Comfortmaker furnace will not light!!
We moved into a house that had been unlived in for 2 yrs. when we went to turn on the furnace for the first time for the year it will not light and only blows cold air. it is a comfortmaker model number EED24B15C2 with a serial number of X034406879 the blinking light is green and is displaing a error code I believe of 3 but we do not have a manual for this furnace. it turns on but dose not click like it is trying to light though we did check and it has spark.
  • eyeore63 Nov 18, 2009
    I do not hear any clicking when it starts up, gas is getting on the line as we checked that but it is not coming out the gas valve ( I think ) when it goes to start up it buzzes but no clicking
  • 614 Answers
Make sure you have gas to the unit and the switch on top of valve is turn to on. Can you here the gas valve click? It igniter comes on and a delay and the gas valve should come on. Kill power to furnace to reset control board. Rus Let me know how it goes.
Posted on Nov 17, 2009
  • James Stopp
    James Stopp Nov 18, 2009
    You need a volt meter to see if you have 24 volts to the valve. Turn on furnace and let it go thru cycle hold test leads across terminals on valve if you have 24 volts and no gas flow valve is bad. If you do not have 24 volts you have control problem, high limit, rollout switch,draft motor. switch. These controls hold open the circiut to the valve. If these are good you have a bad control board. If so call a service tech for free estimate the control boards go from 29 to 89 dollars each labor about 75.00 If your furnace has not been cleaned in a while you need to have that done just for to be safe. Rus let me know.
Home furnace comfortmaker blowing cold air
Home owner's manual? Troubleshooting section. Gas or electric?
If gas, pilot light may be out, or other gas controls. Are you sure you have gas supply? Do you have other Gas appliances so you can check? Furnace needs power for controls, fan and thermostat. Are you sure you have electric power to the furnace? Does the thermostat have a fan switch? If so turn it on and see if the fan turns on. If it does not turn on you may have a circut breaker poped. or some other reason power to the furnace is not working.
Feb 27, 2015 | Heating & Cooling
Comfortmaker model numbers vr8240m1075
I believe it is an 82% efficient 40,000 b.t.u. furnace. If it is an 80% furnace count the burners each is 20,000 btu 2= 40,000 3 = 60,00 and so on. Hope this helps.
Bob
Jul 09, 2014 | Heating & Cooling
Comfortmaker PAT 336K00A1
Cliff, this is Teng. Look inside your furnace if there is any flashing code. If your furnace is recently installed it should have electronic control board.
Nov 10, 2013 | Comfortmaker 7.5 Ton Heat Pump W...
How can I determine btus & AFUE in a comfortmaker furnace, based on the model #?
The BTUS are part of the model number and the Manufacturer will give you the AFUE rating or just call a local comfortmaker wholesaler listed locally. Good Luck
Aug 14, 2013 | Heating & Cooling
Problem with Goodman furnace electric ignition
Power is there, or no lights would blink. Steady blinking or flashing three times, stop, three times Etc
Nov 23, 2011 | Goodman Heating & Cooling
"Comfortmaker " brand air conditioning
I did some research and this sounds like it could be a capacitor issue. Go to the back of your outside unit and look inside the access panel with the electrical warning sticker on it, if the capacitor is bowed up at the top, it needs to be replaced. If it turns out to be the capacitor, follow this link for a new capacitor replacement kit, it will save you hundreds of more dollars than calling an HVAC repair company to charge you an arm and a leg. The kit also comes with the proper tools and parts needed as well as detailed instructions on how to replace the part yourself. http://hvacrepairkits.com/index.php/content/article/68
I hope this helps!
Aug 18, 2011 | Heating & Cooling
Comfortmaker furnace fires sometimes
is there any led lights inside the fan cabinet that blink a code if so write down the code then check inside the panel it might tell you the code description if so let me know what the description is and we can procede
Jan 06, 2009 | Heating & Cooling
Ruud heater will not light consistently
Your furnace is going into a lockout condition, cycling the power resets the circuit board and it starts over. I will need to know approximate age and model of your furnace, it sounds like you have need to clean the flame sensor rod. However i need to know what i am working with.
Dec 18, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
1,749 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
