Question about Dewalt & 2HP Hand Carry Heavy Duty Electric Air Compressor
Hi I have a Dewalt d55141 emglo contiues to run
Hi I have a Dewalt d55141 emglo compressor which does not shut off at the 150 lbs cut out point and continues to run until it blows the safety valve. It sat for a while and last time I used it it was fine. Was has happened and can I fix it? Thanks, Chris
Wrong, no black box or cutout switch. p/o N003307
Posted on Nov 29, 2012
    President:
  • 3,433 Answers
Open the shut off switch box and adjust the cut out pressure.
Posted on Nov 18, 2009
  • sapphireshom Apr 15, 2011
    My compressor is doing the same thing! How do you adjust the cut out pressure?
  • Ned C Cook
    Ned C Cook Apr 15, 2011
    Hello Chris,
    Adjusting the cutout pressure switch is quitesimple. This cutout switch is the black box that the electrical cord comes out of. Remove the cover and all will be told. The way it works is the a signal line runs from the tank to the box (switch) and when the pressure reaches your setting, it opens the power supply contacts. Inside you will see the adjustment screw in the box. The adjustment raises or lowers the tension that that the pressure has to overcome. Emglos are generally set at 125 psi cutout. An Osha yhing. Just turn the screw to the point of preference. Best way is to drop the tank pressure to until the compressor turns on. Cut in should be @90 psi. This easy set, turn the adjustment screw until the compressor starts at 90. Dropping the tank pressure to 90 should kick it on. As it pumps up it should cutout at 125 psi. If not, then adjust the cut out screw if there is one. Adjust it with the compressor running. As it nears cutout pressure be prepared to adjust the cutout screw at 125psi, The unit should shut off Watch the switch when the cover is off and you will see the movement as on and off does its thing. Be care around the eectrical taking care not to get the screw driver or your hands into the electrically hot componaents. Good luck. If adjusting doesn't work, The switch box needs to be replaced.Chk the signal line to make sire it is not crimped, broken, or otherwise being preventeted from getting air to the cutout switch box. Sometimes they are too long and kink when they get hot. _Ned_
Model ihave a dewalt 2 gal air compresssor model# d55141,compressor keeps runing and pressure builds above 150 p.s.i.doesnt shut off
There is a pressure regulator that is contained in the same housing as the on off switch. Take the housing cover off and see if there is a problem with the mechanics on the switch or the seal is bad.
Jul 13, 2013 | Air Tools & Compressors
Dewalt d55155 compressor runs to 60 lbs then acts like not enough power and shuts down
Looks like it's an oiled style compressor. Is it getting pretty hot by the time it hits 60psi? Might be low on oil, or the oil has been contaminated with water from condensation. If that's the case then what is happening is the compressor is causing too much resistance for the motor to turn it because of the excess friction. This is could be what is causing it to shut down prematurely.
Nov 23, 2012 | Dewalt D55155 Emglo Air Compressor
Compressor relief valve opens 150lbs on my d55141
That is the compressor's holding capacity 150psi. Therefore, the cut-out pressure has been reached. The safety valve opens to relieve the excessive psi. Compressor should come on at 120 psi.
May 15, 2012 | Dewalt d55151 factory reconditioned emglo...
Why does my compressor just buzz when I turn it on?
that (more than likely) is the starter, but it also may have hit a bad commutator bar... turn off power, turn flywheel 1/8 (or so) of a turn, turn on power.
if it starts, purchase new motor because the commutator/brushes are dirty or shorted.
if it doesn't, replace the starter relay.
May 04, 2012 | Dewalt D55141 Heavy-Duty 2 Gallon Trim...
Dewalt /Emglo 10 gal ,150 psi with 5.5 Honda GSX just shuts off sometimes ,some days it works fine ,some days it wouldnt work at all ,looks like something with gas ,it would shut off after pumpin tank...
I have an Emglo compressor with a 8 HP Honda motor. The motor has a low oil level shut-off switch in the crankcase. My switch failed intermittently and the motor would run sometimes and not others. There is a wire going directly into the motor crankcase. On my unit, the switch is normally open and when there is enough oil in the motor, it closes to allow the engine to run. If you can't start the motor, unplug the wire that goes into the engine from the connector. Then stick a wire into that connector and hold it to metal on the engine & try to start the motor. If that switch is the culprit, it should now start.
Be advised that running the motor without the switch in the circuit would allow the motor to be run with no oil in it.
Dec 06, 2010 | Dewalt Heavy - Duty 5.5HP, 10.5 Gal., Gas...
DeWalt emglo compressor does not start
hello,
well,you have to release the pressure,the cut out pressure at 120 psig.reached,and the cut in pressure maybe at 40 psig.so after realeasing pressure at cut in the compressor will run.if the compressor not run at cut in or after releasing check your power supply if still have,swicth off power breaker,by pass pressure switch,by disconnecting the line on terminals of pressure swtich,connect the line w/out pressure switch
the wire line should supply the the compressor,
open the service valve of compressor,switch on
observe if compressor run and develop pressure or air is coming out to nozzle,if that so switch off again and replace pressur switch.you have defective pressure switch,regards rate me,thanks
May 02, 2009 | Heating & Cooling
Engine shuts off when max PSI is Reached, instead of cutting out and still running? does anyone have a solution.
Dont understand the question , does the engine shut off after p-max is met , or does it continue to run , if it continues to run then you have a pressure switch problem
Jan 29, 2009 | Dewalt d55151 factory reconditioned emglo...
Air compressor does not regulate pressure to set point.
Emglo airmate compressors are set from the factory to shut off at around 125psi. There is an adjustment (remove cover to pressure switch) that will controll the cut-off pressure but it is not recommended changing the factory setting. There is also a safety valve installed that will open at about 160psi. It is a small brass device with a pull ring. When things go wrong with the pressure switch (rectangular box with power cord coming out of one side) the safety will pop open. There is a pressure regulator with round knob on panel that will lower the pressure to the tool, however this regulator does not control the pressure switch. Let you compressor run untill it shuts off and verify pressure to be about 125, if it is then all as well. Good Luck
Jan 03, 2009 | Dewalt d55151 factory reconditioned emglo...
Dewalt & 2HP Hand Carry Heavy Duty Electric Air Compressor  Logo
1,325 people viewed this question
Top Dewalt Plumbing Experts
Donni Steen
Tom Chichester
Are you a Dewalt Plumbing Expert? Answer questions, earn points and help others
