Question about Kenmore Dishwashers
Stuck in drain cycle - Kenmore Dishwashers
  • juris853 Nov 18, 2009
    I did as you suggested. Turned the power off overnight. pressed other buttons to drain the electricIty. It did not reset. What next?
  • 11,896 Answers
Sounds like a control board issue.
Try unplugging the unit for few hours, press couple buttons to drain power completely from the system. Plug back in and see if the machine resets itself.
Posted on Nov 17, 2009
  • Nate Stansfield
    Nate Stansfield Nov 18, 2009
    If the machine did not reset, then the control panel is faulty and will need to be replaced. You can get parts, diagrams, manuals and more at repairclinic.com or partselect.com
    This is a common problem now days. You can pull the panel and test the wiring with an ohmmeter to see if there is readings when you select different buttons.
Why is my dishwasher is stuck in the drain cycle
What kind of dish washer. It sounds like the switch is stuck try giving the dish washer a through cleaning.
I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_ac64e182ed26f66d
Aug 13, 2014 | Samsung DMT400RHS Builtin Dishwasher
A GE stackable washer/dryer that is stuck on spin?
Good Day,
your machine is normal is washing cycle?
if yes.do the same
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
Nov 02, 2013 | Washing Machines
My dishwasher is stuck in a cycle (draininging) i have canceled the cycle however it still tries to drain.
Without a brand or a model I can ony guess. Some models have a feature that puts the unit into a drain cycle if it detects even a small leak under the unit. If yours has this feature it could even be a stuck foat safety switch.
Mar 02, 2011 | Dishwashers
Whirlpool calypso model GVW9959K-0 leaking during rinse cycle
hi my name is joyce
Sounds like your pump is leaking. if it is leaking when you are on a spin cycle.
now if it is stuck on f1 cycle and wont drain unplug and let stay unpluged for 60 seconds and replug and see if you can restart on drain and spin cycle. let me know if I can help with any other problems.
thanks
joyce
Feb 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Water won't drain out of dishwasher
outflow soloenoid stuck/ blocked, remove and clean/ replace as required
Jan 27, 2009 | GE Dishwashers
Spacemaker spin cycle problem
you may have something stuck in the drain pump......
first try using a wet/dry vacuum attach it to the drain hose and try to **** out what ever you have stuck in there... if that works you are good... if not you will have to get open the cabinet to get to the drain pump
Dec 23, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Dishwasher drain issue
check to see if there is anything stuck in the drain pump. it not, replace the drain pump, as it's malfunctioning.
Sep 13, 2008 | Dishwashers
Help with dishwasher
What Brand is it?
Dec 31, 2007 | Dishwashers
Water wont drain
something is stuck in the drain pump axcess through front panel.
Sep 30, 2007 | Kenmore 44102 Front Load Washer
Dishwashers Logo
43 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
