Air conditioner Getting a C6 error coding system shuts down why please?
  • 236 Answers
Remote control units have diagnostic program in the
control, after 3 to 5 minutes of operating if the diagnostic
tools detect abnormal operation, then its shutdown the unit
to protect from damage. Thermistor sensor is one of the
parts that detect the operation of the unit. Out of range
or defective thermistor can shut the operation of the unit.
- If your indoor and outdoor is clean start the unit in cool mode and monitor the outdoor pipes. If your suction pipe is icing or dry then your unit is under charge, but if your suction is cold and sweating then the system is ok and sure that the thermistor sensor is defective.
- Out of range thermistor sensor in both return air and freeze up sensor can cause the tripping “off “ the unit. The resistance of both thermistor is 8 to 10k ohms@25 deg. C temp. , so can test by using ohm meter.
- Try also to check the voltage in you area if normal, loose ac outlet.
- Be sure that unit is clean no obstruction in your air out and air in.
- Unplug the unit to reset the c6 error.
Posted on Jan 12, 2008
C6 error code
Check capistor and gas leaking
Dec 02, 2013 | LG LSC121PMA Split System Air Conditioner
ERROR CODE ON AIRCONDITIONER LG ART COOL INVERTER MODEL NUMBER LSZ244VM4
The first thing i'll say is you will need to get it repaired by a technician and i strongly recommend you not to do it by urself.
Goodluck..
Mar 08, 2008 | LG LSC183VMA Split System Air Conditioner
Our airconditioner has the code C6 on it. It has cut out and displayed that code. We were instructed to turn it off at the power board and turn it back on, which we did. It went back on again and tried to...
I previously asked you, if the C6 appear on the unit or on the hand held remote. I contacted a friend of mine who is a service technician for the LG Split System units and he advised that it's an error code that can only be solved by a LG trained service tech or LG itself. It may have been caused by a power surge, which may have caused some damage to the circuit board.
Sorry I couldn't be of more help.
Feb 03, 2011 | LG LA185HV Split System Air Conditioner
The led panel on the indoor unit shows a C6 error code the air con is a split system plasma inverter
C6 - compressor run current high
- check [resistance of] compressor windings all equal 1 to 4 ohms
- check [resistance] to earth 50 Mohm minimum
- check run current
I'd also check the motor capacitor(s) , In maximum, it is due to weak capacitor. Replace and try.
Dec 16, 2010 | Heating & Cooling
What is a c2 or c6 error code on the display of the wall mount unit mean can anyone help
C-2 Indoor in-piping sensor error C-6 Indoor Out-Piping sensor error. Replace both sensor.
Aug 22, 2010 | Comfort-Aire EHW 12 Air Conditioner
My samsung split system a/c keeps shutting down, with the mode light flashing on the indoor unit. This unit is installed 30' up the side of the house - is it not getting enough freon and there shuts down?
I have a MH050FX A2 that is two head unit and they run only one at a time, when I turn both on, one will shut down. I get an error code of E2 01 with a, I beleive correction code of U C8. Can you help me with a diagnosis??
Kelly Sheehan
Jun 17, 2009 | Samsung AS18A6RB Air Conditioner
Heating & Cooling Logo
940 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
