Question about Apple iPhone 3G
No sim card error and battery dies within hours of moderate use. it is jailbroke and unlocked and has been working for months as such.
  • kwame_dougan Nov 17, 2009
    I got a new sim card, and i'm unsure how to clean the reader in the unit, but i'm trying a few methods. I've also done a network reset, and have added tape to the back that it is pushed further forward.
    I need a definitive fix for my jailbroken and unlocked phone. I was working just fine until a few days ago
  • Apple Master
  • 13,433 Answers
Are you still in warranty? that sounds like it should be sent back to the dealer or apple for repairs.
As for the sim card issue, try another sim card and try to pull the pins that touch the sim card inside the phone up carefully just a little don't break anything, just pull them up a bit so they touch properly.
if the phone doesn't work with any sim card then its clearly faulty, as for the battery time being just a few hours that also points at a hardware problem, unless your battery is old and worn out.
Posted on Nov 17, 2009
  • 3,741 Answers
The device shows no-Sim card error because it cannot sense the sim card in the unit.this happens when either the copper connections on the sim card are weak or has scratches.also quite possible that the internal device connections have gone weak.clean the sim and connections in the unit and card.then check out.if still the same problem then replace the sim card and check out.
Now the battery problem occurs due to weak battery or battery got internally drained so it does not hold charge and does not last long.also the local non branded batteries are not to be trusted.get the original replacement battery from dealer.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
How can i unlock my security code?I forgot my security code &i dont have any idea
a sim card or phone needs a puk code or is locked BECAUSE it is not active,in order to unlock a sim card,or receive a puck code,you need to either,pay the balance owed,buy a new monthly service,open a new contract with a cell service or return the sim card or cell phone to whom it belongs to,we at fixya CANNOT GIVE YOU A NUMBER TO UNLOCK YOUR SIM CARD OR PUK CODE,there is a reason why it is locked,if it was easy to get a code,then anyone could steal your phone and use it and you couldnt stop its use for at least a month.
a phone is jail broken when you alter it to work on a different cell service provider,we at fixya do not jailbreak anything,if it isn't legal,then it doesn't belong here.
Jul 12, 2015 | Cell Phones
Jailbroken/bricked Iphone w/tmobile sim card
If the Iphone works, all you have to do is reinstall Itunes.
Oct 07, 2008 | Apple iPhone Smartphone
SIM Card Rejected
If the Phone says Sim rejected means it locked to Network,You need to Unlock it,you can get the unlock code from the site
Unlocking4u.com/unlock-your-phone/rs6wp2/ and Unlock it from Network Lock,Then You can use any GSM Network Sim card in NOKIA 1280.
Dec 03, 2011 | Nokia 1280 Cell Phone
Mini phone ka08 - 'sim card not registered'
first u have to jailbroke it from redsn0w , after words u will see cydia in that u search yellsn0w and install it , after that u can use any sim
Aug 25, 2009 | Apple iPhone 3G Black Smartphone
Samsung u900 limited service
Is the battery fully charged now???
Limited service, is when your not getting any reception, Samsungs usually always get low reception or no reception at all if the battery is low or dying... Remove the sim card, reinsert it into the handset, charge the phone and try again...
If it still doesnt work and the sim card does work in other handsets, its still covered under the Samsung warranty if its less than 12 months old.
May 14, 2009 | Samsung U900 Soul Cellular Phone
Jailbroke iphone was working fine but now has no service but every thing ealse works fine
First, call your carrier and have them reset you on the network.
If that does not work, put the sim card in a carrier branded phone. (a phone your carrier sells) then back in the iphone.
If that doesn't work it means that the turbosim (a very thin device that is installed on the sim card) has gone bad. This is the device that actually unlocks the iphone.
You will either need to get a new one, or look in to a software unlock that doesn't utilize the turbosim.
Feb 27, 2009 | Apple iPhone Smartphone
IPhone Network Service
Maybe you shouldn't illegally jailbreak your phone.
Jan 24, 2009 | Apple iPhone 3G
Iphone Unlocking Problem
if you are trying to upgrade to 3.0 you can not unlock a 3g under 3.0 firmware.
2g solution
3g solution
IPhone Unlock
bro,may be you upgrade your iphone  firmware to v 2.2.1 It's inposible unlock this  so far.
Jan 23, 2009 | Apple iPhone 3G Black Smartphone
T mobile wing unlock code
Call your cell phone carriers customer service and they may email you the unlock code and instruction for free within 24-48 hours. Tmobile did this for me several times on different phones. Tmobile will send you the unlock code and instructions via email for free for their customers within 24-48 hrs. But you have to call their customer service (US) 800-937-8997. I tried emailing them initially but no response. When I called they were so accomodating and didnt even ask why I wanted the phone unlocked.
Once they send you the code its simply inputting the code they provide. However to do this you must first put in a non tmoile sim. As far as I know this is only cingular or a foreign pay as you go sim card. Luckily I had a foreign sim that I saved on a prior trip as I have other unlocked phones and this worked for me. None of my friends had cingular so I could not use their Sim to do the unlock code on my phone. Nextel, Sprint and I think Verizon also dont use sim cards.
Alot of cell phone stores and kiosks will also unlock any cell phone for you for about $30.00. You may have to leave the phone with them and pick it up later like an hour or two later if they are busy.
Dec 12, 2007 | T-Mobile Wing™ Smartphone
Apple iPhone 3G Logo
19 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
