Question about Yamaha Full-Size Keyboard
I need to remove the cover from my Yamaha DGX 505 Portable Grand Piano I've taken all the screws out and still can't get the cover off!
5 Suggested Answers
  • 1138 Answers
SOURCE: No sound when piano keys are pushed on my Yamaha dgx-620
I'm sorry but it sounds like you will have to have it repaired professionally.
Posted on Apr 28, 2009
SOURCE: What needs to be removed from my Yamaha YPG-625 to
DO NOT open the case unless you are aware of and comfortable with the fact that you could _destroy_ your piano. Easily.
Observe appropriate anti-static precautions. It should go without saying that this is an electronic repair, and dangerous voltages may exist inside the case.
1. Remove the stand if you have one
2. Lay the keyboard upside down (bottom up) on workbench
3. Remove all 90+ screws from the bottom of the chassis, including the 14 inside the speaker compartments
4. Carefully lift up on the bottom case part, taking not to damage the speaker lines
5. Unplug speaker connector and set lower case aside
6. LCD is mounted beneath main logic board
9in the center), my problem lies elsewhere, but competent and cautious service technique should lead you where you need. I would strongly recommend replacing the LCD assembly module, unless you are experienced in LCD repair.
Posted on Nov 08, 2009
  • 4234 Answers
SOURCE: I need to install a standard 1/4 phone jack in
What you are requesting will not work as you expect. The easiest way to achieve what you seek is to utilize what is called a Direct Box. This is essentially an external transformer that isolates the keyboard from any attached equipment (to eliminate grounding hum) and will allow you to conenct an XLR (low impedance) cable to the keyboard. I assume that you wish to attach the keyboard to some type of sound system which is likely to have standard XLR Mic inputs.
Update this with any additional questions that you have. Please note that using the direct box (about $20-$40) will be both the easiest solution as well as prevent the need to modify the keyboard.
Dan
Posted on Oct 19, 2010
rommelalilin
  • 2178 Answers
SOURCE: Can I connect a Yamaha DGX-500 piano to an
yes - use two RCA cables from the left and right audio output and connect it to the aux audio RCA inputs of an amplifier or receiver.
Posted on Dec 06, 2010
Where can I get a manual for portable grand D6X640 Yamaha piano
Do you mean the DGX-640? To my knowledge, Yamaha doesn't have a D6X line of keyboards. Most of Yamaha's manuals are available from their support page: http://download.yamaha.com/top/?site=usa.yamaha.com&language=en . The DGX-640 support page is http://download.yamaha.com/search/product/?language=en&site=usa.yamaha.com&category_id=16084&product_id=1056822 . Scroll down to find the owner's manual in various languages and other documents. Yamaha provides javascript links to the manuals on the site; these do not resolve to specific direct links in my browser history.
I hope this helps.
Apr 25, 2017 | Yamaha Music
I need access to the keyboard mechanism ofa yamaha dgx 640 piano.How to unmount the black wooden panel to get access without causing any trouble.
Hopefully the attached will let you remove the base correctly.
Message me if you need more information.
Apr 18, 2016 | Yamaha Music
How do i open case to repair power supply
dgx screws are so many..u have to open the speaker covers there are other screws inside...which u can only access by oppening the speaker back cover...you will also have to open the silver screws..all of the behind the cover..all this u r doing when you have separated it from the stand. place it on a mattress in need be to avoid accoustic wear.
Sep 25, 2014 | Yamaha DGX630 - Digital Piano
How do i reset the keyboard to factory settings? It sounds really weird right now
You can normally reset Yamaha keyboards by holding down the highest note while turning on. If you want to do a full factory reset see below - remember this may delete all songs etc you have saved to the keyboard memory.
decdbba2-706f-4a8a-afd1-ac3a6264c7f4.jpg dcd670d5-cf98-45e6-87a4-0591820eb4ef.jpg 2c144414-99a6-4025-960d-eaef496036a3.jpg
Jul 20, 2014 | Yamaha DGX-230 Portable Grand Piano
3 key notes not working and can't write my savings to the banks..
Hi, You can reset your whole keyboard by holding down the top C ( highest key ) whilst turning on.
This is unlikely to clear 3 non working keys. My guess is that the contacts under the rubber switches have worn or dust is under the contacts. You could try cleaning first under the rubber contacts if this fails replace the contacts ( 1 per octave ) Part WF212202 contact me if you need more information
Pictures attached may help 0482dd26-e9cb-4b61-b47e-f97d90aa782c.jpg 42e5c956-fedc-40b9-ae04-8bf3e98b22a2.jpg
Mar 28, 2014 | Yamaha DGX-640 Portable Grand Piano...
I have a new DGX. My problem is when I want to add a dual voice to the piano. I press the portable grand button then hold the dual button till the violin voice appears then select the voice I want and...
HI, Let me answer the question.
1) Select the DUAL VOICE (not portable grand ) button and hold for longer than 1 second.
The choose voices required.
If you press the Portable Grand button this resets the keyboard top a piano.
I hope this helps
Dan
May 19, 2017 | Yamaha DGX 640 Keyboard Arranger
The display screen for my DGX 500 is blinking on and off and is unresponsive.
Do you mean,"The HOUSE power went out" or, "The keyboard power went out"?
Mar 20, 2012 | Yamaha Music
A message came up briefly when I turned the Yamaha DGX-203 keyboard on that read "Allmem - Clr" and all my users songs were deleted. Is there anyway to get them back and prevent this problem in...
Contact Yamaha directly. Parts Consumers Support: By Phone: Monday through Friday
8:30 am to 5:00 pm Pacific Time
Tel:(888) 892-6242
After hours or weekends
Tel:(855) 322-3309
Here's a link to a third-party owner's manual
https://www.manualslib.com/manual/539184/Yamaha-Portable-Grand-Dgx-205.html
Jan 19, 2018 | Yamaha Dgx203 76Key Portable Keyboard
Yamaha Full-Size Keyboard Logo
484 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
