Question about Oster 12-Bottle Wine Cellar - Black
Dose not run or cool. Red light appearsat back.
Dose not run or cool. Red light appearsat back. Used only 40 to 60 days.
  • johnmstorms Nov 17, 2009
    I'll have to work it through. I'll let you know.
  • 3,741 Answers
First of all check the fuse on the main board
The fuse is on the circuit board covered with a black tube. It looks like a upside down "U" on the upper left hand side of the board, next to a copper coil. (The shrink tube keeps the fuse from shorting out with the copper coil.) It is not the fuse on the lower right that you can easily see. It is not easy to find this 5 amp fuse because its covered in black plastic (heatshrink), and is soldered on to the circuit board. There is another glass fuse that's easy to see, that is not the one. check the continuity of both the fuses and find which is blown out. remove the fuse by locating the connections for the fuse on the back side of the circuit breaker and heating the connections with a soldering iron. pick up an in-line fuse holder and a 6.3 amp 5x20mm fuse at Radio Shack and soldered it in place. will have to make the holes on the circuit board a tiny bit larger to fit the fuse holder in. a 6.3 amp to 7.0 amp fuse is perfect. The 5 amp was definitely too small.
but if fuse is not blown then,if you hear the compressor turn on but not the fan, replace the fan and you may have to defrost the evaporator coils. if the compressor does not turn on either, it's the thermostat, the defrost timer, or a relay on the main board.
if you are not familiar with doing this you can get it done by local repair technician familiar with this. its a easy and normal fix.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Nov 17, 2009
Powers on, then powers off, have red light, then blue lite ,then back to red light.
Do a firmware update. The fault is due to corrupted firmware. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 15, 2015 | Westinghouse Televison & Video
HUMIDASTAT INTERNAL RED LIGHT USED TO BE ON AND UNIT WORKED. LIGHT STAYS OFF AND UNIT DOES NOT WORK. WHEN I DISCONNECT AND REATTACH HUMIDISTAT POWER LINES, RED POWER LIGHT GOES ON FOR A SECOND AS DOES THE...
will not blew very good heat and shut down with stop light came on it dose work for 30min after i drain the water but it go back to the stop light again then the will for about1min or so then it shut again
Nov 04, 2013 | Aprilaire 4655 Manual Humidifier...
My cirrus 99 is knocking when at a certain speeds 40,60 mph, when about to stop ?
problem is electronic but exactly what i have no idea without my head under the bonnet ,try the dealer as it may be cheaper in the long run
Jun 13, 2012 | 1999 Chrysler Cirrus
2007 CHEVY COBALT CHECK ENGINE LIGHT IS ON AND THE FAN IS CONSTANTLY RUNNING
this is normal for most vehicles, it is because the water temp in radiator continues to rise after you shut the engine off. would not worry about it unless it dose not shut off at all. or never runs
Jun 11, 2012 | 2007 Chevrolet Cobalt Coupe
A lot of red in pic no matter what we do and tint dose not change anything
As is typical with all Philips projection sets the cooling fluid has become contaminated in the blue and green picture tube assemblies. The red is almost never affected with this as whatever bacterial growth is discoloring the fluid in the blue and green tubes can't seem to survive in red light. The blue and green light is shining up through muddly cooling fluid and that is why the red is predominating. A reputable tv repair shop can pull the tube assemblies and dismantle them and clean and reassemble and refill and do all the necessary adjustments for around $300 to $400.
May 26, 2009 | Philips Televison & Video
Red light when i power up
if Xbox contact info is
1-800-4MY-XBOX
International (direct dial to U.S.): 425-635-7180
Hearing Impaired (TDD device): 1-866-740-9269 or 425-635-7102
Hours of operation (every day):
9:00 A.M. to 1:00 A.M. Eastern Time
6:00 A.M. to 10:00 P.M. Pacific Time
And a cable is most likely unplugged or you have the red ring of death try unplugging all the cables and then putting them back after 30-60 min.
if PS3
Contact info is 1-800-345-7669 (SONY)
Mon - Sat 6:00AM - 8:00PM PST
Sun 7:00AM - 6:30PM PST
If the power indicator on the PLAYSTATION®3 is flashing red and green alternately: Back to top
  • The interior of the system has become unusually hot. Check whether the system is being used in a hot location or whether the vents are blocked. Stop using the system and leave it unused until it cools down. Continuing to use the system in the above condition will cause it to stop functioning.
If the power indicator is flashing red and the system does not operate: Back to top
  • The temperature inside the system has risen too high. Check whether the system is being used in a hot location or whether the vents are blocked. Touch the system's power button to stop the flashing, and then leave the system unused until it cools down. After it cools down, turn on the system again.
-Rel
May 29, 2008 | Video Game Consoles & Games
Xbox360
Is the it the power supply red light?
The red light may indicate that the power supply is too hot or is overheated. Therefore, you should let the power supply cool for several hours in a well-ventilated space. During this time, you should not try to turn the console back on to allow the power supply sufficient time to cool. As soon as the power supply has cooled off, the power supply light will change from red to orange, and you can turn the console back on.
If the power supply light is still red after you have let the power supply unit cool in a well-ventilated space, the power supply unit may require replacement.
Also make sure the power msupply is plugged in correctly.
You could also purchase a new power cord.
Good luck
Mick
Nov 04, 2007 | Video Game Consoles & Games
Oster 12-Bottle Wine Cellar - Black Logo
326 people viewed this question
Top Oster Furniture Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
jasbo
jasbo
Charles T Nevin
Charles T Nevin
Are you an Oster Furniture Expert? Answer questions, earn points and help others
