Question about Baumatic F60 Stainless Steel Kitchen Hood
Where can i buy new Baumatic 7.3 GL cooker hood halogen lights at a good price
  • 491 Answers
FIRST TURN OFF THE POWER TO THE HOOD UNIT THEN LOCATE THE BULBS AND REMOVE TAKE THEM TO THE LOCAL DIY STORE TO FIND REPLACEMENTS IF NOT FOUND THERE YOU CAN GO TO AN ELECTRICAL AND PLUMMERS SUPPLY STORE , GOOD HUNTING.
Posted on Nov 17, 2009
How do I fix the downlighters on my cooker hood?
sounds more the the switch has failed you
Mar 06, 2016 | Baumatic Kitchen Ranges
I have a Baumatic ISL94SS and want to replace the 4 hologeen G4 lights (20W)for Led G4 (2W).
These appear to be quite available:
Amazon com g4 led
While I don't have your Baumatic, I've replaced dozens of halogen and incandescent lamps with LEDS. I've also used LED striplights to replace fluorescent tubes.
Aug 27, 2015 | Baumatic Kitchen Ranges
Instruction manual KuKoocooker hood light bulbs
Just look this youtube video, and it can't be more clear.
Don't forget to unplug the hood, or switch it of. Although the halogen lamps are only 12 volt. In the hood are dangerous voltages. How to replace cooker hood halogen bulb or lamp
Sep 22, 2014 | Kitchen Ranges
Rangehood lights not working
I have a Fabyka Range Hood and know three other people who have had this exact problem (i.e both lights go out simulatneously but fan works fine). In my case I was able to pin it down to the transformer used by the halogen lights. This is an electronic transformer so it is less tolerant of power surges and such.
In the case of Fabyka the transformer is a black box connected to the inside of the hood with sticky tape with a black and white wire and two red wires. It is only used for the lights.
It is connected to the AC power via a black and white wire. you can disconnect this and us an LED power tester (about $2-$5 at most hardware stores) and see if you have power when you hit the switch.
In my case it is a 70W 120v to 12v halogen transformer. You can by a replacement off Amazon for about $12 including shipping or you can by a new one from Fabyka for about $30. I would suggest getting a slightly higher wattage transformer (I bought a 105watt for a dollar more).
You will need to disconnect the power before replacing but it is an easy fix.
1. Disconnect the AC power connector (black and white wires.)
2. The red wires coming out are the 12volt lines. If there is a connector, you can disconnect this, if not, you may need to cut these off.
3. Pull the tranformer off the back of the inside of the hood.
4. Cut the connectors off the old transformer. (Unless you buy Fabyka's.)
5. Connect them to the new transformer using wire connectors or crimps. (Make sure you connect black to black, white to white, and red to red.)
6. Make sure you have no exposed wires.
7. Connect to the corresponding connectors inside the hood. Connect the AC connector last.
8. Verify that the lights work properly.
9. Use sticky tape (or Gorilla tape) to attach the connector to the inside of the hood.
10. Enjoy the light.
Jul 17, 2009 | Kitchen Ranges
Baumatic cooker hood lights not working
take the bulb out and bring it with you to store and see if you can find one the same . DIY stores have tons of types.Joe
Nov 16, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
Belling cooker hood chim101 BL - light/ lamp
I just had this very same problem and believe I have solved it!
You can remove the entire light unit from the hood. On first inspection it appears to be a sealed unit that does not allow you to remove either the wires or what looks to be a regular halogen bulb. If you turn the unit so the bulb is facing you, you can gently prise the glass from it's housing leaving the naked halogen bulb exposed beneath it. You can gently pull this from the housing and buy a new one to replace it. I would advise that when installing the new one you make sure it is completely free from any contaminant as any grease etc can greatly reduce the life of the bulb. Hope this helps!
Nov 04, 2008 | Kitchen Ranges
Halogen Lights Failing
I had the same experiences with my lights. I placed a 50v bulb and it blew the fuses. The fusees located on the right side of the bottom duct cover. use 5a 125 v fuse GE part # wb27x10542 but you can find a cheaper fuse at Radio Shack. Good luck
Mar 28, 2007 | GE Monogram ZV1050SFSS 42" Island Chimney...
Baumatic F60 Stainless Steel Kitchen Hood Logo
165 people viewed this question
Top Baumatic Kitchen Ranges Experts
Greg Cann
Greg Cann
Vitaliy Gins
Vitaliy Gins
Treefrog15
Treefrog15
Are you a Baumatic Kitchen Range Expert? Answer questions, earn points and help others
