Question about Haier HC125FVS Wine Cooler Beverage Cooler
There is a tiny hole in the inside back and the freon gas leaked, is this repairable?
    President:
  • 1,149 Answers
Hi:
It should be repairable. You would need a Heating/ Air Conditioning repair shop to silver solder the hole closed, and possibly sweat on a valve to evacuate and refill the system. I would call around and ask if the shops do this sort of thing. I had a similar repair done on a window air conditioner, and it saved me money!
Posted on Nov 17, 2009
Think I have a Freon leak in freezer can I repair it myself? can it be repaired?
pretty big job! company would charge You somewhere from 400$ to 1000$ to fix. Hope that helps!
Aug 18, 2015 | Refrigerators
Air conditioner loss of gas pressure
look around engine at the a/c lines for cracks or if u can see condenser [mounted with radiator for cracks or holes usually a leak has oil around it still even if u find the or leak u have to replace the part vacuum test the system [to remove all moisture]and than add freon also if seal around compressor goes bad causing leak would have to replace compressor lots of tools and or equipment sometimes is needed to repair an a/c leak and ur 84 uses r12 freon hard to get and expensive most likely while fixing good idea to retro fit a/c to r134
May 13, 2012 | 1984 Chevrolet Caprice
Why is vacuum condenser light blinking
this is usually a leak in the evap coil,if it's under 12 years old the coil is still under warranty.sub zero is a great machine,the only problem is that the evap coil behind the back wall in the fridge section leaks or a hole develops.the freon leaks out and the fridge section will continue to get warmer,the vacumm coil lite will come on.i've seen this happen to some machines that are 3 years old it happens.you need to get a tech in,he'll recover the gas,evacuate it,replace the coil and add new freon in,if it's under warranty it will be 650 to 750,or if not under warranty 11 to 12 hundred dollars to repair.
Dec 29, 2011 | Sub-Zero 650 / O Bottom Freezer...
Unit will not cool to below 40 degrees
Proably has small freon leak and that will cause it not to cool well just like a car that is low on freon.
You might be able to add freon and it may last for awhile but you might want to pay a good service shop for a leak repair.
Usually the leak is a tiny tiny tiny pin hole in the evaporator.
Some times you can repair them but if the unit is over 7or 8 years old replacement is best.
Jan 20, 2010 | True 598-TSSU608ADA SandwichSalad Unit 155...
Small freon leak, food safety
fixing freon leak. Evaporator is leaking freon. Replaced Evaporator on this video
Sep 23, 2009 | GE Freezers
Kenmore upright frost free freezer compressor will not come on...
mlee62599,
You have a freon leak and the coolant leaked out. Perhaps when you mode it down the stairs one of the coils with the freon in it ruptured a tiny hole.
You need an authorized and certified tech for freon.
Apr 07, 2009 | Kenmore Freezers
I was drilling a hole into the bottom of the pan from the rear for better drainage and I knicked the back coils. all the freon escaped;how can it be fixed inexpensively and can i buy the freon from...
You will have to get freon from a supplier such as Aireco, or R.E. Michaels. In order to buy it, you have to be CFC certified. If you want to fix the hole, you will have to be very careful, and cut the fins away from the hole in the coil. Then you will have to get a torch (map gas, acetelyne, etc) and solder it closed. Do not use plumbers solder, use a high silver content such as a brazing rod. Then after you seal the hole, you can hook an air compressor up to it, and pump about 100 to 150psi in to leak check your repair. If all holds well, you should be able to charge it. You may be able to find some R22 on ebay. I sell it on there sometimes. There are a lot of suppliers. Hope that helps
Feb 20, 2009 | Friedrich M18CF Split System Air...
HELP - I punctured the Evaporator coil - is it junk now?
i will give u an experience
if u can see that tiny puncture then u can fix it.
how? well take a 100 grit sand paper and slowly rough the punctured hole on the side of the hole approx 1 inch around it.clean it with a clean cloth. next take some petroleum ether soak a tissue in ththat and with the ether moist towel wipe the area and the hole nicely .now buy fro the market aluminium epoxy tubes. mix a little bit of the epoxy in a i:1 rratio and apply a coating of this stuff on and around the just cleaned hole.After about 12 hours the puncture is repaired now dont touch it.
Take the fridge to a professional refrigerant filling person who has experience in filling gas. he will vacuum the system and remove any ingress of moisture and then begin filling gas. your fridge will be good as new after this job
Jan 11, 2009 | GE Refrigerators
Air cndition 2005 corolla
Hi. In order to find the leak, technicians use a device to find freon gas leaks throughout the system, I really don't know the price of the device, but it really works. And depending on where they find the leak ( hose, elbows, screws, assemblies, pump, etc.) they repair. It could range from $200-$800 or more on repairs. If you can find the device and buy it, it's really worth it, and you can do it yoourself because it's not difficult at all. Just make sure when you replace everything, Put one can of R134a gas with lube, so you can lubricate the parts, and the rest with normal R134a.
Jul 27, 2008 | 2005 Toyota Corolla
GE frig cooling problems
This Refrigerator was charged with leak dye about 4 month before it leaked out again. Got service call, there was sticker dated 4 month ago, thats what honest company do, even if other company will come out they able to see when it was charged with freon and if they add leak dye. Got my blue flash light - found right away dye, spayed with soap - bubbles right on the spot, replaced piece of copper tube - leak fixed! call right service man at first!
Jun 17, 2008 | Refrigerators
Haier HC125FVS Wine Cooler Beverage Cooler Logo
218 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
