Question about Toaster Ovens
Heat elements keep going off and on, so consequently toast is a really dried out piece of bread before it even looks toasted. We have tried turning past 10 and then back, but there's no change.
    Genius:
  • Toaster Ovens Master
  • 1,460 Answers
Try cleaning out first or fit new thermostat
Posted on Nov 17, 2009
Does not toast bottom side
you have to turn the bread over to toast that side .
Mar 16, 2015 | Rival 4 Slice Toaster Oven
Why won't my calphalon toaster oven toast top of bread? Why?
If both the top and bottom elements are working then you may need to re-position the rack closer to the top element for even toasting. If there is only one rack position available then you may need to flip the bread and toast it twice.
Oct 06, 2014 | Toaster Ovens
My calphalon toaster oven will not toast top of bread? Why?
The upper heating element may have failed or the toasting function may not have been selected.
Oct 06, 2014 | Calphalon Convection Oven, Extra Large
Black & Decker Toaster Oven - elements cycle on and off, which makes for a SLOW cook.
Oven has three modes: 1) oven mode cycles elements on and off to maintain a specific temp setting for up to 60 min. 2) toast should keep all elements on for a few min. 3) broil mode top elements only always on, up to 60 min. Make sure you have dials in correct position and use the toast timer.
Apr 17, 2014 | Toaster Ovens
Hello After washing my toaster oven screen that I lay the bread on for toasting, the bread now sticks on it when I toast it
Hi, you may have some detergent or soap left on the screen that is causing the bread to stick to it. Try rinsing it heavily with water to remove any residue. If that doesn't work, try spraying the screen with Pam or a similar non-stick spray.
Oct 07, 2010 | Euro-Pro Toaster Ovens
Cuisinart tob-30bw,is not starting ?when i try to toast its not working
The problem is 4 capacitors on the small circuit boards inside. Three 220uf 16V and one 1uf 50v. These apprear to be going bad from internal heat drying them out and they fail. Symptoms include toast will not start when button pressed, or does start but then stops soon after. A buzz or hum heard when the Toast selection is made..(you should hear nothing until the start button is pressed) and the timer beeper no longer working. These are about $2 in parts, and easy for a good electronics person.
May 06, 2010 | Cuisinart TOB-30 Toaster Oven with...
Can you toast bread in it?
You turn on the grill part, set the temperature dial to high wait a few minutes then place the bread on the grill tray provided.
You will need to position the grill tray near the top of the oven because that is where the elements are.
The grill gets hot so you will need to use tongs or gloves to gain access to the bread
Keep a careful eye on the bread because unlike a Toaster it will not eject the bread when it is done and it will catch fire.
Quicker and cheaper to buy a purpose built toaster and use the other one for doing casseroles etc
Jun 16, 2009 | Dualit 89100 1500 Watts Toaster Oven with...
Toaster does not work!!!
I investigated further (took it apart again to satisfy my curiosity) and it appears that one of the top heating elements (the front one) is open (burnt out). I cannot see an easy way to replace it (contacts are spot welded) and I can't find a place to buy the element. If I could it probably won't be worth it since a new oven costs $25 at Target (B&D TR0490W). Too bad since the oven looks like new. I assume the upper elements burn out more frequently because heat rises from the lower elements and adds extra heat at the top.
Jul 02, 2008 | Black & Decker TRO360 Toast-R-Oven Toaster...
Top element not heating
I found that the heating element in the top front was burned off at the end. I removed the side cover and the ceramic insulator from the broken end. I then grabbed the broken end of the spring inside the glass tube and stretched it to where I could re-attach it to the connector. It now works after getting it back together.
If you attempt this repair, UNPLUG THE OVEN FIRST!
There is also a security screw at the bottom of the side cover.
Dec 26, 2007 | Black & Decker CTO649 Toaster Oven with...
Cuisinart toaster oven modele no.TOB-30BWC, serial no.50421.
The contacts for these toasters fail. The plasic cam that depresses the contacts also can melt. The design is poor and no replacement parts are available. When selecting a setting, if the selection is not exactly perfect, the contacts arc and eventually fail. Unless cuisinart changes the selection cam to a solid state or relay, this failure will continue to happen during normal use. If your unit works properly do not switch the function setting while heating, this will cause the contacts to arc and erode the contact surface. This posting is applicable to the TOB-30BC, TOB-30BCC and probably all TOB-30XXX models.
Dec 26, 2007 | Cuisinart TOB-30 Toaster Oven with...
Toaster Ovens Logo
140 people viewed this question
Top Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Toaster Oven Expert? Answer questions, earn points and help others
