Question about Refrigerators
Feezer seems like it defrosts too long and ice cubes become wet, ice cream gets very soft, then they refreeze fine. thermometer shows 25 degrees above zero when it is happening. ADMIRAL MODEL HMG 19145, 15 year old product
    President:
  • 2,702 Answers
Well its gone wrong now? 25 degrees "above zero?" wow,,, thats cooking!!!! lets be honest,, its 15 years old? its about time you invested in a new freezer you have had your moneys worth out of this one,, and it will cost you more than its worth to fix it up, it realy is time you treeted yourself,, get a new one!
Posted on Nov 17, 2009
Kenmore upright freezer. Ice cream soft. Food is cold. HELP!
Ice cream has to be colder than 0 degrees C /32 degrees F. You need a cheap thermometer If your Ice maker Ice is not sweating in the bin, -10 degrees F ice stops sweating. you need not to sweat the freezer untill your cheap freezer thermometer can be compared to -10 degrees F
Nov 29, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Our 2 1/2 year old GE side by side frigerator has worked fine in the past, but now the top part of inside the freezer thaws part of the time. The ice cubes partially thaws then refreezes into a solid cube,...
hey i got disconnected do me a favor AND CLOSE OUT OF THE CHAT SESSION AND PLEASE RATE IT FOR ME I WILL FINISH UP EVERYTH ING FROM HERE SO YOU WONT HAVE TO PAY FOR IT AGAIN
Apr 24, 2010 | Refrigerators
The ice maker is making 1 tray of ice a day
There are 3 things needed to make proper ice.
Water, cold, time.
Check the cubes that are being made, they should be the same size crescent shaped. If they are not solid and some are hollow or broken then you are not getting enough water to the refrigerator. This is usually caused by the little valve on your house piping that connects to the refrigerator being plugged with sediment.
If the the cubes are all solid and the same size check the temperature of the freezer, it needs to be below 10 degrees F and works best below 5 degrees F. If it is warmer than that it will only produce ice on a very slow schedule. If you do not have a thermometer ice cream is a good indicator of temperature. If ice cream is hard the temperature is below 5 degrees F, if it is soft you are not cold enough to make ice cubes either.
If all this checks out alright you may need to have the ice maker replaced. the modular ice makers are available for sale at most all part retailers.
Apr 19, 2010 | Kenmore 74822 / 74824 Top Freezer...
Symptoms: Ice cubes melt, drip then refreeze causing
are you having any cooling problems? take a look at your ice cream, if you have any. does it look like it has melted and refrozen? if so, you have a cooling problem, and that is causing ice to melt, then refreeze. if you have no cooling problems, then you may have a faulty water valve solenoid, or even a faulty icemaker.
Feb 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Cream won't stay frozen it get's all soft and gross. Main things in the freezer stay frozen.
This is an easy one!!
Ice cream needs to be around -5 degrees to +5 degrees to stay frozen (or hard) if the freezer is at like 15 degrees the ice cream will be soft but the rest of the things like meat and ice cubes will be rock solid because anything lower than 32 degrees is freezing for those things.So you might wanna check to see if the fan motor is working and also make sure the condensor coil is free of debris.
Sep 20, 2009 | Refrigerators
Ice-maker thawing-refreezing into block of ice
Your defrost system may be out on this unit.
Aug 13, 2009 | Refrigerators
Cuisinart ice cream-frozen yougurt maker& sorbet maker CIM 60 series
I have the same problem, but it seems that it has gotten worse with time. When I first bought this product 6 years ago it worked fine, now the bowl won't freeze entirely and it has been in the freezer for two days (at the lowest freezer setting). I am wondering if the freezer bowl has a life span.
Aug 03, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Rubber door gaskets very warm to touch, ice cream soft, ice ok
the icemaker will work until the frezer gets to 17 then it will quit sound like a defrost issue defrost heater defrost thermastat or defrost timer need to get it fixed sooooooon you dont want to loose food at the price we have to pay
May 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
130 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
