Question about LG Keys-U-See Keyboard
I cleaned my keyboard, but keys `-1-q-a-z won't work.
  • 31 Answers
You may have one of two options 1- these Keys are loose and should be pushed down you will hear in old keyboards a type of CLICK 2- in recent keyboards you should press these keys several times.
if it has been cleaned with a non volatile liquid you should be sure that the keyboard has been completely dry specially at these keys
Posted on Nov 17, 2009
Testimonial: "Thanks. Y0u have give me good information. Ill give you a very high rating. Bob"
Keyboard won't work
When a keyboard stops working, has odd key letters, stuck keys and non-functioning keys for no reason at all, the laptop may have an easy fix solution. However, if liquid spilled on the laptop or the laptop was dropped and as, a consequence, the keyboard doesn't work, or the keyboard device has simply failed, fixing the problem may require a more involved laptop keyboard replacement.
Click start control panel keyboard hardware make sure you have the right keyboard selected or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers Click start control panel administrative tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver if your computer came with a motherboard disk the drivers could be on it. If its still not working Tap the "Alt" and "Shift" keys simultaneously if you are pressing one keyboard key and getting a different symbol or letter. This will reset the keyboard defaults on some laptops. Press the "Ctrl" key and tap the "Shift" key simultaneously if the procedure in Step 1 did not work. Press the "Fn" and one of the "F" keys to disable the "Num Lock." Different laptops use different "F" keys to disable the "Num Lock." Toggle each "F" key and press the "Fn" key at the same time to find the right key combination. Check your laptop manual to find the right key combination. Press the "Fn" key and the blue "NumLock" key simultaneously if the keyboard is typing numbers instead of letters or wrong letter keys and the above steps did not solve the problem. b> Keyboard Maintenance b> Blow compressed air in the cracks and crevices of the laptop keyboard. Sometimes dust and debris can cause keys to lock, making such keys non-functional. Disconnect the laptop from the power outlet and remove the battery. Make the tip of a cotton swab as thin as possible by rolling it between your finger tips. Dip the thinned cotton swab in rubbing alcohol and clean the crevices of the keyboard with the cotton swab. Continue cleaning between each key of the keyboard with the alcohol-dipped cotton swab. Use a new cotton swab whenever necessary. Slightly tip up one side of the laptop so dust will move from under the keys to the crevices so you can clean. Blow compressed air into the keyboard again as you did in Step 1 of Section 2. Reconnect the computer to the power and check to see if the issue is resolved. Insert the flat edge of a flat-blade precision screwdriver under a keyboard key and gently pry it up and off. Remember where the keys go, so you can easily replace them. Remove three keys at a time and clean with a cotton swab dipped in alcohol. Replace the keys and remove the next three. Do this until the entire keyboard has been cleaned. Disconnect the laptop from the power outlet and remove the battery again. Turn the computer so the rear is facing you. Remove the screws that hold the plastic hinges in place. Insert a small flat-blade precision screwdriver in the plastic hinge seam and pry the hinges up. Turn the computer back face forward and open the screen as far back as it will go. Continue lifting the plastic hinge and power plate until it comes off. Remove the screws you see holding the keyboard with a precision Phillips screwdriver. Blow compressed air under the keyboard. Lift the cable connector levers slightly and remove the data cable. Clean the cable pins with an alcohol-dipped cotton swab. Replace everything, power on the computer and try the keyboard again to see if the issue is resolved. b> Keyboard Replacement b> Connect an external keyboard to the USB port on the laptop and verify its working condition. Disconnect the external keyboard and verify that the keys on the laptop are still inoperable. Disconnect the laptop from the power outlet and remove the battery. Remove the laptop keyboard as you did in Step 3 of Section 2 by removing the plastic hinge and power button plate, the keyboard screws and disconnecting the data cable from the motherboard connector. Replace the keyboard with a new laptop keyboard for your laptop make and model.
Jan 15, 2013 | Lenovo b560 Notebook
My underscore won't work. I have Win7
Pop the key off of the keyboard and clean any gunk that may be inside of the area where that key is being pressed. All you have to do is get something tiny and strong to pry the key off. Clean the area, and it snaps right back in! I hope this helps!
Dec 01, 2011 | Computers & Internet
Keyboard on Inspiron Mini 10 is not working right. Had chocolate spilled on it. How do I clean it.
Because laptops are portable, people tend to eat and drink over them. They lay the laptops on soiled surfaces and stuff them in dirty book bags. With all of the wear, tear and abuse that a laptop sustains, it's no wonder that the keyboard can become quite dirty. When a keyboard becomes dirty, often times the actual keys won't work. It is commonplace to find dirt, debris and food under the keys of a laptop computer. This causes the keys to not engage properly, rendering them useless.
1.Run a duster over the keys of your Dell laptop. This will remove any dust or small bits of debris that are causing your laptop keys to get stuck and not work. Test your keys once you have dusted them.
2.Spray the laptop keyboard with condensed air. Hold the air nozzle (you will often insert a small plastic tube into the nozzle) about 4 inches from the keyboard. Spray liberally, and use a back-and-forth motion while you work. This will remove most pieces of debris that may be stuck under the keys. Test the keys to see if they now work.
3.Place the tip of your flat-head screwdriver underneath the right-hand side of the key that is not working. Lift up gently and the key will pop off.
4.Dip the tip of your Q-tip into the rubbing alcohol and rub around the area where the key meets the keyboard. This will remove any final bits of dirt and debris. Allow the area to air dry. Repeat on as many keys as needed.
5.Place the loose key directly over the space where it belongs. Note the small piece of rubber. Hold the center of the key directly above the rubber piece and press down. When you hear a small clicking sound, the key is secure.
Sep 09, 2011 | Dell Inspiron Mini 10 Notebook
The keys that don't work on the HP G60-120US laptop are in two columns: the column where the 1 is and the one where the 3 is. (1,q,a,z & 3,e,d,c). For some reason they won't work. Any...
Those key are on the same contact branch inside the keyboard - hardware defect. The keyboard is dead, it will have to be replaced.
http://www.amazon.com/Compaq-CQ60-CQ60Z-G60T-Keyboard/dp/B002K315C2
Jun 18, 2011 | HP Pavilion G60-120US NoteBook
I spilled coffee in my compaq laptop./ The computer works and will turn on however the keys are sticking. so I cant type a sentence. Is there a qucik fix for this>
take your laptop to the expert who can deal with laptop well.don't try to clean the keyboard yourself because it is easy to remove the keys from the keyboard but then you won't be able to fix them on the keyboard properly. If you still try to remove the keys you can damage the keyboard's key sensors.
May 31, 2011 | Computers & Internet
The shift key on the keyboard worked half the time for a while and now it won't work at all
Try the following:
1. Press the shift key several times and check if it changes anything. This is to make sure the inner part of the key isn't sticking onto the connector.
2. Press other keys as well, like Ctrl and Caps Lock.
3. Is the other shift key working? If it is, it is most likely that the other one is faulty. If it's the case, you need to buy one from ebay.
Try to search on ebay and see if you can find just that single key, some sellers are selling just the key for a much cheaper price. If you can't find one that's selling single keys then am afraid you should buy yourself a keyboard replacement.
Hope this helps.,
May 06, 2011 | Sony VAIO VGP-WKB1 Keyboard
My keyboard will not work
Keyboard Is Dirty:
Keyboards should be cleaned with "spray-n-wipe" cleaner and a cloth or tissue on a monthly basis. Ensure that computer is not powered up while cleaning the keyboard. Compressed air can also be used to clean between the keyboard keys. Another tip: clean the keys with a cotton swab dipped in alcohol.
"Keyboard Not Found" Message:
Your keyboard is not plugged into the computer securely. Unplug it and plug it back in and the problem should go away. If this doesn't work, follow procedure: "Computer isn't taking inputs from keyboard" (below).
Key Is Stuck:
1. If a key does not work or is stuck in the down position, you may try to remove it with a CPU "chip puller" tool. These simple "L" shaped tools are great at pulling out keys. Once you've pulled out the stuck key, you can try to stretch the spring to "reanimate" its action.
Computer Isn't Taking Inputs From Keyboard
1. Is keyboard connected to computer? Ensure that the keyboard is plugged into the keyboard jack and not into the mouse jack. If the keyboard was unplugged, plug it back in and reboot the computer.
2. If the keyboard still doesn't work on boot-up, power down the computer and try to borrow a friend's known-good keyboard for troubleshooting. Plug the new keyboard up and boot up the computer. If the new keyboard works, the old keyboard is bad and needs to be replaced.
3. If the known-good keyboard doesn't work, check your BIOS to make sure it sees the keyboard. It should say, "installed." If the BIOS recognizes the keyboard, then you probably have a bad keyboard port.
I Plugged Keyboard Into Mouse Port
1. Many mice and keyboards today use a PS/2 connector
. If you plugged your keyboard into the mouse port (or viceversa), follow steps 2 and 3.
2. Shut down the computer and plug the keyboard into the keyboard port. The keyboard port is usually marked with a "keyboard" symbol. Plug the mouse into the mouse port (usually marked with a mouse symbol).
3. Reboot the computer; the keyboard should work now. If keyboard doesn't work, check your BIOS to make sure the BIOS recognizes the keyboard. You should see the words, "installed" or "enabled" under the keyboard.
4. If the BIOS recognizes the keyboard but it still doesn't work, you may have a bad keyboard port.
I Spilled a drink on my keyboard!
1. If you spill any liquid in the keyboard, turn it upside down ASAP. Drain all the water out of the keyboard, shaking it if necessary. If you've spilled water into the keyboard, just let it dry. You may use a hair dryer to dry out area under the keys (remember, too much heat and you could damage the electrical components).
2. If you've spilled a soda into the keyboard, completely rinse it in warm water. No soap please! You may use a hair dryer at this point or just let it dry for 2 days. Ensure the keyboard is perfectly DRY before you attempt to use it again. Don't plug a wet keyboard into electrical equipment. Think safety.
5. If the keyboard still doesn't work, replace the keyboard.
Nov 13, 2010 | Dell Computers & Internet
Logitech cordless keyboard not working properly - keys stick or are delayed
Did you spill something on it or is food lodged in unit if so take apart clean.
Fresh batteries would be good start.
Feb 18, 2010 | Logitech Cordless Desktop MX3200 Laser...
The number keys doesn.t work properly: `1 `1 2(f1) 3 54 54 67 67 =8 9 -0 -0 =8.. that should be: ` 1 2 3 4 5 6 7 8 9 0 - =
Sound's like dust is the issues here, so you will need to remove the keys that you are having trouble with or all keys to be on the safe side, once removed get a damp cloth and clean the keyboard where the keys once were and while your doing that soak the keys in some water to clean them up and dry them when done. Put keys back into place and test keys to see if problem as gone or not. Hope this helps.
Jul 17, 2009 | A4tech KBS-720 Anti-RSI Keyboard
Key not working
I think u needs to replace entire keyboard or just go and buy external keyboard (USB)(20$ Approx.)
Or you may repair ur keyboard by visiting :
http://www.laptoprepair101.com/laptop/2007/03/20/key-fell-off-keyboard/
May 15, 2009 | ASUS Laptop Keyboard for Asus A3, A6, A9,...
LG Keys-U-See  Keyboard Logo
1,621 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
