Question about Plumbing
Water came out both shower head and tub spout (even w/o spout)
I installed Moen 82244HH Series with one handle tub/Shower valve. The problem is water comes the shower head even the tub spout is removed (only the pipe from on the wall. Water temperature mixture is correct, the handle turns CCW to ON and CW to OFF. I don't think I installed the valve upside down but how do I confirm/check this. What's the problem?
Pat
  • 21 Answers
The shower valve is clearly mark "UP" when you look at it from the front.
Posted on Nov 27, 2009
Testimonial: "That's right"
  • 119 Answers
Remove the round chrome sleeve tube to check the cartridge clip the clip removes from the top of the valve it sounds like the valve is upside down
Posted on Nov 23, 2009
I installed a Moen L2353E tub/shower faucet and water won't come out of shower head
Couple of ideas: If you don't get water at all first check to see if the shut-off valves are open. If so, close them and remove and clean the cartridge. If water comes from the spout and not the shower head, make sure the diverter (the handle on the tub spout) moves up when you pull it. If that works, remove and clean the shower head since there might be debris blocking the water flow. Without
more info this is my best guess.
Apr 07, 2015 | Moen & One Handle Tub & Shower Faucet
Water leak thru valve when turn to shower
a lot of shower diverters do this..you may need a bigger seal on the diverter..if you can remove the spout assembly from the tub(with the diverter valve in it) and take it all to the hardware store.. see if they have a different seal/diverter that has a snugger fit but still falls to drain the shower head line out..that will slow that leakage..the spout is on a pipe and unscrews counter clockwise(normally)unless its a single valve unit..with the wide ring around the back..then that calls for a plumber..
Jan 21, 2014 | Moen & Bayhill& Single Handle Tub & Shower...
We have installed a moen 82490 one handle tub & shower unit. When we turn on the water you could shower and bath at the same time. If you pull the plug for just a shower the water to the spout stops...
If you pull the silver knob on the tub spout up, the diverter located located inside will redirect water up to the shower head and when lowered it will return the water to the tub spout. It sounds as thought the diverter is not working properly. Hope this helps..
Mar 08, 2011 | Moen & One Handle Tub & Shower Faucet
Moen Shower Valve Model L82839 installed: Water comes out of shower head when running bath. Thanks.
Only two possibilities here the diverter tub spout is not open all the way to let water to the tub only or the shower valve is installed up-side-down.
http://www.moen.com/shared/pdf/l82691pt.pdf
Mar 06, 2011 | Moen & Posi-Temp Single Handle Shower Or...
I have a Moen tub and shower system similar to the Moen 2919 Chateau two handle above. When I turn on the faucets up to 1/2 way everthing works fine. If I try to increase the water capacity by turning up...
To talk about your problem forces me to assume a few things.....If you allow the water to flow without cartridges and handles, the water must be flowing straight through the cartridge channels and out into the tub. It is not flowing through your tub spout or shower head when you test the water this way. If I'm correct, then the problem is isolated to the water mix operation. That means coming out of your spout or shower head. So now I have to ask a question. When you operate as normal (cartridges and handles installed) does your problem show up only on your shower head or does it also show up when operating out of the tub spout? If the problem is isolated to the shower head, try a head replacement. It may be partially plugged. If it's head or spout there may be something in the mixing pipe that only shifts around as pressure increases. I hope that is not your problem. It would require pulling those pipes out for inspection and most likely replacement. Nimsgame
Feb 19, 2011 | Moen 2919 Chateau Two Handle Tub and...
On new Moen shower faucet, when I turn on faucet, water drips from shower also.
The faucet was installed upside down.
The shower riser pipe in the wall is to short( the distance between the faucet and shower head).
One of the biggest problems is if your shower faucet was installed with Pex pipe to the tub spout. Pex pipe will restrict the flow and force the water back up and out of the shower head.
The tub spout must be piped with at least 1/2 brass pipe nipples and fittings, or 5/8 OD. copper pipe and fittings.
Hope this helps, if you further questions please let us know.
Sep 08, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Moen shower valves are failing
the diverter is stuck. you have to move it up and down to free it up. the diverter is the mechanism attached to the tub spout that switches the water from shower to tub. you may also need a new diverter if fiddling with it doesn't work.
Jan 02, 2010 | Moen 3175 Legend One Handle Shower Faucet...
When the shower valve is engaged I still get water out of the tub spout and limited water out of the shower head. I just replaced the cartridge thinking that might be the problem but no luck
it sound's like you need to replace the tub spout.there should be a set screw on the bottom of spout loosen and twist off. replace with moen spout for ease of re-install.it's a real pain in the *** to try and replace -o- ring spout.
Dec 05, 2009 | Moen & One Handle Tub & Shower Faucet
Plumbing Logo
418 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
