Ignitor willnot ignite but im getting 120v to it, is my ignitor bad and is there a safety switch on the door that may b bad ? stove top works fine
  • 1,543 Answers
No door safety switch. Replace ignitor. (an older ingitor may glow, yet still not draw enough amperage to open the gas valve)
Posted on Nov 17, 2009
The igniter will come on but no gas, the broiler and stove top both work. I'm and hvac service tech and need some help.
you will either have a weak ignitor or you have a bad safety valve, but before you go buy any thing take the igniter from the broiler and install on the bake and see if works, if works you know it is the igniter, if not it will be the safety valve (fyi you can also turn on oven, then when igniter gets really orange you can tap the safety valve and if it ignites it will be safety valve)
Feb 24, 2011 | Microwave Ovens
Burners will ignite. No spark.
This stove works on the DSI system: Direct spark ignition. The safety valve works on DC volts but the ignitors work on AC volts. The oven valve has 3 terminals. All must have continuity with each other. If you cannot get a reading between any 2 of the 3 terminals then the oven safety valve is bad. The spark module is fine because the top works so I would say it is that valve.
I have a service manual and more HERE
Thanks for using FixYa
Jan 07, 2011 | Whirlpool GS460 Gas Kitchen Range
Oven appears to start, takes forever to preheat,
This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
Feb 26, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
Gas stove with electric ignition (oven stopped working)
the electric ignition is bad and needs replaced in oven. I had the same problem a few months ago and it was the ignitor for the oven. if replacing it yourself, be very careful with ignitor, it is very fragil. do not touch ignitor itself, hold on to it by the base of it. they are not that hard to change.
Jan 31, 2010 | Kitchen Ranges
Stove top gas flow and gas oven bake cycle not igniting
This most likely is the solution for the bake problem you have:
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Jan 05, 2010 | GE Profile JGP636 Gas Cooktop
Whirlpool gas oven sf315pemb1- oven not heating
Hi, It sounds like the ignitor has gone bad. Remove the floor panel in the oven and locate the ignitor fastened to the burner. There should be 120V going to the ignitor harness.
If you have voltage but no ignition, change the ignitor.
I hope this helps you. Please let me know if I can assist you further.
Vic
May 27, 2009 | Whirlpool GS445LELS Gas Kitchen Range
Stove top works oven wont heat on 465
the ignitor needs replacing, that's the glow that you see. it's not getting hot enough to open the safety valve.
Dec 07, 2008 | Whirlpool GS460 Gas Kitchen Range
Stove Top Ignition will not turn off
all ignitors lite thats the way the stove works thats a safty feature..but im thinking your question is they wont go off,,if thats the case replace spark module...if not im here onthejob
Dec 04, 2008 | Whirlpool SF367 Gas Kitchen Range
Top oven bake igniter comes on, but gas does not.
Check the voltage on the 2 wires going to the oven gas valve. If you get 120v when the ignitor is on with no gas coming out, you have a bad gas valve. If you get voltage, but it is not much, it is the ignitor. The ignitors don't burn out completely on the ovens, they just get a little dim and no longer ignite the gas and eventually will not turn on the gas valve
Dec 19, 2007 | Amana AOGD2750 Gas Double Oven
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
