Question about Fujitsu Siemens LIFEBOOK T4010D Tablet PC
Problem with the pen
A friend has give me a LIfebook T4010D, but it hasn't pen, and I can not find it. I've try use the pc with other pen different and it doesn't work. It's neccesary that the pen was the original?? Where can I buy one??
  • 589 Answers
I don't recall if that uses a "special" pen or not. You can try re-installing the pen driver.
Here's a link to the driver support site:
http://support.fujitsupc.com/CS/Portal/supportsearch.do
Just choose "notebook pc" under "select product"
Then "T Series" under "select series"
Then "T4010D" under "select model"
You want the "pen driver / service" driver.
Good luck.
Posted on Jan 10, 2008
6ya staff
SOURCE:
I have windows xp,sp3 on a Siemens Fujitsu Lifebook T4010D. First of all, the tablet and the pen didn't work after installing the OS, also with all drivers installed. A few days ago, when xp was...
All of these drivers must be loaded;
LifeBook T4010D Driver Name Version Size (bytes) Audio V 6.14.1.3916 1,926,959 ACPI Device Driver V.1.21 9,437ACPI_Ext Device Driver (For model with Integrated Bluetooth) V.1.0 8,365 Bluetooth Device Driver (For model with Integrated Bluetooth) V.3.01.03F 15,615,696 Chipset V.4.30.1006 2,374,963 Fujitsu HotKey Utility V.2.30 1,119,189 Fujitsu Button Driver V.1.1.0126.2004 273,237 Fujitsu Button Utility V.1.0.0825.2004 976,478 Intellisonic V.2.0.1 4,077,455 LAN V.7.84.0.0 154,167 Modem V.2.1.41 883,675 MultiMedia Bay V.1.0.7.4 4,964,535 Radio Control (For model with Integrated Bluetooth) V.1.0 853,561 Smart Card Slot V.2.7.3.2 3,110,839 Security Panel Application V.1.2 3,653,534 TouchPad Mouse V.5.4.402.9 1,928,173 Touch Panel Driver V.1.03 22,505 TPM (For Model with Integrated Trusted Platform Module) V.1.7 17,542,125 Video V.6.14.10.3741 7,234,518 Wireless LAN Atheros (For 802.11a/b/g) V.3.1.2.21 3,980,525 Wireless LAN Atheros (For 802.11b) V.3.1.2.13
Jun 13, 2017 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
What is the height of the lifebook pen?
Getting bigger, staying small - the LIFEBOOK P1610 is more than only a notebook.
Rotate the brilliant 8.9 inch (1280 x 768 dots) display 180 to share your ideas or flip it over to convert your notebook into a slate Tablet PC.
May 30, 2011 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
My Fujitsu Siemens Lifebook t4220 is working fine overall. However my pen which was working fine will not function at all. Please advise on what I should do to ge it working again. Padraic.
Sounds like the pen packed up, they do that but normally become intermittent first. Without a source of another pen to determine the nature of the fault, may I suggest a modest solution.
A pen that will function and also be an acceptable fit in the slot is available on eBay, - See - # 140504970431. A good price, and an exceptional supplier. At least it will confirm a pen or a screen problem.
Should you have an original (or copy), of the System Restore disk, I would appreciate you getting in contact, mine got trashed. Paul W.
Jan 05, 2011 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
Fujitsu Seimens T4010D Life Note Book
Have you tried to remove the screw thats connected to the Video connector as well. It is a hexagon shaped screw.
Jun 04, 2009 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
Keyboard Jiberish
It could also be the logic board. Usually, there are weep / drainage holes in the bottom of the laptop. See if there's any traces of moisture there, and you'll know if it got wet or not.
Sounds like it could have been wet. You could try replacing the keyboard.
May 19, 2009 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
Fujitsu Siemens LIFEBOOK T4010D Tablet PC Logo
566 people viewed this question
Top Fujitsu Siemens Tablets & eReaders Experts
NOEL
NOEL
robert
Bill Boyd
Are you a Fujitsu Siemens Tablet and eReader Expert? Answer questions, earn points and help others
