This tv has worked very well for five or six years and now has developed an intermittent problem.
When left on for some time (over an hour) it starts to flicker. This becomes more frequent until it is impossible to watch. The repairers at first thought it was a loose connection and did some soldering but it remains a problem and they have given up with it. They say it is not worth the man hours trying to locate what is probably just a loose connection.
The flickering is about 3 or 4 inches from the top of the screen and the tv actually turns itself off and then on again after a second or two.
Any advice would be helpful. Should I just get a new tv - shame because its a great picture.
SOURCE: Mitsubishi VS-5041 50 Inch Rear Prorjection TV No image but there is sound!
After 11 years???? OMG This set is a tired pup and should be put to reast. My experience with older sets and your complains are all capacitor problems and is only gonna get worse as the first time around repair will take several capacitors to repair. This set has no user serviceable parts inside so you should not attempt a repair suchj as this on your own.. This repair if you decide to go through the first time will be About 300 to 600 bucks the first time and cost will continue to raise till the sets put to sleep. Good luck
SOURCE: losing picture and sound
It needs a new bulb, same thing happen with me. jut get a bulb for this model and change it. if you call sony service, it will cost you about $500.
SOURCE: my tv screen goes green and then turns off by itself
I connected a digital set top box last night and it screwed up my RCA 31" tv. It now has a green screen and is permanently damaged. Pretty hard to belive but painfully true. Anyone else?
SOURCE: blue vertical stripe
The bad news, it sounds like tou have a bad plasma panel.One of the vertical drive arrays are in the process of failing.This part is part of the display panel.
SOURCE: LG LST-5100P set top box. Several times a day have
cap-grant, my friend has the same problem with set top box. When I phone maker I was told it is due to poor and weak signal. You must have 80% signal strength to maintain good picture. When signal strength dropped picture would freeze and had to be turned off at the power point to restart as nothing would work. So I guess what my experience says is you may need better aerial to boost signal and prevent dropout Leonard210
Visit this site for more details. Type in the site name Electro-help either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
Picture of line output transformer is given. It may look different from this picture, but remble most.
This is the picture of Line Output Transistor.
