Question about GE Spectra JGBP35 Gas Kitchen Range
I have two burners that don't ignite
I have an GE Spectra XL44 gas stove with two burners that don't ignite and I want to open the top portion of the stove and check it out myself but i don't know how. Please help
  • 491 Answers
FIRST MAKE SURE YOU TURN OFF THE GAS AT THE MAINS , THEN REMOVE THE ALL BUNERS AND GIVE THE TOP PORTION A GOOD CLEAN WITH WARM SOAPY WATER TO EXPOSE THE SCREWS WHEN LOCATED REMOVE THEM AND THE TOP THEN YOU NEED TO FIND THE IGNITE WIRE FOLLOW IT TO ITS SOURCE CHECKING FOR ANY BREAKS AND ALSO CHECK CONNECTIONS . GOOD LUCK .
Posted on Nov 17, 2009
Testimonial: "Thanks so much, but now I'm a little scared, plus i don't know where the gas valve is. i think i will have to call a repair man."
    Problem Solver:
  • 8 Answers
We had two that stop working also. If we used a lighter to light it then it would work. We had pots boil over. When the repair man came over to tell us we need a new control panel he fixed the burners. I would call a repairman to be safe.
Posted on Dec 10, 2009
Ge Spectra Xl44-three of 4 gas burners will not ignite without a match.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 19, 2010 | GE Spectra JGBP35 Gas Kitchen Range
Xl44 GE GAS RANGE OVEN WONT WORK, RED LIGHT IN
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
czvb
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge xl44
there is switch behind the knob it most be wet or it needs to be replace they are call,top burner valve switches. white in color plastic.
Nov 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE spectra xl44 not work
I have the Ge Xl44 stove the burners and broiler work fine but the over will not heat up. How can I resolve this problem?
Jan 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 Gas Stove
Hi I have a GE X44 gas stove. The 4 top burners work just fine, but the oven no longer turns on. I don't see the blue flame inside the oven. Is it safe to relight the pilot light?????
Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra JGBP35 Gas Kitchen Range Logo
525 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
