Question about GE JES1344SK Microwave Oven
I have two ge microwaves model jes1344sk02 that do not create heat, everything else works fine
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Spacemaker XL 1400 Microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 28, 2007
sharcnet
  • 2130 Answers
SOURCE: GE Spacesaver microwave model: JVM1653sf001
It could be the Magnetron. First, If the unit is out of warranty, you can try to remove the rear cover (make sure unit is unplugged) and see if there is a blown fuse in the section that powers the Magetron. If all the fuses are good, I would suspect a faulty Magnetron. The Magnetron is the microwave tube which makes the food cook. They are not too difficult to replace. MCM Electronics sells them and you can call them with your model and they can find a replacement for you will be able to see how much it will cost.
http://www.mcminone.com/search.asp?keyword=magnetrons
1-800-543-4330
Good Luck,
- Jim
Posted on Jan 24, 2008
rickzilla
  • 706 Answers
SOURCE: ge microwave won't heat everything else works fine
Hello t_sumner4756,
Everything else can work perfectly fine but if it doesn't generate microwaves to heat your food than it is not working ( you knew that anyway).. Unfortunately, and in most cases when you microwave stops working in that manner..the components at fault are either the Magnetron, Filament PS or a High Voltage Capacitor..What that means is that you are probably better off just replacing the entire appliance rather than attempting to repair it. If it is a year old or less, bring it back to where you purchased it and have them replace it.. I am sure that is not what you wanted to hear but when the cost to repair exceeds the cost to replace... it just isn't worth repairing.. Plus.. there is an element of danger associated with these kinds of repairs...
Regards,
Rick
Posted on Nov 22, 2008
  • 1214 Answers
SOURCE: Everything works except heat
Sounds like you've had a failure in the microwave portion of the unit.
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Posted on Jan 24, 2009
heatman101
  • 43501 Answers
SOURCE: MIcrowave doesn't heat up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fdyjhd
Posted on Sep 30, 2010
I have a GE Spacemaker Over-The-Range Microwave Model #JVM1533WD002 that has worked perfectly for 10 years. Now everything still works, except it doesn't heat the food. Where is the fuse located and how...
A common symptom of a failed magnetron is a failure to heat with everything else (magnetron fan, stirrer, timer, etc.) working fine. Check the GE manufacture date for the unit on its nameplate to determine the age of the magnetron. For GE models of the past, magnetrons had a 10 year parts replacement warranty. Magnetrons can be expensive, so you need to weigh all your options, i.e., repair versus replacement, before you commit to one solution.
Oct 04, 2013 | GE Spacemaker Over-the-Range Microwave
GE microwave model JVM1750DM does everything except heat food. Worked this morning fine.
Chances are the magnetron has failed, "heats food" the other possibility is the high voltage capacitor and diode. Repairs will approach the cost of a new microwave oven.
Apr 19, 2011 | GE JVM1750DM Microwave Oven
Microwave will not heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
l'l'l'l'l'l'l'l'l'l'l'l'
Aug 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE space saver Model JVM3670 - it is not heating up
Generally if everything else looks like it is working fine, then the magnetron has quit and needs to be replaced. The magnetron is the part that heats the food. Unfortunately, it is common for this part to fail on GE microwaves and it isn't worth replacing as the cost of the part is almost the same as buying a new microwave.
Let me know how this works out for you.
Benjamin
Apr 30, 2010 | GE Spacemaker JVM1750 Microwave Oven
Have ge sensor microwave model Je1660w
heatman101
62y
Apr 22, 2010 | GE JE1540 Microwave Oven
GE Spacemaker XL1800 Microwave No Heat
heatman101
yuetywe
Jul 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Mar 21, 2009 | GE JE1540 Microwave Oven
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Jan 24, 2009 | GE JE1540 Microwave Oven
GE JES1344SK Microwave Oven Logo
137 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
