Question about Car Audio & Video
Hand brake adjustment Volvo S90 1997
Can you please tell me where the hand brake adjustment is on a Volvo S90, Please dont tell me that I have to remove the center console,its a big job.
Thank you. Paul Mallia
From the bottom of car, look for the hand brake cable connected to rear wheel. Find the nut with bolt and loosen the bolt or tighten it.
Posted on Jan 11, 2008
    New Friend:
  • 83 Answers
Paul maybe you should try an automotive forum or site?
Changed brake shoes on Volvo s80 2.4 2000 but cant adjust them
The adjustment is on the emergency brake lever in the console.
Feb 17, 2015 | 2000 Volvo S80
My handbrake is not holding on a hill brakes seem fine I want to do it my self please help
YOU WILL NEED A HAYNES REPAIR MANUAL OR FACTORY MANUAL ON CD.BECAUSE ON BMW YOU HAVE TO REMOVE CENTER CONSOLE AND ARMREST TO GAIN ACCESS TO THE PARKING BRAKE LEVER. PARKING BRAKE CABLE CONSISTS OF TWO SECTIONS A RIGHT AND LEFT HAND SECTION, WHICH ARE CONNECTED TO THE LEVER.YOU HAVE TO LOOSEN REMOVE THE RELEVANT PARKING BRAKE CABLE LOCKNUT AND ADJUSTING NUT AND DISENGAGE THE INNER CABLE FROM THE PARKING BRAKE LEVER. IF YOU FIND A HAYNES BMW REPAIR MANUAL WITH HAND BRAKES.THAT WILL SHOW AND TELL YOU STEP BY STEP INSTRUCTION HOW TO ADJUST PARKING BRAKE CABLE ADJUSTMENT. I COULD TELL YOU HOW TO DO THE JOB. BUT YOU NEED TO SEE PHOTOS AND INSTRUCTIONS BECAUSE YOU NEED TO SEE WHERE YOU NEED TO MAKE CABLE ADJUSTMENTS.NOT EASY TO TELL YOU.
May 06, 2011 | BMW 325 Cars & Trucks
Tightening the handbrake
the first thing to do is to slacken the handbrake adjuster on the lever off completely.then if you have rear drum brakes remove the drums and make sure that the handbrake levers on the shoes are not siezed and are returning to the stops plus that the auto adjusters are not siezed if not free them off so they are using wd40 or whatever and the linings/drums are ok then reasemble and pump the brake pedal a few times to let the auto adjusters work then readjust the lever to about 5 to 7 clicks if you have got rear discs then one off the rear calipers may have siezed or both handbrake cables should also be checked for being siezed
Dec 23, 2017 | 1999 Nissan Maxima
Loyota Levin BZR rear hand brake adjustment
Try backing the car up while working the hand brake, Had this problem before on a customers Mazda.
Mar 06, 2010 | 1999 Mazda 626
Hand brake on volvo 960, 1996 does not hold.
remove the ash tray and holder from rear of praking brake cover.use a screw driver and hammer to tap sleeve to free from adjusting screw, now adjust the cable. hope this helps.
Jan 30, 2010 | 1996 Volvo 960
How to set up new brake shoes on volvo 850,they keep jamming when traveling forward but not reverse,
removedisc/drum check to make sure linings are secure on shoes bonding can fail this will cause brake to lock make sure shoes are secure on backplates hold down clips can go weak also make sure pull off springs are not weak loosen hand brake adjuster fit drum adjust up shoes on adjuster wheel till brake locked then back off so wheel spins freely re-set hand brake cable
Jan 24, 2010 | 1996 Volvo 850
How do you adjust the hand brake on a XC90 Volvo
how do you adjust hand brake on xc90
Jan 05, 2010 | 2004 Volvo XC90
Trying to find hand brake ajustment on a volvo 940 estate
remove panel at back of centre console you will see adjusterjcheck first if hand brake shoes can be adjusted in drum like on the 850 with wheel off and torch revolve disc if there is a an adjuster use this before adjusting cable
Nov 10, 2009 | Volvo 940 Cars & Trucks
Rear brake disc needs replacing
with car on stands use punch to remove pad retaining pins pull out pads can be tight remove 2 calliper retaining bolts move calliper away from disc remove disc retaining bolts remove disc check hand brake shoes and clean look for adjuster between shoes if it has one back it of some models just have hand brake cabel adjustment clean and fit new disc secure adjust hand brake shoes using screw driver through wheel bolt hole clean refit calliper slowley push back calliper pistons fit new pads refit retaining pins do other side pump up brake pedal check and adjust handbrake if neededcheck brake fluid level
Oct 20, 2009 | 2001 Volvo S80
Seized handbrake 1998 volvo xc70 awd
YOU NEED TO REMOVE THE BRAKE DRUMS AND CHECK WHERE THE PROBLEM IS, THE SHOE MAY BE SEIZED, TRY A LITTLE PENETRING OIL ON THE LINKAGE, NOT THE SHOE
Feb 18, 2009 | 2003 Volvo XC70
Car Audio & Video Logo
150 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
