Question about Microwave Ovens
Went to use and there was no power in unit. was
Went to use and there was no power in unit. was power to the outlet. no history, worked fine to that point. kenmore microwave model 56561584, can i repar it myself? Thank you rich
My kenmore 565 has gone out...no power. We have checked the power supply works. Can we check the internal fuse?
Posted on Apr 11, 2010
    Genius:
  • Microwave Ovens Master
  • 1,467 Answers
Has got internal fuse also ..you need to watch large capacitor if fully chaged can be hazardous....
Posted on Nov 17, 2009
Samsung smh1816s
If side to side movement restored power, even briefly, the power line connection at the rear could be worn or defective.
Jan 10, 2014 | Microwave Ovens
Unit went dead. No fan, display, light, oven. Is there an internal fuse or reset?
There is an internal fuse. Be careful high voltages present even if the microwave is unpluged.
Good luck
Jan 03, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Danby Designer 1.1 cu.ft. Microwave oven model DMW1158W I came home from work...went to heat up some lunch and the microwave didn't work. I thought maybe the power was off...no...power was on. I...
Weird that it worked when you left then not. Have you had the lights inside of your house dimming off and on?? It could mean a bad neutral connection to your house from the power pole. That can cause the low voltage transformer on the timer board to burn out. So the fuse in the unit will not even blow but still kill the Low Voltage transformer. If sounds possible call your power company to do a "load test" on the incoming power lines to your house.. They don't typically even charge to do that. They take out your meter and put a tester in that spot that tests the supply to your house.
Oct 17, 2017 | Danby Microwave Ovens
Unit was working than just shut down, the display went dead.
hello,
the solutionhas noting to do with reset button or code
what the problem is from the element (heat provider)it is always is silver colour all it means is there is disconnection from it or it is bad.
what you need to do to fix up your oven is to unscrew it and then trace down the wire to the heater (element) but if you did not see any sign of disconnection then you will have to make a change of the element it mean bad .
thank you and thanks for using fixya.
Jun 01, 2010 | Sharp KB-6015K 1000 Watts Convection /...
The microwave had been working fine we now have no power at all
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Feb 21, 2010 | Maytag MMV5207AAS Microwave Oven
Microwave has no power
Is the outlet ok? Can you plug somethng else into the outlet to see if the fuse or breaker controlling the outlet is ok? If there is power at the outlet, unplug the unit and remove the outside cover.
Look for a blown fuse on the motherboard. Replace it with the EXACT value of the original fuse. You can purchase a new fuse at Radio Shack or hardware store or auto parts store. Try powering up the unit again and see if it works now or whether the fuse blows again. If it blows again, the power supply may have been damaged. Was this a power outage or surge? Was anything else in your home affected?
- Jim
Jan 29, 2008 | Goldstar MV-1526 Microwave Oven
GH7145XFB microwave hood
There is an internal fuse, and also a couple of thermostats, and I would be suspicious of the thermostat on or near the magnetron.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It helps with troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 14, 2007 | Whirlpool GH7145XF Microwave Oven
Microwave Ovens Logo
369 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
