Question about Viper Vehicle Parts & Accessories
Can you lock the viper 5301 keypad?
Can you lock the viper 5301 keypad to prevent accidentally starting your car?
Yes.
Press and hold Function (f) for 12 seconds.
Press and hold Lock for 2 seconds
(The keypad will light up)
If the green light by the lock button shows keypad lock on/off (no light).
Press lock- green light comes on.
Press and hold f for 2 seconds
Command entered
Press and hold f or wait 30 seconds for it to time out and the amber light turn off.
Posted on Nov 18, 2009
  • kiyorakasa Nov 17, 2010
    SYMPTOMS
    How do you activate the "Button Auto Lock" feature on the Responder LE 2-way transmitter and how do you use the transmitter once the feature is turned on
    CAUSE
    The "Button Auto Lock" feature is used to prevent unintended operation of the system by locking the transmitter buttons and requiring a specific sequence of button activations to unlock the buttons allowing operation of the system.
    RESOLUTION
    Press and hold the "function" button for approximately 10 seconds or until the amber transmit LED lights solid and the transmitter beeps once. Ignore the car number indicator at 3 seconds. Then press and hold the "unlock" button for approximately 1.5 seconds or until the amber transmit LED blinks twice then stays on and the transmitter beeps twice. You are now in the transmitter configuration menu. The "lock" LED will either turn on indicating this feature is already active or stay off indicating the feature is not active. At this point you can press the "lock" button to turn the "Button Auto Lock" feature on, ("lock" LED on) or off, ("lock" LED off). Until the transmitter exits the configuration menu you can continue to press the "lock" button toggling through the on and off settings. When the "Button Auto Lock" feature is on the buttons on the transmitter will automatically lock 60 seconds after the last button push. When the buttons are locked it is necessary to press the "function" button then the "unlock" button to unlock the buttons and operate the system. For a video tutorial, go here:http://www.youtube.com/watch?v=nJsJ9giAX...
    IMPORTANT NOTE
    This article requires a basic understanding of the installed system. Please contact your local Authorized Directed Dealer or Retailer if you require additional assistance.
    http://kb.directed.com/KnowledgebaseArti...
Vehicle will respond but not lock/unlock
reprogram the remotes by following the vehicles owner Manuel
if you can't get them reprogrammed then its dealer time.
Mar 11, 2014 | 5301 LE 2 Way Car Remote Starter System
Remote starter not working
Check to make sure the remote start kill switch isn't broken. There should be a switch under your driver seat or gas pedal that turns your engine off if someone tries to drive off with your car while you're warming it up. If that switch is damaged, it can trick your remote start system into thinking there's someone in your car, and preventing the system from starting up at all.
Dec 12, 2013 | Viper 5301 4202V Remote Start System and...
Horn does not sound when locked by viper 5301
??? Have u tryed a new battary. ???? is there a way to re program it ck online or call the DLR..
Feb 05, 2012 | 5101 LE 1 Way Car Remote Starter System
I have a Viper 5301. Just recently the blue light on the valet stopped blinking when the car is locked with the remote. It just stays on all of the time, no blink. At the same time, the remote started...
The blue light on solid means that your alarm is in the valet mode. Open any door, press lock, unlock, lock. This should put the alarm back into an active mode. Afterwards, check the system for normal operation.
Apr 14, 2011 | 5301 LE 2 Way Car Remote Starter System
When I have my keys in in my pocket, if i bend the wrong way of stick my hands in my pocket I frequently accidently start my car. Is there a way to lock the keypad so this doesnt happen?
sorry but there isnt. i do the same thing all the time. what i did to fix the problam is get a quick conect for my belt and put it on my keys.
Mar 05, 2011 | 5301 LE 2 Way Car Remote Starter System
I have a Viper 5301 LE 2 way remote starter system installed in a manual transmission. When I set my starter everything seems to be functioning normally. Once I get out of the car and hit the lock button...
It sounds like the turbo timer mode is active. In this procedure, the MTS remote starter is active, it's just that once set (after locking the vehicle) the vehicle will run the preset time(1,3,5 or 10 minutes) before shutting down. The MTS remote starter feature should still operate with the turbo timer mode.
Feb 08, 2011 | 5301 LE 2 Way Car Remote Starter System
Getting Viper 5301 to turn on heat fans in 2005 Mruano
Most likely only one of the cars 2 accessory circuits was powered up by the remote start. There definitely are 2 (red and white/blue). Please double check with multi-meter before just hooking up. But that should solve the no fan upon remote start.
Jan 29, 2010 | Remote Start System
How do I lock my keypad
there is a way to do it in the manual which can be found at www.viper.com/support.... i did it by mistake and now can't figure out how to turn it off
Apr 01, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper 5701 remote
read the owners guide look at page 11 remote control programing you have to follow the instructions after your in the programing mode go to page 12 look at the unlock symbol and finish the programing
Dec 21, 2008 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Vehicle Parts & Accessories Logo
3,663 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
