Blue line near the bottom of picture - Televison & Video
    Sergeant:
  • 295 Answers
If this is a CRT rear Screen TV then my thoughts is that there is an issue with your convergence board with the Blue signal.
A/V Media Tech Guy
Posted on Nov 23, 2009
Blue lines at the bottom of a coloured pictue I copied
try cleaning the print-heads from printers menu
you probably have a goggled print-head
Apr 27, 2010 | Lexmark X5150 All-In-One InkJet Printer
Red line across top/blue line across bottom of screen
Adjust your convergence. Under menu I think its the last choice at the bottom of settings or picture menu
May 05, 2009 | Sony KDF-50E2000 50" HDTV
Sony, tv comes on color fine, then turns red
I had the same problem with my TV, but the hue was blue. I was told that not only did I have to replace the picture tube that wasn't staying on, but I would have to replace them all because they would not mix properly. After much investigation, I found that there is an adjustment for a variable power supply to each tube that can brighten and lighten each tube. I adjusted the RED pot and my picture color issue was resolved! To access this adjustment you must remove the front panel on the TV. At the bottom corners there are two small screw covers that you must remove. Then un-screw the screws under the covers. Then pull the front panel off of the TV, (it hooks under the top near the screen so it will swing out from the bottom). Now remove the wooden panel in the center, (four screws). The pot adjustments are at the bottom of the TV. They are marked for Red, Blue, and Green. They are extremely sensitive, don't turn them much! If you over adjust you will get red, green, or blue lines on your screen. Adjust back down to remove these, (this is also the remedy for removing these lines that can appear over time). Good Luck and God Bless!
Mar 17, 2009 | Sony KP-51HW40 51" Rear Projection...
Thin red line appears on screen. Purchased Nov. 2007
the minute parts near the picture tube might have misaligned ,,,,,, you need to align those parts .... contact a good tv mechanic .... he will use a magnetic type material and align every minute parts correctly near the picture tube, the red line wont appear again
Mar 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Picture has a blue ring near the bottom
blue u ring? im interested ... please describe this part... outside inside. where exactly is this part
Jan 18, 2009 | RCA D52W19 52" Rear Projection Television
Tv is messed up
I got a question.
Do you have any stereo speakers anywhere near your television?
This sounds like something a magnetic field could cause from speakers being too close to the tv.
If so try to relocate them and see if the problem goes away.
Jun 15, 2008 | Hitachi 57SWX20B 57" Rear Projection...
Three curved lines have appeared approx. 6" up from the bottom of the screen. Is this a simple fix .... maybe as simple as replacing a bulb?
Are you saying that the whole picture is gone and all you see on the screen are 3 curved lines near the bottom, or is the picture there but 3 curved lines are over the picture, or is the picture there but the bottom of the picture has curved upeards?
Aug 23, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Television has no picture
That TV uses the PTK195 chassis, and the fact that you see only a thin line for each color near the bottom of the screen tells me your vertical output IC has stopped working, and is putting a small DC voltage across the yokes. I have seen this caused by a defective vertical output IC and I have also seen vertical problems caused by a small CRT coolant leak which drips onto the main board near the vertical output IC. If you do not have experience servicing the PTK195 chassis than have a qualified tech handle it for you.
Jul 12, 2007 | RCA P52937 52" Rear Projection Television
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
