Question about Lutron Dimmers S103PNL 1000W 3-Way, Preset Dimmer with Nightlight White Sky
I'm attempting to wire a 3 way switch with a dimmer
I'm attempting to wire a 3 way switch with multiple lights and a dimmer. I followed the diagram supplied by the dimmer switch and it seems to work except for the fact the the non dimmer switch only works when the dimmer switch is turned on. I need to find a solution that will allow both switches to turn the lights on and off.
    President:
  • 704 Answers
Hello Chris,
What has happened, is that you've got th two "traavelers" reversed on the plain toggle switch. These are the RED and BLACK wires. turn off the power and reverse the position of these wires and the switch should work correctly from either the Dimmer switch or the plain switch.
Here's a link with a diagram, which might not exactly match your circuit configuration, but you can also watch a short video that explains how 3-way switches work.
It is just a matter of getting the travelers on the correct screws in order for the circuit to operate properly from either switch. Also, depending on the type of dimmer you've installed, the other switch will only turn the lights on at the dimmer setting that you've left the dimmer switch in. So be sure that you're not turning the dimmer all the way down before you shut it off (at the dimmer) otherwise, the other 3-way switch won't be able to turn the lights on, regardless of whether you've got the travelers in the correct locations.
Remember to turn the power off to the circuit you're working on while you rewire it and flip the breaker back on when you're done.
http://www.electrical-online.com/3waydiagram.htm
Hope you find this Very Helpful and best regards!
Posted on Nov 17, 2009
How to wire a two way switch for a staircase
Copy following link for 3-way switch wiring diagram:
http://waterheatertimer.org/How-to-wire-switches.html#3-way
Add a comment and say if you are adding a 3-way switch to existing single-pole switch.
You need 3 wires running to new 3-way switch.
Mar 16, 2013 | Electrical Supplies
Westinghouse fan wiring diagram
Copy following link for general assistance wiring 4-wire ceiling fan switch:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Jul 14, 2012 | Electrical Supplies
How to wire residetial light switch
Open following link for diagrams showing basic single-pole and 3-way wiring diagrams:
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
May 29, 2012 | Electrical Supplies
Three way electrical switch diagram
Copy following link for 3-way switch wiring diagrams:
Dec 06, 2011 | Electrical Supplies
Load between 3 way switches and line entering switch box. Breaker trips when both switches in down position
Test your wires.
Somehow you've got a neutral wire, or ground wire, or shorted wire connected to one of the switches.
Without a wiring diagram, best place to start is identify hot wire from breaker.
There should be only 1 hot wire connected to the switches.
Disconnect the hot wire. Then test hot wire to each other wire and screw terminal. Tester will light up on neutral or ground fault. That will narrow down the suspects.
Open following link for example 3-way wiring diagram:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-way
Aug 22, 2011 | Electrical Supplies
77020 fan switch dont turn off. i need a diagram please...
Copy following link for wiring 3-speed fan switches
May 25, 2011 | Speed Ceiling Fan 3-speed Switch By...
I HAVE A DIMMER SWITCH BUT NO MANUAL AND I THIN ITS MISSING A WIRE
A standard dimmer switch only needs two wires plus ground, just like a standard switch. If you are replacing a three-way switch with a dimmer, then you need a three-way dimmer switch (which has three wires). 4-way switches have 4 wires. Note, with 3-way or 4-way switches you have multiple switches controlling the same light, but only one of them can be a dimmer. good luck, Al K
Jan 19, 2011 | Garden
I want to wire a 3 way switch with multiple lights between the switches. The easiest route and least wire used is power in at switch then to lights then down to second switch. would i use a 14/3 from...
You have to run the 3rd wire all the way to the switch, whether it hits any lights or not, I have seen electricians pull a single wire in to the box with the 14/2 and that would be the jumper. This will work on any lights, and the lights only need the 2 wires, It is just the switch that needs the 3 wires. Good luck.
Feb 22, 2010 | Lutron Dimmers S103PNL 1000W 3-Way, Preset...
How to wire 3 switches in a 3 gang box
WARNING: Do not attempt to do this work unless you completely understand the information provided below. If in doubt call an electrician.
Always make sure the power is disconnected from all possible sources before making any connections. Your description of the problem indicates that there may be multiple power wires coming into the same box. In that case local codes may require that the box be partitioned to prevent exposure to voltages up to 220 volts.
You need to determine where each wire goes to know how to connect them together. You cannot rely on color alone. If the power supply runs through the box to the loads then most (but probably not all) of the white wires will be connected together. If the power runs to the load boxes first then none of the white wires in the switch box should be connected together. They are used to run the switched/dimmed power back to the loads (and should be taped to cover the white in the box). In that case each switch has its own power input and they should not be tied together. A wire (could be black or white with black tape) brings power from the load box, gets connected to the input terminal of the switch and the corresponding black wire carries the switched power back to the load. The fan/light switch will have one power in and a switched power out for the fan and another for the light. The 3-way will have one "power" in (or it could be the final power out to the light) and two "carrier wires that connect to the other 3-way switch. If the power supply goes through the switch box then there will be at least 10 wires in that box. In that case see the attached diagram: a5fa64a.gif
Sep 23, 2009 | Cooper Industries Cooper Wiring 2158V 3...
Lutron Dimmers S103PNL 1000W 3-Way, Preset Dimmer with Nightlight White Sky Logo
459 people viewed this question
Top Lutron Electrical Supplies Experts
Steve
jdthefixer
ken skalski
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
