Question about Maytag MER6772 Gemini Electric Kitchen Range
The ignition on the large burner has started clicking about every 5 seconds...stove not being used and all burners & ovens are off.
  • 15,935 Answers
Ignitor module relay is stuck.
Replace it to solve your issue.
Thanks for using FixYa
Posted on Nov 17, 2009
Burners turn on sometimes as does the oven but then may not turn off
Hello, when you turn on one of the burner, can you hear some clicking while you turn on one of the burners? This is an electric ignitor, and when you turn one burner on all the burner ignitor will click.
It is possible, that you are turning your burners on the stove to quick. Take a look at one of knobs and you will see ignition--low---medium---high. To get the burning ignited the knob needs to be position at the ignition site. You'll hear it click-click-click and the burner will ignite.
Now, the oven. The oven ignitor is on a time delay. You will push the bake button and across the screen will say something like this "Please set oven temperature" You'll set the oven temperature to---let say 350 degrees---. Then the screen will say "push start button" then you push the start button to turn your oven on. Now, the screen will say "pre" this means that the oven is pre-heating the oven to your desired temperature. Before all this happens there is ignitor in the oven and it has a heater on the ignitor in oven. This heater will heat up to desired temperature and once it reaches the that temperature the ignitor will ignite and the gas will turn on.
Why--one would say for this procedure. The old kitchen stoves had a very bad habit of of flash over---that is gas will built up in the over and once the pilot light ignited the gas---wussh and it blow the oven door open. These ovens would sometimes huff too.
Therefore, take your time and your biscuit will be OK
I am sorry Sandan2. I didn't finish reading your question. Never mind on what I said here.
If the burners will not shut off sometimes, then there could a gas regulator problem.
One very important question. Is your kitchen stove using Natural Gas or LPG--liquid Petroleum Gas?
If it is using either type of fuel as mention above. It is very important that you contact Appliance repair person that is certified by the state that you live in that he/she is license by the state to work with gas appliances.
I wish you luck, but it very it important that you contact a certified Technician... Also, move the stove away from the wall and look behind it. There a black gas pipe and at the end is a brass valve, Take wrench and turn the gas valve off. The gas valve will have a stainless steel flex line attached to it, and the other end is to your stove. Don't use your stove.
If those gas burners and the oven are leaking gas. There is possibility to blow you and your family with your home up. Don't use the stove, Until you have it check out...please. GB you/your family...stewbison
Sep 07, 2011 | LG LRE30755ST Kitchen Range
My old garland gas range, model J38H0, has 3 problems. one of the large burners only burns low, even when fully turned up, the oven won't light at all, and the other large burner ignites at the air intake...
Most likely the igniter is no good and does'nt get hot enough 2 start the oven. Check and make sure their is no blockage to the burners sometimes they get loaded with food and or dust
Sep 03, 2017 | Garland H283 Gas Kitchen Range
The electric panel on my smooth top stove just went out with a popping sound rendering the oven unusable but the stove top burners are working.............what could have happened and is it worth it to get...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 21, 2010 | Kenmore 95423 Stainless Steel Electric...
Dacor gas range. I'm trying to figure out why it
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 01, 2010 | Dacor Preference RSD30 Gas Kitchen Range
O'Keefe & Merritt Contempo Gas Stove Oven won't light
Probably needs the ignitor replaced. http://www.handymanwire.com/ubbthreads/showflat.php/Cat/0/Number/408747/an/0/page/332
May 24, 2010 | Kitchen Ranges
Stove top ignitors do not ignite but oven does.
Mar 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I have a kenmore gas range with electric ignitors. My question is that my stove top doesnt ignite but lets gas by and I can use a lighter to lite them. However my oven doesn't do anything...no gas no...
Nov 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven takes 5 minutes to come on (ignite).
Replaced the igniter. The parts guy told me that the amperage changes with age and use; thus the igniter still glows, but it takes much longer to operate the gas valve with the reduced amperage. Cost - $70.14
Oct 18, 2009 | Tappan 30IN ELEC IGNa Oven
Igniters will not stop clicking.
Hi
Thanks for using FIxYa.The igniter doesn't stop clicking due to a short inside the igniter circuit or due to moisture present on the ignition switch.Turn off the gas supply immediately and also unplug it from the mains power. Now take a blower or your hair dryer and blow hot air over the igniter. Also check for the following troubleshooting steps---
1) The gap between the igniter and the burner base is too large. *Should be approximately the thickness of two dimes.
2) Soiled igniter or burner base.
The above can be tested by switching the suspected burner with a known operating burner.
3) Loose wiring connections at the igniter, the grounding strap, or spark module.
4) Broken or pinched igniter wire between the burner and module.
Both of the above are physical inspections under the main top.
5) The module may have a week coil, which is not providing sufficient voltage to ignite the gas.
Even after performing these steps the igniter doesn't stop clicking then you need to replace the spark module.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 26, 2009 | GE Profile JTP18 Electric Single Oven
Gas oven won't light
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=53999&thid=358497
Gas oven won't light (by 2 users)
Posted by MBeird on Jan 18, 2008
Can hear the clicking of the auto starter when starting the oven, but it stops after 5 seconds and then the oven simply fills with gas. Broiler still works fine as do the stove top burners. Any thoughts?
Good question? You may have a plugged up burner and or the pipes or jets may not be adjusted correctly and it could be your igniter on the gas range because it is not igniting the spark to create the flame. You may want to have it check out with an authorized service repair tech to make sure it is safe and will function well. So if you need further assistance, please feel free to contact your local appliance dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don – The Appliance Man
Go Ahead. Use Us.
Jan 18, 2008 | Whirlpool SF367 Gas Kitchen Range
Maytag MER6772 Gemini Electric Kitchen Range Logo
26 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
