Question about Acer Aspire One PC Notebook
Menu bar has disappeared when turned on. How do I make it visible again?
  • villads430 Nov 17, 2009
    Thx for responding so quickly. Pressing cntrl button doesn't do anything. No programm is running as literally turned on. Can't connect to www as normally need to select option on menu bar to change 'EU' icon to 'UK'. The other unusual (and new) issue is a grey rectangle on screen with a 'sundial' icon in the middle. When hover mouse over it states "New Item. This item has not yet been configured" ??
  • 11,896 Answers
Press the cntrl button to make it appear. If you are using firefox or internet explorer there are options under tools, options, settings to make it stay all the time. Which program are you using?
Posted on Nov 17, 2009
Tip
How to make the taskbar reappear when it disappears in Windows
Sometimes on a computer running Windows, an application will crash or an unstable process will lock up the system, and out of nowhere the taskbar that runs across the bottom of the screen will disappear. The rest of the desktop and all of your icons will probably still be visible -- it's only the taskbar that is gone. Without the taskbar, you can't access the Start menu or view the open programs in your system notification tray.
To get your taskbar and Start menu back without shutting down your computer, hit <CTRL><ALT><Delete> and then (depending on the version of Windows that you are running) choose the appropriate option to open the Task Manager. (In Windows XP Professional, for example, there is a button labeled "Task Manager".) When the Task Manager window appears, select File from the menu bar and then from the drop down menu click on "New Task (Run)". Type "explorer.exe" into the text bar and hit <Enter>. Windows will sort of "reset" itself, and the taskbar and Start button will reappear. (This may take a minute.)
Whatever caused the system to become unstable in the first place could easily happen again, so at this point it's a good idea to save any unsaved data, close all open applications, and then shut down and reboot your computer. If the same problem happens again, make a note of which programs you were running when it occurred, as it may be a resource conflict or compatibility issue that's causing the problem.
on May 27, 2010 | Computers & Internet
Tip
Address bar and tools menu not seeing in Mozilla Firefox
You might have faced issue like not seeing address bar and tools menu in Mozilla Firefox sometimes. You might bit embarrassed by this. Here is the simple way to get your address bar and tools menu bar in Mozilla Firefox
Mozilla firefox will like this when the address bar and tool menu disappears
Now you need to press ALT Key on key board.Now you can see the tool bar and menu bar. To keep this settings, right click on VIEW option and Check options like Menu bar, Navigation Toolbar and Bookmarks Toolbar.
on Mar 02, 2010 | Mozilla Firefox
Why were start menu and task bar lost?
Hi B.G.R.,
Have you tried
Pressing ALT or F10 in your keyboard to make the Menu Bar temporarily visible. If you want it to be permanently visible, go into View > Toolbars > Menu Bar, or right-click the Navigation Toolbar (the Reload button, for example) and select Menu Bar.
If this doesn't help, right-click the navigation toolbar, select Customize... and click Restore Default Set. If it doesn't appear right away, try pressing ALT or F10. You can go into View > Toolbars > Menu Bar to make it permanently visible, or right-click the Navigation Toolbar and select Menu Bar.
Sep 12, 2015 | Computers & Internet
Mac os x lion 10 7 5
Sounds like you may need to reinstall Lion to fix the disappearing menu bar. As far as finding files, try using Spotlight. (Upper right side of menu bar)
Jul 25, 2013 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I deactivated the Safari Menu Bar and I'm not able to make it visible again! I can only see the book mark bar. What shall I do?
Open safari. On the right top corner you will see the settings icon. Click on it and select the second option that is "Show Menu Bar"...... I have attached the screenshot of it...which may help....cheers:)affaf61.gif
Sep 24, 2010 | Apple safari
Lexmark x9350 will not copy or scan.
Great job on trying to do it both ways, scanning and copying. Try to refresh the printer by uplugging the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Make sure other end of the power cord is plugged in straight to the power outlet in the wall, bypass any surge device or power strips. Plugged the power adapter back in the printer after 30 seconds. It should automatically turn on. If not, press the power button. Try scanning and copying again. If problem persists, I strongly suggest you contact Lexmark Technical Support to further investigate the hardware problem in the printer. Hope I can assist you more on this.
Jun 29, 2010 | Lexmark X9350 All-In-One InkJet Printer
Tool bar for computer gone how do i find tool bars in my computer
"FILE, EDIT or VIEW" options on the top.
  1. Open Internet Explorer, and make sure that it is running properly. If you receive any error messages upon opening it, your best bet is to reinstall Explorer rather than customize the options as new add-ons have likely caused serious problems. If it runs properly, however, continue to the next step.
  2. Check to see that the menu bar is visible. If the menu bar is missing, you will have to make it reappear. Right-click anywhere below the "Title Bar" (the bar which shows the Internet Explorer icon and the name of the current website) and any other visible menu bars. Then be sure that the "Menu Bar" has a check mark beside it on the window that appears. Click "Menu Bar" if there is no check.
  3. Click on "View" in the menu bar. Then click on "Toolbars" from that menu. This will bring up a list of available tool bars. To make the one you want appear, simply click its name, making sure that a check appears next to the name.
  4. Restart Internet Explorer. Some toolbars will reappear immediately. Others require a restart. But restart the application anyway to make sure that your new preferences are saved.
  5. Reinstall any extra toolbar applications if they do not appear in the Toolbar menu.
Please try this and see if anything help's.
Jun 15, 2010 | Microsoft Windows Vista Home Basic for PC
Where is the toolbar? Why did it disappear? How can I get it bck complete with printer???
Are you asking about your browser toolbar? In Internet Explorer, if the menu bar isn't visible click <Alt>. Go to View > Toolbars. Make sure the items you want have check marks. The printer icon is part of the Command Bar. Once done, check the line Lock the Toolbars. This will eliminate the vertical dotted line next to each Toolbar. When you click on that line, the toolbar disappears.
If you are dealing with another application, you need to do something similar. However, the names and location in the menus may be different.
I hope this helps.
Apr 13, 2010 | Sony VAIO PCV-W600G PC Desktop
HOW,DO I RESTORE MY TOOLS VIEW FILE HELP BUTTONS
You don't write in which application did your menu bar disappear.
Perhaps you entered "full screen mode", which removes menus and stuff to maximize the viewing area. Depending on application, try F11 key on the keyboard or F9.
If this is not the case, then perhaps you have accidentally dragged the menu bar somewhere - in new applications the standard "File/Edit/View...." menu is movable.
In Internet Explorer you might have turned the menu off by accident. Right-click the menu area, and you will see a context menu, showing a list of bars/strips that are enabled (with a checkmark) or disabled (without). If you see something else, choose a slightly different spot to right-click. If the option "Menu bar" is not checked, just click it and the menu should appear.
Nov 18, 2009 | Audio Players & Recorders
Acer Aspire One  PC Notebook Logo
139 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
