Question about XM Radio (XMP6000)
Replaced car battery now only get weather station
    Top Expert:
  • XM Radio Master
  • 79,847 Answers
U have lost all your presets due to the memory being lost while the battery was disconnected
Posted on Nov 17, 2009
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 07, 2016 | Measuring Tools & Sensors
Replaced batteries in both transmitter then w/station. Latter then started clicking & all items on screen flash on and off with the "clicking". Nothing functions or can be programmed.
Try putting the batteries in the weather station first and then the sender units.
Let me know make and model and I'll see if I can find a manual.
Oct 04, 2015 | Measuring Tools & Sensors
Changed the batteries in both the transmitter and weather station. It doesn't show temperature on the transmitter or show temperature and humidity on weather station
In some of these weather stations, you have to install the batteries in the transmitter first and then the weather station within a certain time limit. Also, the weather station must be within a specified distance from the transmitter when replacing the batteries.
If you look on the weather station, there should be a make and model number. If you have that, you can visit the website (if there is one) and download an instruction booklet for your model.
Jul 21, 2015 | Measuring Tools & Sensors
Display station not showing outside temperature
Check battery status indicator on main weather station of remote unit. If no indication, replace battery in remote unit. If battery is good then check "channel setting" of remote unit to make sure the channel setting on remote unit matches the "channel" setting on main unit. many weather stations will take up to 3 or 4 remote units and they must use different channels to relay the remote imfo to the main weather station unit.
Jun 19, 2015 | Measuring Tools & Sensors
Easy weather station not picking up the data from my weather station
This is the quirk with these "weather stations." They're battery operated. When the temperature gets down to a certain point, the voltage output from the battery drops below the minimum required to operate it.
You lose the signal from that station. Lithium batteries help...
Mar 09, 2014 | Measuring Tools & Sensors
I have a wweather station model no. CE0681The outdoor control no longer tranmits infromation on tempereture to the inside weather station. How do I solve this problem?
There are a couple of reasons that this can happen. First try replacing the batteries in the outdoor control. Also replace the batteries in the base (inside unit).
You may also need to resynch the two units. (For some models, this requires bringing the outdoor unit inside and removing the batteries. Then add the batteries and let the base station look for the outdoor unit.) With the Davis instruments weather station with the solar powered unit, clean the solar panel. You may need to replace the rechargeable battery.
Sometimes, lightning strikes near the weather station external unit causes a surge that damages the unit. In that case, the entire board may need to be replaced to fix the problem.
Please add a comment with the manufacturer for additional information.
I hope this helps.
Mar 18, 2013 | Measuring Tools & Sensors
C Tech Weather Station. How do i reset the outside temperature. Meter says it's off?
Is the outside unit LED on? I replaced the battery on the outside unit and in doing this reset the outside information.
Jul 05, 2012 | Coghlan's CTech Wireless Weather Station...
Cannot get the weather station model ws-916ou-it to show outside temperature
I have three of these WS-916OU-IT units. After a few years, the outside sensor just fails. You will get dashes and a "TR" low battery signal, even if the batteries are good
just buy another whole weather station (short money) and set both the old and new weather station unit to receive from the single new outdoor sensor.
To do this - just follow the procedure for a single sensor - that is - put the batteries in the new sensor - then within 30 seconds - put the batteries in all the weather stations - they will all pick up the same outdoor sensor.
I now have three units running off of one outdoor sensor.
Seems a bit silly, but it works.
Feb 27, 2012 | Measuring Tools & Sensors
WMR928NX battery replacement
I have an Oregon WMR928NX weather station. I have replaced the alkaline batteries in the wind and rain sensors. These did not communicate with the main unit, so I reset both units but only the wind sensor communicates. I have checked both battery voltages on the cuircuit board and both are correct, I don't know a solution. Thanks Rob
Nov 23, 2010 | Oregon Scientific Cable Free Weather...
Car Audio & Video Logo
192 people viewed this question
Top XM Radio Car Audio & Video Experts
xxxxxx xxx
 Mikey
Mikey
Are you a XM Radio Car Audio and Video Expert? Answer questions, earn points and help others
