Question about Canon Pixma iP6000D InkJet Photo Printer
Hi-I have a canon pixma ip6000d that quit putting ink on the paper. I ran through the check list in the tool box and still no luck. Can you help?
    President:
  • 2,306 Answers
Probably needs printhead #QY6-0050-000, around $60.00. Usually that's all that's wrong. Although sometimes the purge assembly goes bad and doesn't clean and prime the printhead properly.
Posted on Nov 17, 2009
Testimonial: "Thanks, great advice, very helpful, I will do more research on repairs available in my area. "
My Canon Pixma ip6000d isn't printing any images or text. There is plenty of black ink, I ran the tests for alignment and nozzle check. The paper feeds through fine and it sounds and acts as tho
Did you try a test print. Most printers have a option to set the ink color, this is done when your computer asks you if you want to print. Look for an options tab and search for ink color options pick black only and try a test print. The test print is done on printer set up. If all else fails try the manual it usually has a troubleshoot section. Oh yes make sure you have the correct usb port some are configured at a lower level ( mine has 2 different ones a 2.0 and a 3.0 the 3.0 is blue when you look inside of it) my 2.0 port wouldn't set up my printer I had to use the 3.0 port. Hope it helps you some!
Feb 15, 2013 | Canon Pixma iP6000D InkJet Photo Printer
Replace the waste ink absorber on my Canon Pixma ip6000D printer
Seems to me that deposit of wasted ink is full. Try w/ a Quill tip o fabric clean excess of ink in the waste compartment (gently). Also cean the brushes.
Oct 23, 2012 | Canon Pixma iP6000D InkJet Photo Printer
Canon Pixma iP6000D prints white streaks thru the words
Run a self clean on the printer a jet may be clogged. print a test page to see if problem persists. If ink is low put a piece of electrical tape over the sensor of the ink cartridge and try again.
Hope this helps!
Aug 13, 2012 | Canon Pixma iP6000D InkJet Photo Printer
How to replace ink on a pixma ip1600
The official PDF copy of Canon Printer PIXMA iP6000D User Guide can be downloaded here..
http://www.devicemanuals.com/guide/Printers/Canon/Canon-Printer-PIXMA-iP6000D-User-Guide-TkRBMk9Uaz.html
mpawlak908
Oct 19, 2009 | Canon Office Equipment & Supplies
Hi, just trying to solve a problem with Canon Pixma iP6000D printer. For some reason it does not print the black ink but all the other colours??? Any help? Tks Mark
make sure that there was still black ink on your the printer.
Clean the print head if you suspect that the nozzles might be clogged.
  • Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
May 01, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Sir iam using cannon pixma 1p6000d photo printer , when i try to switch on my printer i am getting error message error code is 6A00
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 02, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Streaky pictures
hi, your head has damaged/need replacement. Try to clean it once again
thanks
Aug 15, 2008 | Canon Pixma iP6000D InkJet Photo Printer
Paper will not feed in Canon Pixma iP6000D printer
hi, clean the feed roller or get it cleaned from an authorized service center. use good quality paper
thanks
Aug 02, 2008 | Canon Pixma iP6000D InkJet Photo Printer
Canon Pixma iP6000D InkJet Photo Printer Logo
435 people viewed this question
old marine
old marine
