Question about Coleman Powermate Premium Plus 6250W Portable Generator
I have a coleman powermate 6250-5000 running watts-generator. The generator starts and runs but does not produce current to outlets,the outlets are fine-they have continunity,I removrd the armature and coil-a little rust there,I cleaned the rust and wiped the laminations ,put it back together and still nothing, the fuses are ok also
  • tomasbrown35 May 11, 2010
    I used sand paper { fine }, on the tip of the brushes and the plate they make contact with. Thank you for the trouble shooting tips.
  • Rocco Tallaksen May 11, 2010
    Is it capacitor excited or does it have a voltage regulator?
  • 37 Answers
You may have just lost residual magnetism in your rotor. Start genset then apply 12 vdc to 120 v outlet for less the 1 seconds. This will be enought to restore the residual magnetism to the rotor and the unit should be producing power now.
Posted on Nov 18, 2009
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
Coleman generator #PM0497000.02 generator starts well and runs smoothly, yet I have no electrical output. I have purchased replacement brush modules, but am unsure as how to re-excite the unit. The...
You have to get a cord that has a plug on on it. On the other end of the cord strip the insulation off the ends of the wire about an inch. It would be easier if you put small clamps on the stripped ends of the wire. Connect the black wire to plus on a car battery and white to negative. Start the generator and plug the cord in to a outlet on the generator just for a second and take the plug out. The generator should now be producing electrical current. If not there is something burned out internally.
Mar 11, 2011 | Coleman Powermate 7,000 Watt 13 Hp...
Starts fine...no juice....sat for 10 years in the box...started using it 3 weeks ago...worked fine until yesterday....starts...runs..no juice...no circuit breakers blown...what's up?
Colemans were known for losing what is known as "residual magnetism", especially when sitting for long periods of time without use. This residual magnetism is necessary for exciting the field to produce electricity. Here is what you can try: Plug a 110v drill into one of the 110 outlets. While the engine/generator is running, with an open hand (not fingers wrapped around it) spin the chuck while holding the drill trigger in the run position. Many times this small amount of current that will be produced by spinning the drill motor will restore the residual magnetism and excite the field. Keep in mind that if this works, the drill motor will begin to spin immediately since it is plugged into the outlet. Hope this helps.
Mar 04, 2011 | Coleman Powermate Powermate 5000W...
My coleman 5000 generator with a briggs & stratton engine started just fine after years of colecting dust in the shop. After we let the generator warm up we applied a load and found out there is no...
Without knowing the exact model generator you have, it may not even have an automatic voltage regulator (AVR). Colemans were known for losing what is known as "residual magnetism", especially when sitting for long periods of time without use. This residual magnetism is necessary for exciting the field to produce electricity. Here is what you can try: Plug a 110v drill into one of the 110 outlets. While the engine/generator is running, with an open hand (not fingers wrapped around it) spin the chuck while holding the drill trigger in the run position. Many times this small amount of current that will be produced by spinning the drill motor will restore the residual magnetism and excite the field. Keep in mind that if this works, the drill motor will begin to spin immediately since it is plugged into the outlet. Hope this helps.
Feb 24, 2011 | Coleman Powermate Powermate 5000W...
Generator runs, but doesn't produce electricity
Manuals and part lists:
http://www.powermate.com/productmanuals.php?cat_id=3
Contact information:
http://www.powermate.com/contact.php
Mar 20, 2010 | Coleman Powermate Premium Plus 6250W...
I have a Coleman Powermate 6250. Runs Great, No power to outlets!
Excite the genset.
with the gen engine running,
1) plug a 3/8 drill into an outlet,
(make sure the drill is set to the forward rotation)
2) hold the trigger in the run position
3) by hand, rotate the drill chuck with a quick flip of your wrist.
*** NOTE: BE PREPARED !!! this will excite the gen-set and the drill will start to run as normal.
Oct 07, 2009 | Coleman Powermate Premium Plus 6250W...
Engine runs but won't generate any electricity
Sometimes the generator loses the magnetic field that allows it to produce power. Do a Google search on "flashing a generator field". There are many ways to do it, but I would recommend doing some reading before trying it. Your "dead" generator could produce hazardous voltage once it comes back to life.
Also, before trying any of this, make sure the circuit breakers on the generator (if equipped) are not tripped.
Good luck and be careful!
Jan 19, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Coleman Powermate 5000 no electricity, runs fine
Hello;
Take a look at your outlets. Some of these units use pretty cheap outlets and short out. You will know if it is bad when you look at it. Hope this helps.
Thanks;
Rich
RPM Northwest
Jan 16, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
784 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
