Question about Kenmore Refrigerators
The trap door on the icemaker doesent shut, there apears to be a plunger like item hanging down which upon touching it it fell off. I don't see how to get into the unit for a look see. Model 106.5698*602.
  • jmb1946 Nov 17, 2009
    The Trap door Im refering to is in the door from the outside. This is where the ice comes through when you press your glass against the lever.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First of all unplug the Refrigerator and shut the water supply of the Ice Maker. Please check the part #16 and 23 from the diagram shown below and replace whichever is required.
You can buy the parts from the link---
Kenmore Refrigerator Ice Maker Parts
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Nov 17, 2009
  • Rylee Smith
    Rylee Smith Nov 17, 2009
    Hi
    Please check this schematic---
    Thanks
    Rylee
I have a HP 7673B injector on a 5890II that continued to give plunger error faults, despite no restriction in plunger. Upon removing retainer clip on plunger to inspect belt, motor fell off its mount. ...
I am also getting plunger errors with out any restrictions in plunger. Everything seems to be intact, but keep getting plunger errors or on saying the door is open. Any ideas?
Sep 24, 2013 | Agilent 7673 7673b 5890 6890 Gc Als...
The door on my GE advantium 120 fell off and I need to reattach it
take off the top vent cover , should be three screws ...hang the door provided nothing is broken off the door or the microwave.. after hanging put the vent cover back on. If your model has a little clip/postage size at the top hinge or if you think there is something missing at that location you may need that to keep the door from coming back off... It can be bought on line if your model needs it. some do and some don't if you found something near that area before the door fell off... then your model had one..
Nov 06, 2011 | GE Advantium 120 Convection/Microwave Oven
No water coming out of dispenser. I shut off the icemaker as well because it is not getting any water as well. The line coming from the house has been replaced and is not the problem.
Hi and wel;cometo FixYa, I am Kelly.
When both the water in door and the ice maker do not get water the common failure is the door switch or door switch wiring.
The switch is item 608 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5226718&diagram_id=23085527#d23085527
Only one side has a lock tab on it and you can release it with a thin knife blade to lift the switch free of the cabinet.
http://www.appliancepartspros.com/part_details.aspx?part_id=3192880
Note the 3 terminals on the switch. One terminal is common.. one controls the operation of the light and the other provides power to the water in door and ice maker when the door is closed.
Find the switch... press the plunger in and see that the compartment light goes off. If it stays on the switch is bad. The light can go off and the switch still not porvide power to the icemaker and water in door. Use a meter and read the contacts. Find the C on the switch and read C to the other 2 contacts. Only one will read continuity to C with the plunger extended and only one will read continuity to C with the plunger depressed. Any other result = bad switch.
If you need mroe assistance or this does not resolve the problem just respond here and I will help you.
Thanks for choosing FixYa,
Kelly
Apr 03, 2011 | GE PSS26SGRSS Stainless Steel Side by Side...
Model gd25dfxfw00 Gold side by side; air appears to be leaking around the ice maker ejection door creating a build up of ice inside the freezer at the bottom of the icemaker ejection slot.
I had the same problem, same Whirlpool frig.
There's damper/delay arm/plunger, similar to what you see on doors, that slowly closes the ice door to allow all the ice to escape. This is stuck/broken. You can order the parts on line and replace it. I actually just removed it and the door closes nice and snug again, and no more ice build up in the chute. It occasionally traps ice in the chute, as the door shuts real quick now, before the last cube(s) can come out. I'm use to it now and am quick to open the door without sending more ice out of the maker.
The replacement kit should be : AP3595356
May 21, 2010 | Refrigerators
I Have a rf266abpn and the icemaker front plate f...
I know this is a little old, but I had the same problem. It turns out that under the Ice tray, there are some plastic clamps that you can set the hanging hose onto, along with a hook that the thermostat (harder thing) hangs on.
May 19, 2010 | Samsung RS2534 Side by Side Refrigerator
Ice maker leaks water
The GE Icemaker has a center bottom plunger that drives the ice cube discharge tray up and down. If that center plunger oring has failed the ice maker will leak in a drip drip drip fashion. If it only leaks once every cube cycle then it is overflowing when filling. This can be corrected 2 ways. One is to turn of the water supply line and disconnet the water line on the back of the unit. Place the hose into a large bowl of some kiind and then have someone open the valve until the flow is full and then reduce that flow about 50 percent. Remember how many turns it took to get that flow and shut off the water supply line. Then reconnect the line and turn on the water the number of turns you counted when shutting off the water. The PROPER way of setting the water flow timing is to frome the front cover of the ice maker and turn the adjustment screw in the DECREASE direction. My suspicions are that the plunger o-ring is leaking. It costs nearly as much to have the service call to replace the o-ring as it does to replace the ice maker. Your choice but I would replace the icemaker if the plunger is leaking. (mid-bottom point of ice maker) Just note that once a leak occurs in the plunger area if the plunger has corroded the new o-ring will wear out rapidly.
Jan 03, 2010 | GE Profile Stainless Bottom-Freezer...
GE GSS25 continuely has frost on cube chute preventin cubes from discharging. Have had doors replaced under recall but problem came back.
I had the exact same problem. My neighbor has the same refrigerator, and told me that there is a solenoid in the door, behind the panel where you select between water, crushed or cubed ice. You can carefully remove that panel to expose the solenoid, which is on the right side of the dispenser water line. I have the model GE GSS25. The plunger on the solenoid gets rusty buildup on the outside of it from the moisture and water splashing from the dispenser. You might try wiping the exterior of the solenoid, and working it up and down so that it moves freely. If not, it's a cheap replacement part you can order from GE. The solenoid shuts the trap door which opens when you get ice from the dispenser. If the solenoid plunger does not move freely, then the trap door hangs open, and warm moist air enters the freezer through the ice shute, causing frost.
Sep 16, 2009 | GE GSS25JEMWW Side by Side
Dome lights wont shut off
sounds like there might be 2 feeds coming to where you disconnected the switch, I would co to the reckers & get another one from a similar car. Most of them complete the circuit when they close the switch/door open when the door closes then switch it left hanging open.
Sep 11, 2009 | 1995 GMC Sonoma
I've got the LFX25960ST model. The icemaker
its the ice maker .water or condensation has built up in the ice maker modual and refroze upon turning unit back on.either get a new ice maker or uninstall the ice maker and let it dry for a few days and reinstall.but it could happen again that way.or maybe not.
Jul 24, 2009 | LG LFX25960 Bottom Freezer French Door...
GE model # GSS25KGMC WW
  1. There is a solenoid that operates the trap door. When the lever is pressed to get ice, the solenoid operates and there is a plunger mechanism that pulls a metal pin into the solenoid. When I took mine apart I found the pin rusty which hangs up in the sleave of the solenoid. I tried cleaning the rust off with steelwool but it just rusted a month later and is now hanging up again. I may reclean the rust and spray it with silicon spray. Most likely I will need to replace the solenoid. It is located behind the touch panel. To remove there are 3 small holes just underneath the lip of the touch panel that you must push a small screwdriver or pin of some type through the holes to release the latch for the the front touch panel. Pull the touch panel toward you while pushing on the latch. You will then be able to see the rest of it.
May 24, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
43 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
