Question about Leviton 5611-2ISP Grounded Switch
The light in my lighted switch has stopped working. What could be wrong?
  • 115 Answers
If switch still works, the little diode in switsh is burnt out. easier to just replace switch
Posted on Nov 18, 2009
When light switch is off only 3rd brake light work, when switch is on the back lights are stuck on 3rd light works normal what could be the problem?
Are the brake lights stuck on or are you just seeing the parking lights on without the brake lights lighting up? Sounds like you have no rear brake lights, check your emergency light switch. Sometimes it may not switch completely, turn it on and off a few time and then recheck it.
Mar 08, 2015 | 1998 Ford Explorer
Stop & tail light not working. Also Number plate light not working. However number plate light and a light in tail light works when key in parking position.
spray your switch with light oil ie wd40
...no contact is being made ....and I mean your light switch not your ignition....infact spray them both it will not harm the and when you have don't forget to work them
Mar 04, 2015 | 2008 kawasaki Z750
Head lights dont work on my 86 ford bronco II, new switch still not working
the main lights have dip and main switching
whats ever is up its the + side
so check the fuses and holders and wires and the dip main relays and main beem switchings
so...does the dip beam work if so its the relay or switch to dip main gone wrong
Dec 10, 2014 | Head Electrical Supplies
3 lights and loud beeping
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Dec 12, 2013 | Fisher and Paykel Washing Machines
HOW TO WIRE BRAKE LIGHTS FROM THIRD LIGHT 97 MONTE CARLO
Instead of improvising, why not get the stop lamps working the way they should be. You must be getting power through 15A fuse 23 in the fuse block and the stop lamp switch, otherwise the high mounted stop lamps would not work. Stop lamp power is routed through the turn signal switch and is applied to the tail/turn/stop-lamps. That should solve your problem
Oct 17, 2012 | 1997 Chevrolet Monte Carlo
Wall light fitting
you can check the switch .the fuse and fitting are ok .maybe there is something wrong with switch .
wall light
May 09, 2012 | Televison & Video
I have a 98 f150 xlt. My left rear turn signal and brake light has stopped working but the running lights work on the same bulb. Ive replaced the bulb nothing, replaced the socket and nothing, even checked...
Have you checked the socket to see if 12 volts is reaching the socket for brake light citcuit? Probe the wires with a 12 volt test light probe (avail from any parts store for about $6)
Apr 13, 2012 | 1998 Ford F150 Regular Cab
Door ajar light is on when all doors are shut, fuel guage reads empty and dummy light is on saying get gas, all lights in the rear do not work i.e. brake, running, reverse, blinker, hazards. 15 amp fuse...
your stop light switch is broken and shorting out hence it will not start in park ,or you have a fitted the wrong bulb in one of the back lights like a twin connector bulb in place of a single or visa versa ,which is blowing the stop light fuse ,with this fuse blown your stop light switch isnt working hence you cannot get it out of park .also flasher could be using the same fuse as the stop lights .side lights should work but if wiring is being shorted out then anything is possible
Jun 27, 2010 | Ford Windstar Cars & Trucks
Dash lights and tail lights not working on my 1999 chevy malibu
Hi its rob here what make and model of car is it? it sounds like the light switch is faulty but that wouldnt stop the brake lights workin try two stop and tail light bulbs then if you have stop lights your switch is at fault
May 11, 2009 | 1999 Chevrolet Malibu
Leviton 5611-2ISP Grounded Switch Logo
50 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Hippy_dd
jdthefixer
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
