Question about LaCie d2 Extreme (300793U) 500 GB Hard Drive
The dic doesn't spin and you can hear the ticking sound
  • 358 Answers
From what I can deduce here, it seems that you the hard drive probably has a bad sector on it.
That clicking sound that you are hearing from the Hard Drive is coming from the read/write head inside the hard drive.
In this case, what I would advise you to do is, unscrew the hard drive case and remove the Hard disk from the case, connect it directly to a system, not externally or through USB this time around, then get a software called NTFS DOS Professional. It is a software that works like magic when it comes to hard drive repairs.
If you know any other hard drive utility, apart from this, you can also use it. I just recommend this personally because that is what I use.
Insert it into your PC, start up your CD-ROM and let your system boot from CD-ROM.
It works through DOS, and it should be able to help you with it.
If this does not solve the problem, then I'm afraid you might need to replace the hard drive.
And if it repairs it, I would suggest that you just retrieve all your valuable files from it and don't fully rely on the hard drive again because of the hardware error it has developed. Just keep using it as a second.
If you cannot do this by yourself, just get a very good technician to do it for you instead.
Kindly keep me posted about the problem.
Hope it helps.
Goodluck.
Posted on Nov 23, 2009
Why is my front loader noisy at end of cycle in spin?
Most likely the rear main bearing is bad
Jul 13, 2015 | LG Washing Machines
Will not start but its making a ticking sound
Electric or gas dryer?
Depending on where the ticking sound is coming from, without more specific information, many dryers use a timer within their dial for timed drying. If the switches are malfunctioning, the ticking of the "timer" can still continue.
If you can hear a whirring sound, which would be the motor, then it may be the drive belt. If this is the case, then the ticking of the timer may be more noticeable due to it being quieter without the spinning drum.
If you have a gas dryer and the ticking is from below, then it may be the ignitor that's faulty. However, that shouldn't cause your dryer not to turn on. It that case the dryer would spin, but not get warm.
With more information, I may be of better assistance.
Feb 14, 2012 | Dryers
Engine tick, sounds like a lifter, but it only does it once the engine gets good and warm. it doesn't do it around town. could also be maybe an exhaust leak between the ...
Well without hearing the tick it would be impossible to diagnose over the net. But it sounds like you have a handle on where to look.
While under the hood, exhaust and lifter ticks would sound different. A lifter would be kind of muffled while exhaust being in the open, not muffled.
Exhaust leaks are easier to see than finding one lifter ticking. Exhaust you can look around the manifolds and down pipes for black soot. You can also carefully pass your hand around things and feel for exhaust coming out.
Be sure to look at the manifolds themselves for cracks. If those manifolds have any heat shielding there could be a good place for cracks.
Sep 06, 2011 | 1989 Ford F 350
I have a Sony DVP-NS57P DVD player, The disc doesn't spin unless I give it a light touch; then it spins, reads and plays fine. If I stop it, eject it and reload it, the same thing happens again and I...
Problem seems with spindle motor that needs little bit lubrication of WD40 contact cleaner spray.
Let me know if you are willing to take apart dvd player and have WD40 spray.
Thanks.
Jul 29, 2011 | Sony DVP-NS575P DVD Player
My technics sl-p770 doesn?t recognize the loaded CD.A cd is alway spin but not any track in audio cd.
Try cleaning the lens with a cd/dvd lens cleaner disc. Another thing of note....some cd players simply will not recognize homemade cds, or dics that are not audio discs, or if they were made on a computer.
Apr 15, 2010 | Technics SL-PS770D CD Player
Ticking problem on power up
The ticking noise is most likely the hard disk and the ticking noise indicates that the hard disk is faulty.
A normal functioning hard disk makes a spinning sound.
I suggest you get your money back or get a new hard disk and install Windows to get the laptop operating again.
Jul 31, 2009 | Acer TravelMate 518TX Notebook
Ticking sound
Gm will tell you this is normal lifter noise if it from the top of the motor. It could be from the exhaust but you would hear it from under the car more. I do not care for the responce from GM but they say it is ok.
Mar 01, 2009 | 2003 GMC Envoy Xl
Rattling noise during high speed spin
sounds as if you might have a bad rear bearing, real obnoxious almost painful to listen too kinda sounds. big job, but might have some part warrentee depending on age of unit
Oct 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE3 fills but won't spin
do you hear any sound while stops??
like ticking sounds?
Jul 15, 2008 | Kenmore Elite 45986 Front Load Washer
LaCie d2 Extreme (300793U) 500 GB Hard Drive Logo
177 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
