Question about Photography
Can't remove film cassette from Canon IXUS M-1. The film has rewound (I think) but the film cassette stays jammed inside the chamber.
  • 571 Answers
The cassette needs to be lifted a bit to be able to tilt it out.
Posted on Jan 11, 2010
APS film chamber stuck shut. Door won't open when film chamber release button is pressed
Sorry to hear about this issue. If you have a change bag, I would put a few jewelers screwdrivers in it then put the camera in it. With the bag closed up I would attempt to forcibly open the back. With the camera in the bag there is not any chance to expose the film. After the film is removed wind it back into the cartridge. Now send it off for developing.
Good luck,
Cordially,
May 03, 2014 | Minolta Vectis S-1 35mm SLR Camera
Film will not fully load
On many of the film Rebels, mine is the T2, the film is completely unwound. As we take pictures the film is rewound in to the film cassette. That is a film safety feature. If the back if the camera accidentally opens we only expose unused frames. The frames we took are safe in the cassette.
Cordially
Feb 11, 2014 | Canon EOS Rebel 2000 35mm SLR Camera
My shutter got stuck at 14 frames.i wound it back but want to go back to the 14th frame,will this ruin the pictures i have already taken?
Could be that when the load builds up there is friction to jam the film. You must not take chance with the shot film and so try to click with the cap on the rewound portion and if the film is not advancing then it is possible that the camera must be checked with a dummy film to confirm on why the jamming takes place.It can be also due to failure of the loading mechanism
Mar 17, 2012 | Canon EOS-AE-1 35mm SLR Camera
The film ripped from the cassette on a contax rts when i was manually rewinding it. is there any way to salvage this at home? also, what is the best way to remove the film from the camera, without damaging...
before opening the camera, press the film rewind release button and ensure that the portion of film which remains attached to the cassette has been totally rewound. Next, with the camera in total darkness, open the camera back and remove the film cassette. Grab a firm hold of the loose end of the torn film and tape it to a piece of wooden dowelling and then turn the dowelling so that the film pulls out and winds onto it. Once the film has disengaged from the camera, place the dowelling with the film into a totally light-proof container: an old but spotlessly clean metal tin, such as a custard powder, cornflour or even a paint tin will do the job. Don't use a plastic lidded tin as the lid is always slightly translucent and will fog the film. When the tin lid has been firmly closed with the film inside, you can take the tin to a specialist processor and get both film portions developed.
Note that specialist handling of this type regarding development is not cheap. You cannot use a regular postal processor or minilab as their machinery cannot handle damaged film, only a professional lab (or a well-equipped friend) can individually process your film. Bear the cost in mind, as it's only worth doing if you are sure that there are valuable/irreplaceable images on the film.
Also note that by pressing the rewind button before pulling out the film, you are largely using the camera as intended so will not damage it. Afterwards, check the camera thoroughly and clean out any broken film fragments.Torn film is sometimes down to a manufacturing defect in the film, or due to the rewind button popping out during rewinding, or rewinding much too fast or due to excessive resistance in the take-up mechanism as the film is rewound; the latter usually indicates that the camera is overdue for a professional CLA (Clean, Lubricate, Adjust) service. The fault may commonly be due to a combination of those factors.
Sep 13, 2011 | Contax RTS II 35mm SLR Camera
My Canon AE-1 Program will not rewind. I shot the whole roll, rewound a little, and then accidentally opened the back cover. The counter reset to S, and the rewind crank just unscrews when I try to...
I think you have already ruined the film except the frames that are rewind back to the film cartridge.
You can take the film out from the camera, push in the rewind button at the bottom, pull out the film from the film take up reel.
On the film cartridge, turn on the long tube in the middle clockwise to wind all the film back into the cartridge.
If you had the back opened briefly, do manual film rewinding in the dark room.
May 21, 2010 | Canon EOS-AE-1 35mm SLR Camera
Film has not rewound but has 'reverted' to showing
On the toplate of the camera, to the left hand side, is a button which slides to the left. It is marked with a film cassette outline, and two arrows to the left <| <|
At any time, you can use this button to rewind the film back into the cannister. It should make a whirring noise for 5-10 seconds, and will stop automatically.
If it makes no noise, you may have a flat battery, or the film may already be rewound.
You can insert new power (battery) without affecting the film cassette, if need be.
However, if really unsure, then:
1) Slide the rewind button to rewind(i.e. to the left).
2) Familiarise yourself with where the back opening latch is.
3) Go into a pitch black room. Preferably under a quilt in a pitch black room.
4) Open the back and take out the cassette. If it comes freely, its probably fully rewound. If its still attached to the take-up spool by film, then (holding the film by the edge only) pull on the film to release it slowly from the take up spool. Whilst it can be quite a tug, they are designed to let go of it "under protest". (Do not pull it so hard that you strip the gears, but fairly firmly).
5) Using the spool winder on the top of the cassette, wind the trailing film back into the cannister. If you've never seen a 35mm cassette, then in the dark one end has an elevated round part, the other end has a void into the cassette. You can tell the elevated part, and start winding - it should only wind one way and feel like its winding onto the reel (wind the other way and it feels like its unwinding - even in the dark!)
6) Only when you are sure film is in the cannister, can you turn on the light.
Films are very sensitive to light, so if you do not feel comfortable doing this procedure in total darkness, go to a photo processing store who will do this for you, usually for no charge (other than the hope you'll let them process the film). They put your camera in a sort of black pillowslip, but the procedure is the same.
Hope this helps
Jan 20, 2010 | Olympus SuperZoom 700BF Film Camera
Can't open vivitar 5388
Use the rewind knob to rewind the film. Once the film is rewound, lift the knob up and the back should open. Then you can remove the film cassette and insert a new cassette and load the film.
Jun 11, 2009 | Photography
Minolta maxxum 5 jammed film-chamber lock
i just found it after looking at the manual again. it didn't work for me but maybe it will work for you.
go to http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/dynax_5/dynax_5_inst_e.pdf
and page 61 (actually page 121 of the manual but page 61 if you type in the page at the bottom of acrobat reader).
when i tried this it made the noise that it wanted to unlock but it didn't.
good luck!
~gobygirl
May 11, 2008 | Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
N55
Go digital- Seriously Take batteries out and clean the contacts in the base of the chamber with the eraser on the end of a pencil and clean the cover contacts remove the cassette and reload Then try- but if it is automatic and has died then a repair option may not be possible because of lack of parts unless there are secondhand ones to be had and the cost could be big bucks
Jun 13, 2007 | Nikon N55 35mm SLR Camera
The film automatically loads then rewinds when a new film canister is added
Hm. Well, the way this camera works is actually very clever. When you first load a film into it, it winds the entire film out of the cassette and into the camer. As each shot is taken, the film is rewound back into the film cassette. The advantage of this is that if the back of the camera is accidentally opened, the shots which have already been taken are already safely back in the film cassette and will not be damaged by the light ingress. However, your camera is behaving strangely. I would check that the electrical contacts where the film cassette goes in are clean. You can clean them using a cotton bud moistened with methylated spirits.
Apr 13, 2007 | Canon EOS Rebel G 35mm SLR Camera
Photography Logo
108 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
