Question about Gateway FPD2275W LCD Monitor
Inability to Install Benq FP992 Pivot on lapto with Vista.
Hi, the Monitor works, but I cannot install anything from the disk, and I want the pivot to work.
Can you help me please.
Many thanks,
Lady Liz
  • 151 Answers
Use pan drive for matter.
Posted on Mar 03, 2008
How do you replace windshield wiper motor on a 1997 ford e250 van
REMOVAL
  1. Raise and support the hood.
  2. Remove the windshield wiper pivot arms.
  3. Remove the cowl top vent panels.
  1. Disconnect the windshield wiper mounting arm and pivot shaft.
  1. Remove the access cover from the dash panel.
  2. Remove the mounting arm and pivot shaft retaining clip.
  3. Disconnect the windshield wiper mounting arm and pivot shaft from the windshield wiper motor.
  1. Remove the windshield wiper motor.
  1. Disconnect the electrical connector.
  2. Remove the three bolts.
  3. Remove the windshield wiper motor.
INSTALLATION
  1. Install the mounting arm and pivot shaft retaining clip on the windshield wiper mounting arm and pivot shaft.
  1. Install the windshield wiper motor.
  1. Place the windshield wiper motor in the dash panel.
  2. Install the three retaining bolts.
  3. Reconnect the electrical connector.
  1. Reconnect the windshield wiper mounting arm and pivot shaft.
  1. Press on the windshield wiper mounting arm and pivot shaft after it is aligned with the windshield wiper motor.
  2. Install the access cover in the dash panel.
  1. Install the cowl top vent panels.
  2. Install the windshield wiper pivot arms.
  3. Adjust the windshield wiper pivot arms.
This is technically for the V6 4.2L but I'm sure those Ford E250's have the same setup for windshield wiper motor. Let me know how it goes.
Nov 17, 2014 | Cars & Trucks
Hp monitor problems
Here is a link to a web site that offers few notes on how to enable the feature in the windows OS environment:
Pivot Feature Does Not Work
Aug 15, 2014 | HP 21.5IN MONITOR ELITEDISPLAY E221 /...
Adjust tension on wishbone rear
For a 2004 Softail - you never gave a model year.
1. Place rear fork (3) in the frame so that
the bores in the frame align with the bores in the fork.
Insert the bushings (10) into the spherical bearings (7)
from the inside.
2. Install pivot shaft.
a. Apply LOCTITE ANTI-SEIZE to pivot shaft (4).
b. From the right side, install pivot shaft and spacers
with spacer collars facing transmission case.
c. Apply LOCTITE THREADLOCKER 262 (red) to
threads of pivot shaft nut. Install and tighten pivot
shaft nut to 90-110 ft-lbs (122-149.1 Nm).
NOTE
Proper pivot shaft tightening is important to maintain rear fork
alignment.
3. Check for freedom of rotation of the rear fork around the
bearings and that the fork and frame side members have
not been distorted when the pivot shaft nut was tightened.
4. Install the canister (California models),
fender extension (2), brake caliper and rear wheel.
5. Install both rear shock absorbers (9) using bolts and
washers (8).
Aug 31, 2013 | Harley Davidson FLSTC Heritage Softail...
I am trying to replace the fan belt on my 1988 Bronco II. What do I do to replace it with a new one. THe old belt broke off.
Hi, there are pivots bolts on the alternator, power steering pump, and A/C compressor (if you have one). Depending on which belt is broken, you may have to remove outer belts first to install inner belts. To remove a belt, you have to loosen the pivot bolt on the accessory as well as the adjusting bolt. The accessory will then pivot to loosen the belt. To install a belt, again loosen the pivot and adjusting bolt, install the belt, and then carefully use a pry bar to pivot the accessory to tighten the belt. While holding the belt tight, tighten the adjuster screw and then the pivot bolt.
Please let me know if you have more questions, and thanks for using FixYa.
Aug 21, 2011 | 1988 Ford Bronco II
My lcd monitor have red lines
Try altering your display resolution in all its variables.
If the monitor has a menu, try altering RGB settings, contrast and appearance settings. If this does not work, most likely a hardware screen failure.
Jul 26, 2011 | BenQ FP992 19" LCD Monitor
How do you take the alternator off for a 96 plymouth neon
For REMOVAL & INSTALLATION check this procedure...
  1. Disconnect the negative battery cable.
  1. Loosen, but do not remove the alternator adjusting nut.
  1. Turn the front wheels completely to the right, then raise and safely support the vehicle.
  2. Unfasten the retainers, then remove the plastic lower splash shield.
  1. Unfasten the alternator field circuit wiring connector. You must squeeze the locking tab to release it.
  1. Remove the B+ terminal nut and wire.
  1. Loosen the alternator pivot bolt, but do not remove it.
  1. Remove the alternator drive belt. The alternator spill shield does not have to be removed.
  1. If necessary, remove the bottom pivot bolt and anti-rotation tab.
  1. Unfasten the three mounting pivot bracket bolts, then remove the pivot bolt and bracket.
  2. Holding the alternator in one hand, remove the adjustment nut then slide the alternator off the T-bolt. The T-bolt does not have to be removed. Lower the alternator and remove through the wheel well.
To install:
  1. You may need to use a C-clamp to drive the sleeve into the mounting ear for installation clearance.
  2. Position the alternator in the vehicle, sliding it onto the T-bolt. Install the adjusting nut.
  3. Install the bracket and pivot bolt, then install the three mounting pivot bracket bolts. Tighten the bolts to 40 ft. lbs. (54 Nm).
  4. If removed, install the anti-rotation tab and bottom pivot bolt hand-tight.
  5. Install the alternator drive belt.
  6. Tighten the alternator pivot bolt to 40 ft. lbs. (54 Nm).
  7. Install the B+ terminal wire and nut. Tighten the nut to 75 inch lbs. (9 Nm).
  8. Attach the alternator field circuit wiring connector, making sure the locking tabs are engaged.
  9. Install the splash shield, then carefully lower the vehicle.
  10. Tighten the adjusting nut.
  11. Connect the negative battery cable. Adjust the alternator belt.
Hope helps.
Jul 16, 2010 | 1996 Plymouth Neon
How do i replace the alternator?
  2. If equipped with a pulley cover shield, remove the shield at this time.
  3. Loosen the alternator pivot bolt. Remove the adjustment arm to alternator bolt. Pivot the alternator to gain slack in the drive belt and remove the belt.
  4. Disconnect and label (for correct installation) the alternator wiring. NOTE: Some models use a push-on wiring connector on the field and stator connections. Pull or push straight when removing or installing, or damage to the connectors may occur.
  5. Remove the pivot bolt and the alternator. Fig. 1: Alternator harness connections 86753014.gif
    Fig. 2: Remove and set aside the alternator belt 86753300.jpg
    Fig. 3: Remove the alternator pivot bolt 86753301.jpg
    Fig. 4: Tag and disconnect the wiring harness connector 86753302.jpg
    Fig. 5: Remove the alternator when it is completely detached 86753303.jpg
    To install:
  6. Position the alternator assembly onto the vehicle. Install the alternator pivot and adjuster arm bolts, but do not tighten them at this time.
  7. Install the alternator drive belt and adjust the drive belt tension.
  8. Once the proper belt tension is reached, tighten the adjuster bolt to 24–40 ft. lbs. (33–54 Nm) and the pivot bolt to 40–50 ft. lbs. (54–67 Nm).
  9. Reconnect the alternator wiring.
  10. Install the pulley shield, if equipped.
Jul 11, 2010 | 1989 Ford Taurus
Removing windshield wiper assembly ford excursion
Wiper Pivot Arm Removal and Installation
  1. Lift the windshield wiper pivot arm to the full upright position.
  1. Remove the windshield wiper pivot arm.
    1. Release the locking tab.
  1. NOTE: During installation, it is necessary to pull the locking tab out to its full open (unlatched) position and hold while assembling the pivot arm onto the mounting arm and pivot shaft. Align the key on the pivot arm head with the keyway on the shafts. This will make sure the pivot arm is correctly aligned. If necessary, the key can be removed. To adjust wiper pivot arms, refer to Wiper Blade and Pivot Arm Adjustment in this section.
    To install, reverse the removal procedure.
Jul 02, 2009 | 2005 Ford Excursion
Installing a stering pivot door
on the pivot side, the seal will go toward the outside,.providing that the seal is on the door,...the seal "on the pivot side of the door" will go up against the wall jamb as you close door,.....
Jun 20, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Monitor Help
Two things: one, the pivot may be really tight and therefore doesn't move easily. Two, the pivot on that monitor doesn't have much range. It ranges from looking slightly downward, to slightly upward. The pivot will give before you break anything so long as you're not trying to force it past the limits.
May 03, 2009 | Computers & Internet
Gateway FPD2275W LCD Monitor Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
