Question about LG ALLTEL AX275 Cellular Phone
Screen is garbled and i can't read it. sometimes
Screen is garbled and i can't read it. sometimes it rotates sideways and the text, etc. is backwards - like you're looking in a mirror
How do hummingbirds fly backwards
A hummingbird can rotate each of its wings in a circle, allowing them to be the only bird which can fly forwards, backwards, up, down, sideways or sit in sheer space. To hover, hummingbirds move their wings forward and backward in a repeated figure eight, much like the arms of a swimmer treading water.
Hummingbird Facts at Hummingbirds Forever
Feb 18, 2015 | Citrix UPG PRES SVR PLATINUM ED FR/ ENT...
Touch screen not aligned correct
Do you mean the onscreen text or pictures don't rotate when you turn the tablet sideways? If so, on the Home screen tap Settings, then scroll all the way down the settings past the bottom of the screen. Near the end of the list is Accessibility. Tap that, and then in the System section be sure there's a check in the box next to Auto-rotate screen. If there isn't, tap the checkbox to put one in. Then press the back arrow till you're back at the Home screen, and when you rotate your tablet the pictures and text should remain horizontal.
Mar 16, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
Scanning is backwards
I just got my scanner yesterday and had the same problem with my FIRST jpg. I looked for a solution and found your posting. I had scanned one page of the instruction booklet from the center fold outwards, not in the direction of the text, but rather sideways across it. That image was mirrored. I did another scan in the 'proper' direction, that is, from the top of the page to the bottom, both as a jpg and a PDF and they came out in a normal, readable form. Perhaps you need to do it a few times if you haven't already? Have you tried calibrating it?
Jun 20, 2013 | PANDIGITAL PANSCN08 Handheld Wand Scanner...
Cant get phone to turn sideways for texting, internet or pictures.
Check under your settings to see if you have the screen orientation option turned off.
-go to Settings > Sound and Display > Orientation
-Orientation should be checked if you want to be able to rotate the screen
Good luck.
Jun 07, 2010 | HTC Hero Smartphone
Sideways screen
Press [CTRL]+[ALT]+[UP ARROW].
Feb 25, 2010 | Computers & Internet
The monitor display is all jumbled up; each text line is split
Try putting a video card in it. The screen is most likely garbled because the onboard card is not working correctly.
Dec 26, 2008 | AOpen MX36LE-UN (91.89Q10.101) Motherboard
Monitor screen displays sideways
if the screen is rotated then press
ctrl + alt + up arrow
your screen will be placed correctly
this is happened because sometime you might have pressed by mistake ctrl + alt + some arrow key .....
the hot key will be enabled defaultly so your screen got rotated
Jul 05, 2008 | Gateway FPD1950
LAPTOP PROBLEM
hold down alt & ctrl keys and press the up arrow and that should sort it out
Mar 16, 2008 | Computers & Internet
Ramiden 9000 dell lattitude d600
Linux and UNIX wget command help Another instance where you'll get a garbled file if you try to use -c is if you .... The same goes even when several URLs are specified on the command-line.
Good Luck, Read and follow instructions.Please dont for get to Vote/Thank You.
Dec 22, 2007 | Dell Latitude D600 Notebook
LG ALLTEL AX275 Cellular Phone Logo
116 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
