. Now a couple of weeks later, i have no picture, but the set turns on and i have sound. The standby light is flashing. I purchased the set in 2000 so it is seven years old. This is the first problem. Could it be all three of the bulbs? Could it be all three of the bulbs? no as you say that sound is ok that means your power supply &high voltage section is ok. please check chroma ic luminance section or system control section stand by ckt ihanks
Sep 11, 2007 | Sony KP-53HS10 TV
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
