Question about Saeco Magic De Luxe Espresso Machine
Leeks coffee into grounds container
My magic saeco started to dump coffee into grounds container - the quantity varies from time to time
  • fvaysberg Dec 11, 2009
    I replaced the thumbscrew and my espresso machine is back in business :) Thank you for your prompt and expert reply! It was greatly appreciated.
  • 1,089 Answers
HI
You have a stripped thumbscrew. Check the top left side of the brew unit. The thumbscrew is the little rod that sticks out of the top of the center part of the brew head. If there is water in the center cavity that's your problem. If you push down on the rod and check your brerw head screen on the other end it is probably pushed out a little. Pry the screen out, and you should see a barrel nut in the middle of the screw stem. Pull the thumbscrew out from the other end.
The plastic rod that has 2 small hooks on the end and has ribs around the opposite end is your thumbscrew. There is suppose to be a small round nut that is molded into the position between the legs with the hooks. If you use the key to tighten the thumbscrew you will pull the nut out and then the thumbscrew will pop out of the brew head. Check the stem of the filter screen. If you have an item about that is about 3/8 of an inch long and has a grove in the middle and small bumps on it, that’s the nut. You need a new thumbscrew. Remove the old nut on the stem before putting it in the new thumbscrew. Remember it’s a thumbscrew, so it only needs to be finger tight. The key is for removing only.
Posted on Nov 17, 2009
My Saeco Xsmall stops before brewing the coffee
1- The grind fineness setting is too fine. Pump is not able to pump through the compacted coffee grounds.
2- The machine is not descaled. The Calcium deposits in the hydraulic system have reduced the pump pressure. The partially clogged water passages can generate a back pressure to reduce pumping pressure. Was the machine descaled in the past two or three moths? If yes, what was the descaling product used?
3- The pump may be air locked and not able to pump water.
4- Oily beans may have been used. Oily beans are poison for the all fully automatic espresso machines. This clogs the grinding chamber or the grinder outlet. This model is made in Romania made in 2006 or after. This machine has a Ceramic Burr grinder 2006 which is a huge problem to clean adjust beans quantity per shot of espresso etc. etc. Occasionally it will dump dry coffee grounds when the quantity of beans powder is insufficient.
Based on the above details, you can figure out what is wrong and fix it. See the exploded parts diagram included, for help. Services Unlimited Inc Parts Guru Since 1988
Dec 29, 2016 | Saeco Coffee Makers & Espresso Machines
Re Saeco Magic Comfort+ coffee maker - machine notes that there are no beans in chamber when there are, and the grinding mechanism runs at about half the usual sound. I've removed the screws and clean
If the machine at some predetermined time is not filled with ground coffee a volumetric container it stops.
1. Check if the knives rotating.
2. Look if the ground coffee falls in grup while it is milling. If you left the volumetric tank open.
3.Maybe the knives mechanism is not at the right possition.
Nov 14, 2014 | Saeco Coffee Makers & Espresso Machines
My saeco magic deluxe, doesn't make coffee all the time, it seams the brew group arm is not riseing and the coffee gets dumped in the tray
Sounds like early stage of stripped gears in Gear assembly or faulty Main electronic board. These are the 2 most common problems.
Mar 28, 2010 | Saeco Magic De Luxe Espresso Machine
I put ground coffee and it doesnt come out only water.. is it my brewing unit ??
If you are putting the ground coffee into the little override container for decaf coffee I had the same problem because I was using a bit too much ground coffee so it dumped it out rather than making a cup. Once I ensured that I was using one level scoop only, not more, it worked.
Feb 28, 2010 | Saeco Magic De Luxe Espresso Machine
My Saeco magic grinds the beans, but no coffee comes out. Sometimes it makes one cup, and skips. Other times, I grind the equivalent of 8 cups of coffee without any cups of coffee coming out.
HI
When a machine grinds but doesn't make any coffee there are a couple of things.
If the grounds are wet in the dredge drawer, then you have a plugged brew head and need to clean it.
If the grounds are dumped dry into the dredge drawer, then you have an overcharge and need to adjust the dosing lever back from the full charge. On your machine it is inside the door at the top center. Pull the lever back towards the front 1 click. Then try again.
Nov 14, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco coffee machine
make sure that the brew group and door are close or dump box ect
Jul 08, 2009 | Saeco Magic De Luxe Espresso Machine
Add beans??
I had this same problem with my Saeco Magic Plus and found that cleaning the burr grinder fixed the problem. Here's a link showing how that is done:
http://www.cerinicoffee.com/Saeco_technical_documents.asp
Good Luck!
Mar 07, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Won't make coffee
Could you please advise how I obtain a manual for a Saeco Magic deluxe
Apr 28, 2008 | Saeco Magic De Luxe Espresso Machine
Bypass doser malfunctions
Happens when the preground coffee is not ground fine enough, you may have to put the pre ground coffee in a manual coffee grinder to make it finer. The machine is not really designed to brew regular coffee grounds.
Jan 20, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
231 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
