Question about Uniden DECT 6.0 Cordless Phone ID
How do I turn ringer on & off phone is 6.0 - Uniden DECT 6.0 Cordless Phone ID
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
Since you declined to specify the model of your Uniden DECT 6.0 system I can only suggest that you select it from the list beginning here to download a copy of the manual.
Posted on Apr 30, 2012
How do I turn the ringer on, on the handset?
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
May 27, 2016 | Uniden Cordless Phone
How do i set the ring tone?
Hi Bec
On what Phone?
iPhone 6 (ios9) = Settings / Sounds / Ringer & Alerts
Volume
or
SOUNDS & VIBRATION
Ringtone ... Choose from List
Or
Download a Ringer Custom Sounds App
Mar 11, 2016 | Cell Phones
Turn ringer on
To set the Vtech T2326 ringer:
there are only four ringer tone/volume choices plus "off" available
1. Press the PROG end of the "SELECT/PROG" rocker switch.
The display will light and show "DIRECTORY"
2. Press the right side top button "VOL +/DIR"
The display will change to "SPEED DIAL"
3. Press the right side top button "VOL +/DIR" again The display will change to "RINGER: [number] ( 1 - 4 or OFF )"
4. Press the SELECT end of the "SELECT/PROG" rocker switch.
The "RINGER: [number] ( 1 - 4 or OFF )" will blink and the ringer will sound.
5. Press the right side top button "VOL +/DIR" The display will change from "RINGER: 1" to "RINGER: 2" and the sound will change accordingly.
6. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 2" to "RINGER: 3" and the sound will change accordingly.
7. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 3" to "RINGER: 4" and the sound will change accordingly.
8. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 4" to "RINGER: OFF" and the sound will cease accordingly.
9. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: OFF" to "RINGER: 1" and the sound will change accordingly.
10. ...and so on, cycling through the four choices & OFF: when you decide to select one, press the "SELECT" end of the central "SELECT/PROG" rocker switch.
11. The display light will go out, the phone will chirp in acceptance, and it will be ready to use the chosen ringer. --
Sep 07, 2013 | Vtech T2326 Cordless Phone
Our digital answering feature now picks up after 2 rings, it has always rang 4 times. Is there a way to adjust back to 4 rings?
click menu 3 times. click either repeat/rew or skip/ff to set to either 2 for 2 rings or 4 for 4 rings or 6 for 6 rings or h5 for toll saver THEN press set/ringer to save your change. Answering machine will answer after 4 rings if you wanted the 4 & saved by pressing set/ringer. Thats all there is to it.
Mar 29, 2010 | Uniden Cordless Phone exai398i
The ringer is turned off on my Cirrus 100 (onetel) telephone
I have the OT100 & to turn ringer off & on you press & hold down the * key until the phone beeps
Sep 02, 2009 | Lands Phones
Change the ringer
go for .. the menu and setting phone setting then ring setting..........
Jul 01, 2009 | Comdial 8324S-PT Corded Phone
Turn ringer off on certain phone
for Nokia & Motrola phones use # key by holding it for 2seconds..
May 28, 2009 | Lands Phones
Lowering ringer volume on handset v tech 5.8 digital phone
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume
• With the handset or base in idle (off) mode, press MENU then
press ▲ or ▼ until RINGER VOLUME is shown
• Press SEL. You will hear a sample of the ringer
• Press ▲,▼ or a digit (0 through 6) You will hear a sample of
the new ringer volume and the volume bar will be increased or
decreased each time the setting is adjusted At the lowest setting
the ringer will be turned off and the display will show:
- OR -
• With the handset or base in idle (off) mode, press or of the
volume control will directly go to ringer volume menu
• Press ▲ or ▼ to adjust the ringer volume
Good Luck
Nov 11, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
How to turn on the ringer
While the phone is not in use, press the up arrow until you get the ringer volume you want.
Jun 28, 2008 | Uniden Cordless Phone
Uniden DECT 6.0 Cordless Phone ID Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
