Question about RIM BlackBerry Pearl 8100
Where do I get my blackberry off CAP - RIM BlackBerry Pearl 8100
    Scholar:
  • 173 Answers
In your Handheld on the lefthand side you will find CAPS key with the arrow mark, If you press that the CAPS will be Off.
Posted on Nov 18, 2009
Blackberry bold 9000 rebooting solution
If your BlackBerry Bold 9000 series device is frozen or not responding, you will probably want to reset the unit. Here are the different types of resets that can be perfomed in the order they should be tried.
Soft Reset
Press ALT + RIGHT SHIFT(CAP) + DELETE.
Double-Soft Reset
Press ALT + RIGHT SHIFT(CAP) + DELETE . The screen will go blank for a few seconds. When the screen comes back on, immediately press ALT + RIGHT SHIFT(CAP) + DELETE again.
Hard Reset
If none of the above works, pull the battery out of the unit for a few seconds, then reinsert it.
May 13, 2011 | RIM BlackBerry Bold Smartphone
Tip
How to reset your Blackberry
Performing a soft reset stops all applications on the BlackBerry device by pressing the ALT+RIGHT SHIFT(CAP)+DELETE keys. A soft reset re-establishes communication between the BlackBerry device and the computer.
Performing a double-soft reset stops all applications on the BlackBerry device and is nearly the equivalent of a hard reset. Timing however is critical. Perform a soft reset by pressing the ALT+RIGHT SHIFT(CAP)+DELETE keys. The screen will go blank. When the screen is no longer black, press the ALT+RIGHT SHIFT(CAP)+DELETE keys again. You should then see another blank screen followed by an hour glass.
The first step in troubleshooting a networ, software or hardware error is often to perform a hard reset. With Java® based devices, this is accomplished by removing the battery, while the BlackBerry device is powered on. Hold the battery out for about 30 seconds, and replace. The BlackBerry device will reboot.
on Apr 17, 2010 | Cell Phones
I locked my phone. Every time I unlock it I would have to put my password in. I put my password in, and it said incorrect. I know it was correct, I don't forget my password. So I kept trying it and trying...
You will need to reset the phone for everything to return to normal. I would advice you perform a double soft reset, though it is a bit tactical. Performinga SOFT reset on the BlackBerry device Performing a soft reset stops allapplications on the BlackBerry device by pressing the ALT+RIGHTSHIFT(CAP)+DELETE keys. A soft reset re-establishes communication between theBlackBerry device and the computer.
Performinga DOUBLE-SOFT reset on the BlackBerry device Performing a double-soft reset stopsall applications on the BlackBerry device and is nearly the equivalent of ahard reset. Timing however is critical. Perform a soft reset by pressing theALT+RIGHT SHIFT(CAP)+DELETE keys. The screen will go blank. When the screen isno longer black, press the ALT+RIGHT SHIFT(CAP)+DELETE keys again. You shouldthen see another blank screen followed by an hour glass. HOPE THESE HELPED
Apr 24, 2011 | RIM BlackBerry Storm 9530 Smartphone
My bb is getting rebooting
If your BlackBerry Bold 9000 series device is frozen, rebooting or not responding, you will probably want to reset the unit. Here are the different types of resets that can be performed in the order they should be tried.
Remember your data will we wiped. So make a backup.
Soft Reset
Double-Soft Reset
Hard Reset
Mar 12, 2011 | RIM BlackBerry Bold 9000 Smartphone
My blackberry torch just suddenly stop working the screen after 7days from my purchase date the screen turned to black while i can see the keyboard has lights.
It may be locked up. Take the battery out for about a minute and then put it back in. If it boots up and works you are fixed. If that doesn't work there are other resets:
Soft Reset
Double-Soft Reset
If none of that works a data wipe and reset is indicated:
1. From the home screen, press the Menu button.
2. Select Options.
3. Select Security Options.
4. Select Security Wipe.
5. Check the items you wish to wipe.
6. Type blackberry in the box.
7. Select Wipe.
Follow the instructions.
If that doesn't work its fried and I hope its still under warranty
Jan 27, 2011 | RIM BlackBerry Torch Cell Phone
CAP is in the top right hand corner of my blackberry pearl 8100 and I cannot write a number to dial it. I can only dial a number from the address book.
In this case kindly Press the ALT key in your Handheld and the CAP will turn off from your Handheld and you will be able to Dial the number.
I hope I was able to help.
thankyou for using Fixya.
Nov 04, 2009 | RIM BlackBerry Pearl 8100
Need to get back a default software/application but how?
Resetting the BlackBerry device is a useful way to resolve issues and is usually the first step in troubleshooting the BlackBerry device. Knowing the differences between a hard, soft, double-soft, and master reset ensures that the correct troubleshooting method has been chosen. Note: Backup all applications before resetting the BlackBerry device using the Backup and Restore tool on the BlackBerry Desktop Manager.
Please follow the below steps or resetting
Performing a SOFT reset on the BlackBerry device Performing a soft reset stops all applications on the BlackBerry device by pressing the ALT+RIGHT SHIFT(CAP)+DELETE keys. A soft reset re-establishes communication between the BlackBerry device and the computer.
Note: This does not apply to the BlackBerry® Pearl™ smartphone.
Performing a DOUBLE-SOFT reset on the BlackBerry device Performing a double-soft reset stops all applications on the BlackBerry device and is nearly the equivalent of a hard reset. Timing however is critical. Perform a soft reset by pressing the ALT+RIGHT SHIFT(CAP)+DELETE keys. The screen will go blank. When the screen is no longer black, press the ALT+RIGHT SHIFT(CAP)+DELETE keys again. You should then see another blank screen followed by an hour glass.
If you liked my response Please do Rate this solution.
May 04, 2009 | RIM BlackBerry Bold 9000 Smartphone
Blackberry pearl
Try holding these keys simultaneoulsy.
ALT+RIGHT SHIFT(CAP)+DELETE Until you get a blank screen then power on.
Failing that power off, remove your battery for 30 seconds and then power on.
Feb 08, 2009 | RIM BlackBerry Pearl 8100
Blackberry reset
Check out this link. http://uis.georgetown.edu/hardware/blackberry/bb.trouble.html
May 30, 2007 | RIM BlackBerry 7250
RIM BlackBerry  Pearl  8100 Logo
87 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
