Question about kawasaki Full Suspension Mountain Bike Men
KX80, overheating ?
KX80, fitted new piston and rings, runs really well, but, steam coming from radiator vent after 10 mins ?
  • 4 Answers
Hi its better to check your water pump where the hoses are.I think its not working properly and make sure you use the correct coolant fluids.
Posted on Oct 14, 2013
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 197 Answers
I'm not familiar with this bike but it sounds like it could be air locked and causing it to overheat.I found the best way to remedy problems like this is to get it up to temp,shut off and lay bike down too one side then the other.Tilt forward then back,check to see if coolant level dropped.If that dont work pull a vaccum on cooling system and see if it holds when warm.
Posted on Nov 17, 2009
Replaced heads after overheating problem, Water and steam coming from dip stick. What did I do wrong?
Several possibilities..wrong gasket, maybe installed incorrectly, head bolts maybe stretched or not at correct torque, possibly the block deck wasn't cleaned properly, or the heads could be warped or cracked from the overheating.
Dec 06, 2016 | Cars & Trucks
How to bleed radiator aprilia sx 125
u must seek a repair manual for ur model--or go to library sec629 and view the books--asian bikes are similar
Feb 27, 2014 | Aprilia Motorcycles
How to install power rod on a 2001 kx85,we did a piston and ring replacement and the power rod came right off, but how to reinstall is the problem
when your putting the barrel back onto the piston start lowering it down. when you lower so far swing the power rod into posistion cause you cant fit it after you have reinstalled the barrel. hope this helps just fitted a new piston and rings on ma kx80 and a had the same problem lol
Jun 11, 2010 | 2003 kawasaki KX 125
Was making steam did head work new still have the same problem 1994 toyota 2.4
Obviously the engine is overheating.
Could be a struck thermostat --- that would show up within about 5-10 mins. of running in the driveway in neutral. You did put a new thermostat with the head work ? Did you bleed out the cooling system when filling????.
Or is it steaming when driving under load.????
If that is the case than you may have a compleatly plugged up radiator--- which would have to be replaced.
Mar 30, 2010 | 1994 Toyota Pickup
99 Firebird still overheating after repairs and antifreeze
overheating is most likely a bad thermostat, but the coolant loss is a second big concern. Does the exhaust look like steam? You could have a cracked block and the coolant is leaking into the engine. Also check the oil for contamination.
Feb 16, 2010 | 1999 Pontiac Firebird
What causes 1991 toyota camry to over heat? we put a new radiator in it last year cause the radiator got cracked. but it didnt start overheating til this year. so we changed the thermostat thinking it...
Change the radiator cap, it may be the wrong pressure rating which will cause the coolant to boil at a much lower temperature than designed.
Nov 18, 2009 | 1991 Toyota Camry
I have a 1996 Acura 3.2TL[V6] and it is overheating...
I had the same problem, whole new radiator, new hoses, new thermostat, and still overheating. What the problem was for me...bad radiator cap...all that money and a $20 fix...try it?
Sep 13, 2009 | 1996 Acura TL Series
Car overheated, radiator has hole in it. Clicking sound when engine is on and I have pressure tested the head and the gasket seems to not be blown. Smoke is also coming out of tailpipe when engine is...
you could have a broken cylinder head gasket...you are loosing water thru the engine pistons that is why you have smoke on tail pipe when engine is running.
our simple test if you have a blown gasket is to fill the radiator up to the rim and then be carefull, do not stay in front of the radiator then ask someone to start your engine and watch the water in the radiator, if the water rushes outside the mouth of the radiator, then you have a blown gasket.
if not, then put the gasket cover and run the engine for 20 mins and watch the temp gauge, it should not over heat.
tnx for using fixya,
drcool
Aug 19, 2008 | Mitsubishi Diamante Cars & Trucks
AC vent steam
have your heater coil replaced, have ac system checked out its something thats coming from an exchange
Aug 08, 2008 | 1997 Honda Accord
kawasaki Full Suspension Mountain Bike Men Logo
126 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
