Question about AOpen i915Gm-PL (918EM10I13) Motherboard
Computer freezes after inserting usb stick
I915gm-pl Computer freezes after inserting usb stick using windows xp.
  • 329 Answers
If you are inserting it in front panel then try using it in other ports at the back if the it still hangs your system try usb stick in other pc....if it works well in other pc then you need to install chipset driver and usb driver....
Posted on Nov 19, 2009
Re MiBody 360 Personal scale. downloaded software successfully (Windows XP) inserted USB into scale and stepped on . waited for a few seconds then put USB in PC but no data transferred (PC recognised USB...
Make sure that you have selected USR1 each time you weigh yourself.
When you stand on the scales it records your measurements against that user ID and holds them in the internal memory of the scales.
When you have taken a few readings and when you are not standing on the scales, insert your USB memory stick (any memory stick will do) and press the SET button. The scales display "USB" and write the data out to the memory stick and gives you a message "END" afterwards. When you insert the memory stick into your computer you can read the data into the Homedics software
Aug 26, 2013 | Health & Beauty
Tip
Acer One's and More "Making working Windows copy to USB Stick"
Directions for Making Usb OS for windows 98,me,xp,2000,2003
You will need to saerch for a little program called Komku-SP-usb so get going and also a working computer with an actual cd/dvd rom drive.So if you need go use your buddys computer.
After you found the program as stated abovce download it and follow the rest of these directions I have left. Curtosy of someone else of course.
1.Open and install Komku-SP-usb on a working computer other than your Acer One.
Make sure that the Usb Stick you may be using has at least 2GB.
2.Locate folder C:\Komku\PeToUSB\ and double click PeToUSB.exe
3.Select USB Removable,make sure enable disk format and enable disk format are all checked.
If you feel the need you may put something to name your usb in the drive label area.And uncheck
enable file copy if it is checked.
4.Click Start
5.Click Yes
6.Click Yes Again
7.After Operation complete you can exit out of that program.
8.Next open Ms Dos command promt.Click Start > Run > type cmd > click OK
9.On Command Prompt window, go to directory C:\Komku\bootsect\
how to do this?
first type this cd\ and press Enter
10.then type cd komku\bootsect and press Enter
11.on command prompt window, type bootsect /nt52 and whatever your drive letter is {Mine was H:}
12.press enter
13.now type this cd.. and press Enter
14.then type cd usb_prep8 and press Enter
15.type usb_prep8 again... and pres Enter
16.Press any key to continue and the usb_prep8 welcome screen will appear
17.now, insert your original Windows XP CD, or Windows XP with sata ahci driver to your CD/DVD ROM
and back to Command Prompt window
18.type 1 then press Enter and "Browse For Folder" window will appear, select your CD/DVD drive and click OK
19.the result... "XP Setup Source Path" changed to G:\ (yours may be different)
20.now for point 2, if letter T is currently assigned to a drive in your computer,
you must change it.... if not, leave it as it is
To change it type 2 and press Enter...
21.Enter Available Virtual DriveLetter"
for example you doesn't have drive S
so you type S and press Enter
back to usb_prep8 welcome screen...
now type 3 and press Enter...
22.Please give Target USB-Drive Letter e.g type U" Enter Target USB-Drive Letter:
because my Flash drive letter is H
23.so, type H and press Enter...
after back to usb_prep8 welcome screen...
now type 4 and press Enter to make new temporary image with XP LocalSource and copy it to USB Flash Drive
please wait a few seconds..
24.WARNING, ALL DATA ON NON-REMOVABLE DISK DRIVE T: WILL BE LOST! Proceed with Format (Y/N)?"
type Y and press Enter
please wait....
when format virtual disk complete, press any key to continue...
25.when you see "Making of LocalSource folder $WIN_NT$.~LS Ready"
26."Copy TempDrive Files to USB-Drive in about 15 minutes = Yes OR STOP = End Program = No"
Click Yes, and wait...
27.Would you like USB-stick to be preferred Boot Drive U: bla... bla..."
Click Yes
28."Would you like to unmount the Virtual Drive ?"
Click Yes, wait a few seconds, and press any key....
press any key again to close usb_prep8...
29.Now, insert your USB Flash Drive/Flash Disk/Thumb Drive to your notebook (e.g Acer Aspire One)
go to BIOS and make USB HDD (or USB ZIP in some other machine) as primary boot device....
30.then boot form your USB Flash Drive....
and select "TXT Mode Setup Windows XP, Never unplug USB-Drive Until After Logon"
31.After Hard Disk detected, delete all partition, create single partition...
and install Windows XP on that partition...
and wait...
32.once text mode setup is complete, computer will restart....
this time select "GUI Mode setup Windows XP, Continue Setup + Start XP"
33.Continue Windows XP setup.... and Done!
Windows XP Installed....
34.Remember, you can use this tutorial to install Windows XP on all other computers..
not just Aspire One and Asus EEE-PC....
on Jun 21, 2009 | Acer Aspire One AOA150-1570 Notebook PC
Windows - No Disk error when using 3G USB stick
Make sure it is formatted in FAT and not NTFS, also eject/unmount vs. unplugging it. Trying plugging the USB drive in the back of the PC's USB port instead of the front panel USB port.
Nov 17, 2012 | Microsoft Windows Xp Home Edition Sp2...
I'm trying to move files from old computer to new computer.
The easiest way is to use an USB memory stick, plug this USB memory stick into the XP computer and copy the files from the XP computer to the USB memory stick, then remove the USB memory stick and plug it into the Windows 7 computer and copy the files from the USB memory stick to the Windows 7 computer.
Jul 14, 2012 | Computers & Internet
How to transfer pictures from computer to camera memory card?
Below is how to transfer your photos incomputer to a memory stick in Windows XP operating system 1. Insert the memory stick into a compatiblememory stick reader. Plug the memory stick reader, with the memory stickinserted into it, into the computer's USB port. 2. After a moment, a screen thatsays "Removable Disk" will pop up and prompt you to take an action.Click on "Open folder to view files using Windows Explorer." Thiswill open the folders on the memory stick. Select and open the folder whereyour photos are stored. 3. With the memory stick folderand the photo folder open simultaneously, use the mouse to click-and-drag thephotos to the memory stick folder. 4. Close all folders and removethe memory stick reader from the USB port. 5. To ensure that your photos havebeen transferred, plug the memory stick back into the USB port. When the"Removable Disk" screen pops up, select "Open folder to viewfiles using Windows Explorer." Once you see the photos on the memory stickfolder, you can close the folder and remove the memory stick reader from theUSB port.
Jan 08, 2011 | Fuji FinePix J10 Digital Camera
'Please insert a disk in to the removable disk drive k"
Same thing happens to me .My 8gb silicon usb flash drive got the same error, please insert a disk into drive, the name of my drive weas changed into Removable Disk instead of the name(Sanctuary which is what i used) It said ni media ,and it was registered as XXXXXXXX U167CONTROL USB DEVICE can anyone help me with this.
Nov 25, 2009 | Electronics - Others
Need a free download for my sony cyber shot dsc-w55 to download pictures on my computer
You do not need any Driver or Software to transfer the images from the Camera to the Computer.
1. Set the USB Connection or Transfer mode setting in the Camera menu to Mass Storage or Normal .
2. Connect the Camera to the Computer using the supplied USB cable or any USB cable.
3. The Computer will recognize the Camera (make sure that the recording media containing the pictures (Memory Stick) is inserted in the Camera).
4. Click the Start button and then click the "My Computer" icon (for XP Operating System and for Vista or Windows 7 it will be "Computer" icon).
5. In the "My Computer" or "Computer" window, click the icon that represents the Camera.
6. Click the "DCIM" folder and drag it to the desktop screen of the Computer to transfer the images from the Camera to the Computer.
However, you may download the supplied Picture Motion Browser software for the Camera from this Link.
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=4598&mdl=DSCW55
Good Luck!!!!!!!!!!!!
Nov 18, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
USB Devices: Printer or Memory Stick freezes my XP sp2 on startup
Unplug the offending device(s) from the computer and start it normally. Log on as an administrative user. Open Device Manager. In the View menu, make sure that Show hidden devices is checked. Go through the list of devices and find the problem children. Right-click and select Uninstall for each of them. Reboot the computer. Plug in the devices one at a time and let XP reinstall the proper drivers.
May 29, 2009 | Western Digital My Book Essential Edition...
AOpen i915Gm-PL (918EM10I13) Motherboard Logo
407 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
Matthew Spark
Matthew Spark
David
David
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
